Micro modular friendly patches
Page 1 of 1 [20 Posts]
cappy2112
PostPosted: Fri May 27, 2005 10:34 pm    Post subject: Micro modular friendly patches Reply with quote  Mark this post and the followings unread
Does anyone out there still have a Micro ?
Was there every any naming convention used to indicate patches that would work for the MM ?
Are there any tools available that can scan through a directory of patches to determine if they will play on a MM ?
Audio files: 317
PostPosted: Sat May 28, 2005 3:06 am    Post subject: Re: Micro modular friendly patches Reply with quote  Mark this post and the followings unread
Nope, but some people did make patches with the micro in mind, there should be lots of 'm actually.
Nope, but it wouldn't be too hard to make such a tool, see http://www.iaf.nl/Users/BlueHell/info/patch303.htm#[Header]
Jan.
Audio files: 235
PostPosted: Sat May 28, 2005 9:42 am    Post subject: Reply with quote  Mark this post and the followings unread
I never had one of these, but I might pick one up. They are fabulous...
cappy2112
PostPosted: Sat May 28, 2005 8:28 pm    Post subject: Re: Micro modular friendly patches Reply with quote  Mark this post and the followings unread
Jan.
Thanks for the patch format spec.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sun May 29, 2005 12:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
These Patches are made by users working only with the Micro. Andrew Dymond made some real compositions on the little one.
Sorting out Micro Patches can be done the best searching on number of Voices. (1) At least, that's what I think...
Some folders in the Archive:
http://nm-archives.electro-music.com/010_NordModular/011_Patches/Abildgaard_Kenneth/
http://nm-archives.electro-music.com/010_NordModular/011_Patches/Pajanen_Pasi/Rectif/
http://nm-archives.electro-music.com/010_NordModular/011_Patches/Zzzzra/
http://nm-archives.electro-music.com/010_NordModular/011_Patches/Dymond_Andrew/
Wout
Audio files: 317
PostPosted: Sun May 29, 2005 1:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
That's what I meant to say, thanks for making it explicit :-)
Jan.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sun May 29, 2005 2:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yep, BUT if someone made a Patch special to the Micro and he was able to keep it below 50%, 2 Voices were possible, wasn't it? I thought the question was special asking for those Patches... That's why I gave these URL's of Patchers surely working with a Micro.
Wout
(who isn't that sure, anymore)
Audio files: 317
PostPosted: Sun May 29, 2005 5:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hmm yes indeed there were some polyphony freaks at work on micro's ... 6 or 7 voice patches even ... ok so it's a bit more complicated to auto find such patches, thank god we have Wout :-)
Jan.
cappy2112
PostPosted: Sun May 29, 2005 7:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wout
I"m glad you're still around Wout. You've got a great memory for all things Nord!
cappy2112
PostPosted: Sun May 29, 2005 7:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
That's what I meant to say, thanks for making it explicit Smile
Jan.
Doesn't the MM have 1 DSP- which is capable of four notes- max ?
I wrote my program to search for 4 notes or less.
Ok- in reality 4 notes with very minimal patch load, probably isn't very useful, but ...
davep
Audio files: 10
G2 patch files: 73
PostPosted: Sun May 29, 2005 11:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Remember Terryfunken's low-DSP pad patches called "8bitOrchestra"? I made a few modified versions as well. These used three LFOs as detuned audio oscs, and varied from about 19% DSP down to less that 10% DSP.
Dave Peck
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Mon May 30, 2005 1:54 am    Post subject: Reply with quote  Mark this post and the followings unread
There was some competition in creating Voices on the Micro.
I think I found two of these.
I have no Micro anymore (only full Classics), so I can't check if it's alright.
Wout
28VoiceOnMicro.pch
 Filename:  28VoiceOnMicro.pch
 Filesize:  821 Bytes
 Downloaded:  430 Time(s)
32VoiceOnMicro.pch
 Filename:  32VoiceOnMicro.pch
 Filesize:  915 Bytes
 Downloaded:  439 Time(s)
Audio files: 317
PostPosted: Mon May 30, 2005 2:54 am    Post subject: Reply with quote  Mark this post and the followings unread
That was one of the things keeping the NM list alive, all this experimenting with minimal suff - we don't do that anymore for the G2 (probablt it's too big for that ?)
Jan.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Mon May 30, 2005 3:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Pushing the boundaries, Jan. That is one of the things people love the best.
How many oscillators can you use in the NM Classic? Very Happy
The G2 is much more a players instrument, although, people are saying that! The NM Classic was more an experimental machine, both to the users as for Clavia itself. I still believe something of the designer's thoughts are really in the object itself...
Wout
http://nm-archives.electro-music.com/010_NordModular/011_Patches/Doornekamp_Ico/Iclock02.pch
transforms your Micro into an almost real Schwarzwalder Coo-coo-clock, which tics and coo-coo's on the hour. In the Editor one can read the exact time...
cappy2112
PostPosted: Mon May 30, 2005 1:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wout
thanks again-
Johan Zwart
Audio files: 19
PostPosted: Mon May 30, 2005 1:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
You don't say what kind of patches you're looking for, but this are mine.
All made with a Micro
http://nm-archives.electro-music.com/010_NordModular/011_Patches/Zwart_Johan/
cappy2112
PostPosted: Mon May 30, 2005 11:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nothing in particular at the moment- I've got an MM on the way, and wanted to get some sounds for it so I can check it out- as well as uunderstand what restrictions the MM has for patches
thanks to al who replied to the MM query!
hyperstationjr
G2 patch files: 24
PostPosted: Sun Jun 12, 2005 9:40 am    Post subject: Reply with quote  Mark this post and the followings unread
I had a Micro for about 2 years till I upgraded to a G1 key and added a G2 Engine. I had a HUGE selection of Micro patches I made, with patches up to 16 note poly (still sounded good too!), as well as a ton of downloaded patches I optimized for the Micro.
However their on a HD on my Win-98 machine with a dead motherboard, and no PC's in site aside from a laptop.. if anyone could give me a fix to this situation I'd gladly hook you up...
Studio:
Analog Four Mk2, Digitone, Iridium Desktop, Nord Modular Rack, Nord Modular G2 Engine, Octatrack Mk2, Syntakt, Torso S4, Torso T1
For Sale/Trade:
Alesis Microverb 4, Panasonic RQ-705 Reel-to-reel, Roland Alpha Juno1, Roland R5, Yamaha TG55
cappy2112
PostPosted: Sun Jun 12, 2005 10:53 am    Post subject: Reply with quote  Mark this post and the followings unread
You can always just connect the drive as a slave to another PC- like a computer at work, then copy your files off.
hyperstationjr
G2 patch files: 24
PostPosted: Sun Jun 12, 2005 12:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
I would have but I don't have access to a PC tower anymore, hence my problem.
Studio:
For Sale/Trade:
