Posted: Fri Mar 24, 2017 8:08 am Post subject:
But we DO care!
Nice job! |
mcop
Posted: Fri Mar 24, 2017 8:57 am Post subject:
| Indeed we do! I've been following your progress here and over at Muff's - looking great. |
Joined: Jan 31, 2003 Posts: 18314 Location: Durham, NC
Audio files: 235
yegglet
Posted: Thu Apr 05, 2018 4:18 pm Post subject:
Here's mine! Freshly built!
I was going to stretch leather over the faceplate but I think I'll just gussy it up with some decoupage instead.. |
Audio files: 235
Posted: Fri Apr 06, 2018 5:40 pm Post subject:
yegglet to electro-music.com
Your Benjolyn looks great... _________________ --Howard
my music and other stuff |
frequenzteiler
Posted: Sun Apr 15, 2018 1:57 am Post subject:
heres mine . its called bifold benjolin
6 pots to adjust the level of osc 1, 2 and pwm signal not implented yet . dont know if i really need them . but im pretty happy so far .
Audio files: 235
dragosandriana
Posted: Mon Oct 28, 2019 4:53 am Post subject:
Benjolin / Zeitgeist - "Globalizer" |
The "Globalizer" contains two benjolins (for patching dialogue) and one zeitgeist.
If you're interested, I can post a video later with it functioning in patch mode.
Thank you, Rob Hordijk!
Enjoy!
| Description: |
| Filesize: |
208.2 KB |
| Viewed: |
604 Time(s) |
| Description: |
| Filesize: |
106.97 KB |
| Viewed: |
605 Time(s) |
| Description: |
| Filesize: |
336.86 KB |
| Viewed: |
602 Time(s) |
| Description: |
| Filesize: |
367.5 KB |
| Viewed: |
594 Time(s) |
| Description: |
| Filesize: |
166.29 KB |
| Viewed: |
591 Time(s) |
Joined: Apr 03, 2004 Posts: 24673 Location: The Netherlands, Enschede
Posted: Mon Oct 28, 2019 3:40 pm Post subject:
Re: Benjolin / Zeitgeist - "Globalizer" |
| dragosandriana wrote: | | The "Globalizer" |
You even put a knob on Rob's home I see
Nice build! .. I would watch that video  _________________ Jan
dragosandriana
Audio files: 235
Posted: Wed May 06, 2020 11:08 am Post subject:
Just watched the video. Very cool. That's a great instrument. _________________ --Howard
mattkuebrich
Posted: Wed Feb 09, 2022 10:33 am Post subject:
Here's a quick test of the Zeitgeist circuit, which I recently adapted into a PCB/panel for Eurorack. I'm thrilled it seems to be working! I also did a 10HP Euro Benjolin a few years back, which you can see in the video.
https://www.instagram.com/p/CYux4pghnXf/ |
LFLab
Joined: Dec 17, 2009 Posts: 497 Location: Rosmalen, Netherlands
Posted: Sun Mar 06, 2022 1:20 pm Post subject:
Pretty cool, not many Zeitgeist builds around. Would like to build one myself, but there are some interesting other contenders around (NLC Delay no more ). |
zaphod betamax
Posted: Sat Mar 26, 2022 7:46 am Post subject:
Somewhat based on the Rungler.
Circuit has been changed multiple times.
When I get it right I can post.
Basically there are 2 square VCOs (no musical scaling)
formed with two slots of a CD4093BE.
Each of the VCOs feed a CD4517BE shift register with the
shift register feeding a 8 DA array and a MCP6002 opamp buffer.
These CVs control a F11V FET vactrol with the resistor element
across the resistor element of the VCO.
Each oscillator can either get its data from:
A "random" ring oscillator
-feedback slots on the CD4517BE,
or normalled to the square outputs on the CD4093s.
I need to buy 2 4 position switches!
Both oscillators feed a CD4070BE XOR which feeds a simple
2N7000 "VCA".
Very early days.
https://www.youtube.com/watch?v=aJAYRqCYBCE |
zaphod betamax
Posted: Sun Apr 10, 2022 10:21 am Post subject:
The Retroverb generates all sounds and reverbs. The VCF LFO is used to modulate Fc as well. The Audio output of the Retroverb acts as data input for a CD4517BE 8 Bit shift register. The clock is 1/16 notes from CV OCD, with MIDI Monotribe as master clock, it does not sound, it only makes the midi clock. The 8 bit shift register feeds an 8 bit R2R array which is fully buffered by a MCP602 single sided 5Vdd (0-5V CV). The CV controls the Fc on the Retroverb, which in-turn is fed back as data to the SR.
https://youtu.be/e3VhqNR2Iwg |
