Audio: 1sec --> 10sec
Page 1 of 1 [12 Posts]
sebber
G2 patch files: 33
PostPosted: Wed Oct 19, 2005 11:14 am    Post subject: Audio: 1sec --> 10sec Reply with quote  Mark this post and the followings unread
How can I stretch a 1s Audio snippet into a 10s thing?
More to the point:
I'm having a sequencer that controls the pitch of an oscillator. Now I want to prolong only one note out of that row and make it sound longer, but without using another oscillator (which I think wouldn't be elegant) and - of course - without stopping the sequencer to constantly change the pitch of the (one and only) oscillator.
Thanks for any tips.
sebber
G2 patch files: 33
PostPosted: Thu Oct 20, 2005 7:06 am    Post subject: Reply with quote  Mark this post and the followings unread
This is where I'm stuck: The loop captures the audio, but I don't know how to unfunny the sound. It either repeats itself or it doesn't sound like the original loop. I would like the audio capture to sound for e.g. 10 seconds.
Audio files: 226
PostPosted: Thu Oct 20, 2005 8:21 am    Post subject: Reply with quote  Mark this post and the followings unread
I don't see what is so unelegant about using another oscillator/sequencer. I wish I could help, but I don't do much with the delay modules.
sebber
G2 patch files: 33
PostPosted: Thu Oct 20, 2005 8:54 am    Post subject: Reply with quote  Mark this post and the followings unread
It wouldn't be only one oscillator but a couple of them. I'm programming a repetitive piece by Terry Riley and only a few notes need to be held longer than all other ones. I would have to build (well, copy and paste) a new "sound block" for each of the longer notes and think that would be a waste of resources. And wasting resources is unelegant Wink.
Audio files: 226
PostPosted: Thu Oct 20, 2005 9:06 am    Post subject: Reply with quote  Mark this post and the followings unread
OK, each to his own, but if the timbre is supposed to be the same, then I would imagine that notes artifically extended with the delay modules would sound different.
BTW, I'd be very interested in hearing your final version.
sebber
G2 patch files: 33
PostPosted: Thu Oct 20, 2005 9:43 am    Post subject: Reply with quote  Mark this post and the followings unread
I'll send it to the forum, but it won't be tomorrow...
deknow
PostPosted: Thu Oct 20, 2005 9:56 am    Post subject: Reply with quote  Mark this post and the followings unread
one of the things that always amazes me about the g2 is the ability to do very short and accurate durration events.
i think you might be better off trying to sample either one or a specific number of waveforms rather than trying to "capture the sound". if you are using specific pitches, this should be doable. you will want to start sampling at the begining of a waveform, and stop at the end (zero crossing detector)....at this point, you end up using the delay as a "digital oscilator" rather than a loop.
deknow
sebber
G2 patch files: 33
PostPosted: Fri Oct 21, 2005 3:02 am    Post subject: Reply with quote  Mark this post and the followings unread
That's a cool idea and I'll try that in another patch. I got myself in trouble with routing all over the place so I organized the patch completely new and I will use extra oscillators now. It might me easier after all and I'm not sure if I'd really safe a lot trying to be elegant.
Thanks for your input and I will post the patch when I'm done.
deknow
PostPosted: Fri Oct 21, 2005 7:56 am    Post subject: Reply with quote  Mark this post and the followings unread
i spent some time screwing around with this yesterday ( i didn't get far, but i learned a lot).
i'll post back if i come up with anything that actually works. in the end, however, it might be cheaper to use another oscillator (but less elegant of course).
deknow
Afro88
Audio files: 12
G2 patch files: 79
PostPosted: Fri Oct 21, 2005 7:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
Why not use an event sequencer freezes the note on a high logic signal, by using a sample and hold on the envelope gate and note signals? That way the sequencer keeps running while the note and gate data is sampled and held.
Afro88
Audio files: 12
G2 patch files: 79
PostPosted: Fri Oct 21, 2005 7:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
Kinda like this...
Pause.pch2
 Filename:  Pause.pch2
 Filesize:  1.93 KB
 Downloaded:  1342 Time(s)
sebber
G2 patch files: 33
PostPosted: Sat Oct 22, 2005 6:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Just wanted to say that I posted the patch here:
http://electro-music.com/forum/post-55059.html#55059
There's a bug and maybe your ideas are just what I need. Thanks for that.
