<on air> Twyndyllyngs tonight Chez Mosc
Edited
Page 1 of 1 [16 Posts]
illuminated
PostPosted: Sun Nov 06, 2005 9:02 am    Post subject: Edited Reply with quote  Mark this post and the followings unread
Edited
Audio files: 228
PostPosted: Sun Nov 06, 2005 9:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Welcome to the world of synthesizer design. Laughing
Pretend you are designing a polysynth. There are lots of tradeoffs. Hey, the G2 isn't pretend. I used to design hardware - not fun anymore...
If you have a complex routing scheme, it's fine that you have lots of knobs. You can keep them hidden or bring them to the control surface. Variations are good for changing these modulation matrixes.
If you develop a really nice flexible synth you can spend months or years developing variations for it.
illuminated
PostPosted: Sun Nov 06, 2005 9:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Edited
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Sun Nov 06, 2005 10:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Is this what you were looking for? If you go with a mod matrix, you will have many knobs. Unless you hardwire stuff or use multiplexers/switches (but then your source can only go to one place), you're gonna need knobs (in the shape of mixers).
Nasty sounding patch, but it illustrates how i do multi source to multi dest routing. I sometimes put a 1 input mixer (with button) to control the overall modulation depth (if the destination does NOT have a mod level built in).
Alternatively is you use switches then you need to decide how many destinations each of your mod sources will go to (at once). but then you need a level knob and a 1-4 or 1-8 switch which goes to your destinations. The disadvantage of this is you do not get an immediate idea of what all the modulation sources for a destination are (nor their levels).
Mixers are the way to go.
/Dasz
Routing_DZ.pch2
multi source to multi destination ..
 Filename:  Routing_DZ.pch2
 Filesize:  2.04 KB
 Downloaded:  1663 Time(s)
illuminated
PostPosted: Sun Nov 06, 2005 10:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Edited
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Sun Nov 06, 2005 1:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
actually, this is the same idea as the 8x8 matrix. but with examples.
/Dasz
G2DREAM
PostPosted: Sun Nov 06, 2005 5:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well very good question, i have now completely understood Dasz's 8x8 mod matrix!
Very good job here Dasz, very helpfull patch wich solved a lot of my problems!
Thanks from me too!
______________
cyber-evolution
illuminated
PostPosted: Sun Nov 06, 2005 6:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Edited
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Mon Nov 07, 2005 7:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Well, don't give me too much credit, I did not post the 8x8 matrix. Although I did figure it out on my own. My matrices are typically smaller than 8 by 8 ... more like 4x4.
/Dasz
Audio files: 228
PostPosted: Mon Nov 07, 2005 9:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Skip, that's a great patch, but why not program all 8 variations so we can hear what it is capible of?
Please
illuminated
PostPosted: Mon Nov 07, 2005 11:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Edited
Audio files: 228
PostPosted: Mon Nov 07, 2005 6:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
I guess I wasn't clear. Your patch is very flexible. Sure, everyone can take it and adjust it to make all kinds of sounds. Since you created this and have spent a lot of time with it, why not share some of the different sounds you can make with it? You don't have to, it is just a suggestion.
illuminated
PostPosted: Mon Nov 07, 2005 6:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
Edited
Audio files: 228
PostPosted: Mon Nov 07, 2005 6:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Some people are better at it than others. Different strokes for different folks. Some are neat and some are slobs. Some patches are actually artistic looking on the screen.
jamos
G2 patch files: 41
PostPosted: Mon Nov 07, 2005 8:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
skiptracer wrote:
i think there should be a standardized module organization scheme, like there are standard indent and formatting schemes with all programming languages.
Heh-heh-heh. Would that THAT were true.
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Fri Nov 11, 2005 10:33 am    Post subject: Reply with quote  Mark this post and the followings unread
What you are implying is what we've always asked for -- subpatches (like in Reaktor) with user defined module UI's (height, knobs buttons, displays, ins and outs)... But I'm not going to hold my breath that it'll ever see the light of day ...
/Dasz
