MIDI to clock
Page 1 of 1 [24 Posts]
Pehr
PostPosted: Mon Nov 07, 2005 8:08 am    Post subject: MIDI to clock Reply with quote  Mark this post and the followings unread
Does anyone know if there is any way to convert a bpm-signal from a midi source (MC-505) to an analog clock, to sync with my analog gear?... Confused Any DIY-project?
YouTube channel
flickr photostream
http://loxodrom.blogspot.com
PostPosted: Mon Nov 07, 2005 9:29 am    Post subject: Reply with quote  Mark this post and the followings unread
If you have a spare audio output on some peice of gear that has MIDI input, you might be able to just trigger a "note on", and use that to sync your analog gear. It would depend on the type of input the analog gear has, and what type of threshold is considered "on" vs. "off" that are supposed to be 5v will trigger ON if they receive a +1V signal (many digital inputs (74XXXX or most 0-5v type signals see ~.8v as on) . Since you would be sending pulses, you wouldn't need to worry about the AC coupling that most audio outputs have.
Worth a try at least!
deknow
PostPosted: Mon Nov 07, 2005 11:40 am    Post subject: Reply with quote  Mark this post and the followings unread
i've never actually bought one of these, but there are tons of uses for it (including yours):
http://www.blacet.com/misc.html
a preprogramed pic that converts midi clock to trigger....might want a clock divider as well.
deknow
Pehr
PostPosted: Mon Nov 07, 2005 1:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
deknow
That one might do the work! Very Happy Just have to try to get my hands on one of these. Razz
YouTube channel
flickr photostream
PostPosted: Mon Nov 07, 2005 2:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
http://www.paia.com/midi2cv.htm
THis one is OK.
Pitch and Gate control of 4 synth voices. Either Multi (assignment of data from four midi channels) or Mono (rotational assignment of data from one midi channel) operation.
Pitch, Velocity and Gate control of 2 voices plus Pitch and Mod wheel CVs. Either Multi or Mono assignment can be selected.
Pitch, Velocity, Pitch Wheel, Mod Wheel, Release Velocity, Channel Pressure, Gate and Re-trigger. Complete, true staccato control of one synth voice.
8 CVs from Continuous Controller messages. Controllers can be on one midi channel or separate channels.
Analog Drum Trigger Mode. 8 pulses by note# with pulse amplitude set by note velocity.
DIN Sync - 24ppq, Start, Stop and Continue PLUS simultaneous control of a single Pitch, Velocity, Gate, Wheel, Re-trigger synth voice or two multi-assigned voices with Pitch, Velcocity, and Gate.
Self-Test. Separate checks of midi input and analog outputs verify operation and aid in set-up and trouble-shooting.
Flickr
Pehr
PostPosted: Mon Nov 07, 2005 2:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
elektro80 wrote:
THis one is OK.
Yes, but expensive... Sad
YouTube channel
flickr photostream
deknow
PostPosted: Mon Nov 07, 2005 2:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
...and it doesn't do clock either (which is i think the question).
deknow
PostPosted: Mon Nov 07, 2005 2:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
it is? Shocked
Flickr
PostPosted: Mon Nov 07, 2005 2:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
THis one is OK.
Nah Stein! That is so last Autumn !!!
Why have midi clock when you can have one of these;
http://www.analoguesystems.co.uk/Reviews/rs3001.htm
happy smoker thumb up
ACHTUNG!
deknow
PostPosted: Mon Nov 07, 2005 3:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
...i have an old garfield electroncs box that converts analog clock into midi clock...a pretty neat trick.
deknow
Pehr
There is also this one, but it´s expensive too... Sad
YouTube channel
flickr photostream
PostPosted: Mon Nov 07, 2005 3:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
That one is a beauty!
Flickr
Pehr
elektro80 wrote:
it is? Shocked
Yes, it is... Rolling Eyes
PostPosted: Mon Nov 07, 2005 3:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Pehr,
It's a kit, but it's got a good spec above all it offers a lot of bang for its buck (I reckon Smile );
edit- hahahahaha- time to lay off the coffee (AND this Moseley homegrown Sensi!!) !!!
But seriously, Stein is right- you won't get cheaper I reckon Smile
Unless you print that link Deknow Evil or Very Mad
PostPosted: Mon Nov 07, 2005 3:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Actually, I have it. It works fine. I can recommend it. They even updated the firmware.
Flickr
PostPosted: Mon Nov 07, 2005 4:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Specifically, what analog gear are you trying to control with clock pulses? How much of a divide is needed from midi clock (always 24pulses per beat) to the analog trigger?
I still think a simple audio output connected to your gate input (or other) is all that might be needed. This could come from your laptop, or an extra output on the MC-505 (more or less, you just need to sequence a metronome as this audio control signal). Worst case, a 5V buffer like a very cheap 74LS04 could be used to drive the signal to 5V. It would take less than an hour to build something like this very nicely. 10 minutes as a quick hack.
Audio files: 320
PostPosted: Mon Nov 07, 2005 4:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
AND you could go wild with using outrageous trigger signals, sounds like fun !
Pehr
PostPosted: Tue Nov 08, 2005 2:00 am    Post subject: Reply with quote  Mark this post and the followings unread
I want it to sync with other analog sequencers... Confused
YouTube channel
flickr photostream
PostPosted: Tue Nov 08, 2005 3:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey Pehr,
Keep your eye out for an old Roland TR707 drum machine.
I used to have one and it does the job perfectly. It has 2 separate clk outs which can be programmed into any pattern as rim shot(?) events.
So not only can you divide the clocks, you can program a clock "seive". It's got Midi In/Out/Thru and you get a load of cheesy 80s drum sounds thrown in for free Rolling Eyes
Seriously though, if I see one cheap I'm getting it.
Also, as it has a separate output for every drum, JKs idea about the 5V buffers could turn it into a 12 Channel programmable Midi to Clk box!
Ghees,.. The Uncle's getting excited now!! Very Happy
deknow
PostPosted: Tue Nov 08, 2005 6:30 am    Post subject: Reply with quote  Mark this post and the followings unread
...i have a 707 that most often gets used just as you are are describing (the trainspotters get sweaty and nervous if they see a 909 being used for such things). pehr is (i think) looking for something specifically to run the sl in sync with midi clock...and for this, the blacet chip is ideal...a 707 is a whole other piece of gear.
deknow (who does love to clock arpeggios with irregular patterns)
Pehr
PostPosted: Tue Nov 08, 2005 6:53 am    Post subject: Reply with quote  Mark this post and the followings unread
But I want diy... Confused What I really want to do is havingtwo analog sequencers synced with drums somehow... Maybe a couple of DS-7 with some sort of multi channel trigger sequencer... I dunno Rolling Eyes
YouTube channel
flickr photostream
PostPosted: Tue Nov 08, 2005 7:39 am    Post subject: Reply with quote  Mark this post and the followings unread
I have a TR 707 too.. still.. It is excellent for what Uncle is suggesting.
Flickr
PostPosted: Tue Nov 08, 2005 1:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
Have you checked out this idea based on the Blacet PIC?
http://www.hoohahrecords.com/resfreq/modular/patseq/patseq.html
PostPosted: Sat Nov 12, 2005 4:36 am    Post subject: Reply with quote  Mark this post and the followings unread
elektro80 wrote:
I have a TR 707 too.. .
gotcha Stein!!! You do use drum machines after all!! Laughing Shocked Embarassed
I'm diggin' this new server!!
