Hardware upgrade kit for G2 Engine
Page 1 of 1 [19 Posts]
pal
PostPosted: Tue Nov 22, 2005 10:32 am    Post subject: Hardware upgrade kit for G2 Engine Reply with quote  Mark this post and the followings unread
I could defenitly use a build in Mic pre amp just like the keys version...
And a view midi knops at the front....and a small lcd, so at least you can see witch patch/performance is running....
I can remember a guy fixing a joystick on his NM classic...
PostPosted: Tue Nov 22, 2005 10:48 am    Post subject: Reply with quote  Mark this post and the followings unread
pal
PostPosted: Tue Nov 22, 2005 11:01 am    Post subject: yeah Reply with quote  Mark this post and the followings unread
Thats the one, you happen to know the guy?
deknow
PostPosted: Tue Nov 22, 2005 11:38 am    Post subject: Reply with quote  Mark this post and the followings unread
...you might want to read the second to last post in this thread as well.
http://www.electro-music.com/forum/viewtopic.php?highlight=pedal+input&t=3840
deknow
pal
PostPosted: Tue Nov 22, 2005 12:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks for the link, probably the theory does not work since there is no keyboard connected to the engine model...to bad Sad
deknow
PostPosted: Tue Nov 22, 2005 12:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
...if all you want to do is stuff a mic preamp inside the box, you probably could...you might even be able to add some controllers, but they would have to be interfaced via midi inside the case.
deknow
PostPosted: Tue Nov 22, 2005 12:06 pm    Post subject: Re: yeah Reply with quote  Mark this post and the followings unread
This particular one is Rob's probably as it is without a switch, Wout has two AFAIK, and I have one as well.
Wout and Rob are also on this forum, btw.
There is also this thread in the archive.
PostPosted: Tue Nov 22, 2005 12:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
pal wrote:
[...] since there is no keyboard connected to the engine model...to bad :-(
You could try to find out maybe how the keyboard detection works.
deknow
PostPosted: Tue Nov 22, 2005 12:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
jan, rob explained (in the thread that i linked to), that there is a differant rom in the engine and the kbd...the engine likely doesn't even look for a kbd. i could imagine replacing the rom and hacking a false kbd detection, but that's more than i would want to get into on something as expensive as a g2 engine.
deknow
PostPosted: Tue Nov 22, 2005 12:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes I know, but as long as noone actually tested it there is hope :-)
tombola
G2 patch files: 9
PostPosted: Wed Nov 23, 2005 7:25 am    Post subject: Reply with quote  Mark this post and the followings unread
That joystick is awesome!
I don't understand how Clavia could see that, then NOT put a joystick in the G2! (Although I guess there are one or two other things which we could say that about... )
The new Metasonix synth:
http://musicthing.blogspot.com/2005/11/behold-mighty-metasonix-s-1000-tube.html
has a joystick with a built-in envelope trigger.
pal
PostPosted: Wed Nov 23, 2005 11:13 am    Post subject: Reply with quote  Mark this post and the followings unread
deknow
Maybe someone wan't to unscrew his G2 keys and make pictures on how the mic pre amb is connecte Laughing
I think a mic pre amp kit would be possible if clavia want's to...
Tried to send a email but server is not working.... il try later Wink
deknow
PostPosted: Wed Nov 23, 2005 11:26 am    Post subject: Reply with quote  Mark this post and the followings unread
well, i'm pretty sure that the mic input is not in addition to the 4 external ins, so a simple switch that goes between using one of the existing inputs and a mic input would do the job (if you use a 1/4" connector rather than xlr, you could have it switch automatically).
on the other hand, the engine could simply go into a 2 space rack with a mic preamp in the other space.
if you are not looking to use a super high quality mic, the radio shack tie clip mic is about $25, and puts out a signal that is close enough to line level that you won't need a preamp.
deknow
PostPosted: Wed Nov 23, 2005 1:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
I use an external mic preamp, even though I have the G2 keys. It's not for quality, it's just a Behringer SHARC, but I use it to kill feedback from my didje (sticking a Mic up a tube while near a PA system isn't, in general, a good idea for avoiding feedback). Plus, it has compression and phantom power. I very much recommend it for live work (I assume that's why you want it very compact?).
pal
PostPosted: Wed Nov 23, 2005 3:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well that Behringer SHARC thing looks very handy!!!! thanks for the tip!
deknow
PostPosted: Wed Nov 23, 2005 8:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
the sharc has cool features (i have one, and the band owns another 2 or 3), especially for the price. i hardly use it, but i will say that when, on occasion, i need it for something, it is a little cryptic to get everything setup correctly...not impossible, and if i used it regularly (or spent some time with it when i didn't all of a sudden "need it", it would probably not be an issue. nothing wrong with the thing, but it is not like using a channel strip....and the powersupply is about as big as the unit!
deknow
PostPosted: Wed Nov 23, 2005 11:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
It has lots of little random features too, like line delays for speaker timing. And a noise gate. A little swiss army knife of audio, if you will.
pal
PostPosted: Wed Nov 30, 2005 3:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Well i bougt the SHARK (behringer) for my first live gig Last saturday and everything whent great!!!! thanks again for al the help on this forum for help with the G2!!!!
Rob
G2 patch files: 109
PostPosted: Wed Nov 30, 2005 3:29 pm    Post subject: Re: yeah Reply with quote  Mark this post and the followings unread
Hey, I know that guy for a long time... At least I remember him polishing that steel shaft on that joystick. Very Happy
On the question of modding the G2 Engine with G2 key features I can quote the Clavia developers:
    The key versions have their specific features on the panel circuit board, e.g. the A/D converter for the pedal input is on the panel board, also some of the mic preamp circuitry. As there is no panel board in the Engine there is no straightforward way to add those features to an Engine. On startup the motherboard detects the presence of a panal board, if it can't find one all software that handles the G2 key and G2X specific features is simply not loaded and can't be activated (meaning all panel board functions plus mic preamp plus control pedal input).
    The G2X panel board has an A/D chip with two more channels as the 3 oct G2 key, to handle the two extra global wheels. These global wheels cannot be simply added to the 3 oct G2 key, as it lacks A/D channels to read them.
And that's how it is. Sad
/Rob
