Posted: Fri Nov 25, 2005 10:25 pm Post subject:
Clean & dirty ground connections |
Something very interesting I've discovered over the past few weeks is the idea of a clean ground (for audio chips etc) and a dirty ground (for logic chips) it stops the logic chips from contaminating the op amps with logic spikes.
To implement it on a synth you need to run a new dirty ground to every logic chip and take it right back to the main filter caps, where you have a common conection to the clean ground.
I don't know whether it is feasible (or even needed) to put this on the SL, but I thought I'd share the idea with you all just in case you didn't know about it. _________________ What makes a space ours, is what we put there, and what we do there. |
etaoin
Joined: Jun 30, 2005 Posts: 761 Location: Utrecht, NL
Posted: Sun Nov 27, 2005 11:07 pm Post subject:
I must say that I hadn't heard of separate grounds before. It would be very, very tricky to connect anything if you can't connect the grounds. In your example, the grounds are still connected, albeit somewhere else. It might do something, but my guess is that it doesn't make much difference. Also, as I understand it, logic spikes are in your power lines, not in your ground.
But having separate power supplies for digital and analog stuff is pretty common. I'm building some boards from Ken Stone at the moment en he recommends a separate 'dirty' power supply for everything digital. |
Posted: Mon Nov 28, 2005 5:44 am Post subject:
Yeah,
My initial thought was that it wouldn't make much difference. I definately don't know the details of it, but I want to look into it. I think the idea is that spikes from the logic chips will go down the path of least resistance which is to be soaked up by the filter caps (as they would hit them first). The separate run back to the caps would have it's own inherent capacitance as well, albiet very small, but that's fine when you're trying to take the edge off a very short transient.
I'll look into it a bit more and let you know whatever I find out. _________________ What makes a space ours, is what we put there, and what we do there. |
Joined: Jan 31, 2003 Posts: 18291 Location: Durham, NC
Audio files: 235
Posted: Sat Dec 03, 2005 9:59 pm Post subject:
If I remember correctly, the Buchla 200 Series modules had clean and dirty grounds. _________________ --Howard
my music and other stuff |
etaoin
Posted: Sun Dec 04, 2005 10:48 pm Post subject:
| mosc wrote: | | If I remember correctly, the Buchla 200 Series modules had clean and dirty grounds. |
Probably related to the separation of control and audio. They even used different plugs for each. |
etaoin
Posted: Sun Dec 04, 2005 10:55 pm Post subject:
| I should say "use", as they are still in production. If you have a bit of spare cash... |
