<on air> Twyndyllyngs - not canceled Chez Mosc
need help New with G2 module
Page 1 of 1 [6 Posts]
alione
PostPosted: Wed Dec 14, 2005 2:42 pm    Post subject: need help New with G2 module Reply with quote  Mark this post and the followings unread
i am sorry ; i bought today my brand new g2 module : i work at Digital performer but i cant open the Edit /midi/audio menu at the g2 editor , so i cannot connect to my master keyboard channel.,
any idea?
how can i connect it to my midi system ( ok cables in/out to Midi time piuece but no menus avaible)
Audio files: 231
PostPosted: Wed Dec 14, 2005 2:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Congrats on the new G2 and welcome to electro-music.com
You set the midi channels using the Synth->Settings menu on the editor, or on the G2 front panel using the System button.
alione
PostPosted: Wed Dec 14, 2005 3:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks very much but that is the problem thta menu is not avaible is in grey color and i cant open it,
Your wellcome Smile
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Wed Dec 14, 2005 3:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sounds like the USB is not connected properly. The G1 used midi for the editor but the G2 uses USB. If you have installed the USB drivers and connected the cable and it still does not work, try a different USB cable.
alione
PostPosted: Wed Dec 14, 2005 3:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
well actually i could open that menu , but something must be wrong ....i have midi signal at my MTP but th routing maybe is not fine Crying or Very sad
alione
PostPosted: Wed Dec 14, 2005 3:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks!!! its resolved ( bad cable)!! thks
is not easy.......... Shocked
