today> Twyndyllyngs Chez Mosc
 Forum index » Online Music
Way up high
Page 1 of 1 [6 Posts]
TheWidestSmilingFaces
PostPosted: Thu Jan 12, 2006 2:30 am    Post subject: Way up high Reply with quote  Mark this post and the followings unread
This is a new song I recently recorded, there's a bit of hiss since I had the microphone too close to the computer ( I think that's why)
Please tell me what you think
way up high.mp3
Go away sun so I can sleep, come back sun to hide the moon
 Filename:  way up high.mp3
 Filesize:  3.07 MB
 Downloaded:  4066 Time(s)
http://spoti.fi/2KOaErr
Audio files: 234
PostPosted: Thu Jan 12, 2006 8:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Could be a good song. I think you need to work on the recording/production techniques a bit. The voice need some equalization and compression and needs to be put back in the mix, IMHO.
PostPosted: Thu Jan 12, 2006 12:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks, I'll try the equalization and compression on the voice now.
Edit: I'm hearing a slight difference, but not a huge one, my ear isn't well trained for this at the moment
The song has a "minimalist" feel, even though it probably has more tracks than most of my songs, it's a bit of a lullaby i think, or at least that's what i'm going for.
PostPosted: Fri Jan 13, 2006 10:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
I used garageband to record this song ( i have logic too) when doing the compression, at some moments it sounded perfect, but then it would "change" mid song. Unfortunately, I'm not sure how to do it properly.
Audio files: 309
PostPosted: Sat Jan 14, 2006 6:52 am    Post subject: Reply with quote  Mark this post and the followings unread
I agree with mosc on the production remarks he made.
The voice and the text have a certain intimacy which is really great but it gets lost for me I think because the voice lacks a certain distance. It's too close, either the microphone was too close or it is too loud in the track.
When you recorded this in one go (as a single track) it will be hard to do something about it (applying compression will cause pumping in the other sounds) - only re-recording would help. When the voice is a separate track it could work to compress it, but there are some plops in it that will be hard to deal with - maybe a slight touch of reverb could mask it a bit - but it might loose it's intimacy then.
PostPosted: Sat Jan 14, 2006 3:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
There are 3 tracks. tracks for guitar, vocals, and keyboards.
I think i figured it out though, thanks for all the comments!
