today> Twyndyllyngs Chez Mosc
Slow decay of sustained sounds
Page 1 of 1 [15 Posts]
bensc
PostPosted: Sat Jan 28, 2006 6:34 am    Post subject: Slow decay of sustained sounds
Subject description: Live Sound
I'm writing a piece for Bass Clarinet and Double Bass. Both will be playing long sustained sounds. I want to be able to sustain these when they change pitch. So the sounds would decay very gradually over a period of about ten minutes. Is this possible with a standard piece of equipment? For example, would this do it: http://www.dolphinmusic.co.uk/page/shop/flypage/product_id/6739
There are probably a few ways to do this...I'm looking for the most 'cost-effective' way.
DrJustice
PostPosted: Sat Jan 28, 2006 11:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Bensc!
I don't think a reverb is the solution. Most reverb units will not give you more than at most a couple of tens of seconds of decay time. Also, reverbs do 'dissolve' the sound as time goes by.
If I understand your requirement, it is pretty specialized. Something could probably be made with PD (Pure Data) to acheive this. To quote from the authors site it is a "...software system for live musical and multimedia performances ...". It is freeware, so it should fit your budget.
PD could be programmed to automatically catch the sound in a buffer each time a new pitch is played, then sustaining (looping) that sample. Perhaps someone has even made a similar patch already?
We have a forum with PD discussion right here here. And here is a Wikipedia article and a PD community portal.
DJ
bensc
PostPosted: Sat Jan 28, 2006 11:39 am    Post subject: Thank you! Reply with quote  Mark this post and the followings unread
Thanks for the help Dj, Much appreciated!
Bensc
deknow
PostPosted: Sat Jan 28, 2006 11:51 am    Post subject: Reply with quote  Mark this post and the followings unread
as the composer, you have to decide what it should sound like, and how complicated you need the effects to be (which might impact how often the piece is performed).
i would start with a basic delay unit (or software), and try just using a delay with a long decay (you could try an older digitech rack or a pedal). you could probably put something together in pd or max that would be "smarter" about how it did things (like not loop the attack or decay of the note), but you need to first define what it is you want to happen (not what it will sound like). the nord modular g2 would allow you to do this a little easier (at least it would be easier for me), and also will allow you to use a g2 engine (no settings, no buttons, no knobs) for performance (easier to send an engine around with the performances than to load and keep stable pd or max on a laptop that is not dedicated for the purpose, and that others might screw up by clicking on an infected email or surfing porn).
it's a little like building a moustrap....trapping the mouse is easy to define, but pulling the string attached to the cheese that turns on the water faucet, which spills the bucket and starts the toaster.......etc is the level on which you must think. something like:
"when a note is sustained for more than 10 seconds, take a 2 second loop, and mix it in to the output when the pitch changes". if you don't like the results (ie, a click when the loop restarts), then you need to figure out what is wrong with the moustrap....as the mouse is still running free.
deknow
rbedgar
PostPosted: Sun Jan 29, 2006 12:51 pm    Post subject: Long decay of sustained sounds
Subject description: A suggestion
#1: if you want to work with an algorithmic program anyway, I'd second PD. But there's a steep learning curve.
#2. One pedal that would work for you is the Boomerang. It has several decay modes, and you could easily mix a sample of several seconds with a long delay mode to give a 10-second long delay. The Boomerang is also excellent for live performance.
I just attended a new music concert in SF featuring a bass clarinet, what a magnificent sound!
-Robert
Robert Edgar
rbedgar@stanford.edu
www.robertedgar.com
The present day composer refuses to sleep...
DrJustice
PostPosted: Sun Jan 29, 2006 4:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Bensc says he is after 10 minutes (!) of sustain/decay. That's why I thought plain reverbs, delays and loopers doesn't really apply. I don't know the community myself, but I'd not be surprised if there are PD buffs out there just itching to assist in making a patch for this Smile. I suggest posting a request directly in one or more PD fora.
DJ
PostPosted: Mon Jan 30, 2006 3:41 am    Post subject: Reply with quote  Mark this post and the followings unread
So; if I understand it all correctly we need sounds that sound like acoustical instruments (to some degre....) that change pitch and that decay very, very slowly; far slower then most envelopes can go. And we need it cheap....
What if we were to use a off the shelf sound module, then use very long midi notes, simply ignore the envelope decay and instead modulate either the sustain value or the overall volume using MIDI CC's. We could then use features like legato or pitchbend to do the modulation.
I feel Tassman is the best choice for doing emulations of acoustical elements with "unnatural" twists but at a very small budget a freeware sample player followed by a tactfull combination of both chorus and some reverb (to keep it lively) might get you by?
The largest challenge (and most topical to this section) might be keeping the sound interesting for that period; I'd concentrate on that question.
PostPosted: Mon Jan 30, 2006 3:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Oh, wait, perhaps acoustical instruments are involved?
In that case it becomes much harder. How about some technique like a phase locked loop that tracks the instruments pitch and controlls a delay. At speciffic moments this looped delay set to a feedback rate very close to 100% would sample the instrument, then loop it (and stop tracking), basically making the whole instrument into a cross between Karpluss Strong and a acoustical instrument. Next note would use a new sound buffer. Again tactfull application of chorus would help.
This would be hard but not impossible to code but would need lots of practice. Pedal controlls for the instrumentalists might help?
rbedgar
PostPosted: Mon Jan 30, 2006 1:45 pm    Post subject: long decay
Subject description: well...
No arguments from me, if someone wants to code this puppy.
But a Boomerang will do this.
-r
Robert Edgar
www.robertedgar.com
morbius
PostPosted: Sun Feb 12, 2006 10:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
I posted this somewhere else (the mind is the second thing to go)... anyway- the Boss DD-20 Mega-Delay gives you up to 23 seconds of delay or sound-on-sound. And, it is in a guitar-pedal format, so it would be easy for the musician to use it, if needed. It also has four presets, panning, tape, analog, smooth, twist... a bunch of modes.
I use mine with my modular, and love it. I may even get an Etherwave, and use it with that.
~Morbius~
http://www.MusicByCybertron.com
morbius001a@yahoo.com
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Mon Feb 13, 2006 12:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Sounds interesting, how good is the tape mode and what does smooth do?
morbius
PostPosted: Mon Feb 13, 2006 9:15 am    Post subject: Reply with quote  Mark this post and the followings unread
The 'tape' and 'analog' modes sound pretty close to 'real'.... but- I'd like to point-out that many people (like me) get used to the superior quality of the 'digital delay' effects... and you start wondering why you'd want to use 'tape'..... 'warmth' not withstanding. Well, that's just my opinion.
So many rave about the sound of the Mellotron. I have found that in many of these cases, this fondness of the Tron is from 20 or 30 years ago (when there wasn't anything better). If you have a Motif ES or other sampler which has samples from a Tron, and also a current-day approximation of a Tron-like sound (only without all of the tape-noise and crappy frequency range of the Tron)... in a A/B comparison, ya kinda listen to the Tron and go.... "Yuuuuuk". (I know, I know... I jumped off topic there).
Anyway- the 'tape' and 'analog' modes do a pretty good job of it. "Smooth" does pretty much what the name implies... gives you a smooth sounding delay, which takes much of the digital-edge off of the sound. Still- my favorite is the 'pan' mode. Since you can work in either BPM's or milliseconds, you can set the delay for any amount of feedback, and since the 'pan' mode is cross-bouncing in the stereo field, you can fatten-up the sound a whole bunch.
Oh yeah... you can work with mono or stereo inputs... AND outputs. I'm not going to tell you that I know for sure that this is what you want or need... but, I will tell you that it's worth going to your local Guitar Center or other music store to check it out in person. (Then, if you like it... search around online for the best price) Wink But, there are two or three units that are sort of close... long delay times.... sound-on-sound, etc. ..... I would A/B those at the music store. For me, it wasn't just the total delay-time, but the sound quality, and the user controls, which are important, as well. There may be something newer and better... (or not).
For use with a modular system... it works great inserted into the signal-path. And since it has a stereo mode, you can take full advantage of that within patches, even if you chose mono as the final output. Lost of territory to explore. Laughing
~Morbius~
PostPosted: Mon Feb 13, 2006 9:30 am    Post subject: Reply with quote  Mark this post and the followings unread
[quote="morbius"]
Very true. I love the Trons but I don´t think I will ever even considered buying one again. It is still an instrument with a nice character, but a mac with the M-Tron standalone does a far better job.
Flickr
morbius
PostPosted: Mon Feb 13, 2006 10:02 am    Post subject: Reply with quote  Mark this post and the followings unread
Well that... and the Trons are a maintenance nightmare.
~Morbius~
PostPosted: Mon Feb 13, 2006 10:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Yup. It is the stuff that makes you wake up at night screaming.
Flickr
