!linear
Page 1 of 1 [8 Posts]
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Tue Feb 21, 2006 3:35 am    Post subject: !linear Reply with quote  Mark this post and the followings unread
Taking a rest from the Random module group.
The glitchy patterns here are produced by a shift register with feedback so they are not random, if that matters Rolling Eyes
!linear.prf2
random holiday
 Filename:  !linear.prf2
 Filesize:  11.35 KB
 Downloaded:  2232 Time(s)
Audio files: 232
PostPosted: Tue Feb 21, 2006 12:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
I like this one... Very Happy
PostPosted: Tue Feb 21, 2006 1:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Doesn't the pattern gen. module use LSFRs also?
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Tue Feb 21, 2006 2:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Most likely.
This one is not optimal length, and gives access to all the bits in parallel. So I trigger 3 different sounds off the same rotating bit sequence. Also the bits are assigned randomly (or are they carefully selected connections?) to a couple of DIY 5 bit DACS for dynamics.
Just an exercise I suppose, choosing to limit the modules you use can sometimes result in new ideas.
Afro88
Audio files: 12
G2 patch files: 79
PostPosted: Tue Feb 21, 2006 3:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
This is great g2ian!
PostPosted: Tue Feb 21, 2006 9:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sorry! I suppose reading back that my typed words didn't sound like they would have coming out of my mouth. Just an observation, though.
I do like the multiple taps off the shift register, and the end result, as always Ian, sounds great.
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Tue Feb 21, 2006 11:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
No need to say sorry, it was a good point Smile
I like the way the random modules can be made to repeat a sequence of values. In hakuyen.prf, the rythmns are random but every two bars get repeated which makes it sound more 'composed'.
Audio files: 232
PostPosted: Wed Feb 22, 2006 7:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, this seems to satisfy the mind. I think it is established compositional practice that "always twice, never thrice". I've found this to be a good rule of thumb. Still, if you put in a transposition, mode change (key change), inversion, or retrograde, you can have a lot more variation and still keep that 'composed' quality. No matter what you do, repeated patterns will get stale pretty quickly.
