 Forum index » Clavia Nord Modular » G2 Performances - Experimental
AnalogHeaven
Page 1 of 1 [13 Posts]
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Mon Jan 30, 2006 1:24 am    Post subject: AnalogHeaven Reply with quote  Mark this post and the followings unread
Synth base in slot A uses an experimental jitter technique. The mixer sums filtered noise and pulses generated at the peak of each sawtooth. This is sort of like the background noise present in multi oscillator circuits where spikes occur when the FET switches to discharge the capacitor. Each saw oscillator syncs to itself via a level shifter and a little of the ‘bus noise’. The noise causes a subtle shifting or jitter on each cycle which prevents the oscillators from locking even when tuned the same.
Slot C has a sort of dikmik crossed with a Shepard tone, the Shepard tone is using zero Hz PM oscillators as sine shapers for the volume enveloping.
AnalogHeaven.prf2
synthesists in heaven play ARPs
 Filename:  AnalogHeaven.prf2
 Filesize:  11.45 KB
 Downloaded:  2316 Time(s)
Ivity
G2 patch files: 57
PostPosted: Mon Jan 30, 2006 2:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Wow Shocked Very impressive!
Igor
www.myspace.com/phoiod
www.bl-project.com/Ivity.html
monokit
G2 patch files: 8
PostPosted: Mon Jan 30, 2006 3:30 am    Post subject: Re: AnalogHeaven Reply with quote  Mark this post and the followings unread
Ah, I guess you've been reading that Kevin Lightner article about the secret of the Moog modular OSCs?
Can't listen now, but I'm dying to find out. Does it indeed work??? Do you get a more analog tone this way? Especially in the bass?
klontart sound and vision blog: http://www.klontart.com
coolcat
G2 patch files: 28
PostPosted: Mon Jan 30, 2006 7:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Fantastic!!! well done
cat Menno
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Mon Jan 30, 2006 12:07 pm    Post subject: Re: AnalogHeaven Reply with quote  Mark this post and the followings unread
Yes I did, I also remember reading what Bob said in a copy of 'imoogination'.
I like the effect, very juicy when the filters open up. but I am not sure how different it is to alternate tricks posted by Rob and others.
Mind you, I once had three Minimoogs side by side, one with the original discrete oscillators, and I liked the newer ones better. The elders sound was subtly different but not 'better', and the more frequent retuning was just a pain.
I agree with Kevin's statement that slow drift is not the reason for the sound character. All analog oscillators drift a little but the change is too slow to affect the character at any one point in time.
Edit: Another thing about the Mini is it cant do that 'odd only' pure square sound. The ratio needs to be exactly 50:50 and the mini's square is not quite right.
cebec
G2 patch files: 31
PostPosted: Mon Jan 30, 2006 5:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
awesome. bassline sounds really nice.
cappy2112
PostPosted: Mon Jan 30, 2006 6:01 pm    Post subject: Re: AnalogHeaven Reply with quote  Mark this post and the followings unread
Mutated, or straight?
I can' t look ath the patch now, at work.
What's worse, I can' t listen Smile
Stanley Pain
Audio files: 10
G2 patch files: 35
PostPosted: Wed Feb 22, 2006 1:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
i've looked at this patch for a while now and i think i'm missing something obvious.
on slot B (the pad sound) how are you changing from an apparent 9th to the major 3rd? i can't seem to find the modulation source.
i love that pad btw.
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Wed Feb 22, 2006 1:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Slot B is played via internal MIDI from the FX section in Slot A (Bass sequence). I try and keep all the MIDI sequencing in one place so I can sync the parts witout using another ClkGen.
Audio files: 231
PostPosted: Wed Feb 22, 2006 2:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Superb... Very Happy
BobTheDog
PostPosted: Wed Mar 01, 2006 1:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Another great patch!
How do you get the time do keep doing all these, or can you knock them out quickly?
I am very jealous!
Andy
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Wed Mar 01, 2006 3:35 am    Post subject: Reply with quote  Mark this post and the followings unread
I don't watch much TV anymore. Not smoking also freed up a lot of time, all those 10 minutes add up.
And I don't have a 9-5 job Very Happy .
BobTheDog
PostPosted: Wed Mar 01, 2006 2:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Mmm, I don't watch TV anymore either (apart from the news once a day), but I do have a 9 to 5, maybe I need to give it up as well.
Andy
