 Forum index » Clavia Nord Modular » G2 Performances - Experimental
PM bassoon and kinda quacky oboe
Page 1 of 1 [4 Posts]
Chet
G2 patch files: 35
PostPosted: Sat Mar 18, 2006 9:30 pm    Post subject: PM bassoon and kinda quacky oboe Reply with quote  Mark this post and the followings unread
Here's a bassoon and oboe. The bassoon's not too bad, but the oboe gets quacky on the low notes. It's because the oboe patch is playing the second harmonic of the pipe, forced there by a pair of notch filters that prevent first-harmonic vibration. I liked the effect it gave the attack on the higher notes, but the lower notes now sound pretty quacky. Maybe I'll modify the patch so that it plays the first harmonic on lower notes, and the second harmonic on higher notes, like I figure a real oboe does.
On each, variation 1 is controlled by an envelope generator, and variation 2 by a breath controller.
There's a sound example of these patches here, a little Handel hornpipe written for two oboes and a bassoon.
Unfortunately, these require an expanded G2.
mumsBassoon06.prf2
PM bassoon. var1=envelope, var2=breath control.
 Filename:  mumsBassoon06.prf2
 Filesize:  32.74 KB
 Downloaded:  1795 Time(s)
mumsOboe13.prf2
PM oboe. Quacks on low notes. var1=envelope, var2=breath control.
 Filename:  mumsOboe13.prf2
 Filesize:  33.82 KB
 Downloaded:  1669 Time(s)
Audio files: 316
PostPosted: Sat Mar 18, 2006 9:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wow
Audio files: 316
PostPosted: Sat Mar 18, 2006 9:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ehm, that was a bit short. I mean I can't play the patch .. just listened the mp3 some twenty times, very convincing, it's just in the ambiance that I'd like to try a bit.
Audio files: 235
PostPosted: Sun Mar 19, 2006 1:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
Very imressive. The mp3 is excellent too. Smile
