Doepfer Regelwerk configuration
Page 1 of 1 [2 Posts]
rasputin
PostPosted: Fri Apr 14, 2006 4:16 am    Post subject: Doepfer Regelwerk configuration Reply with quote  Mark this post and the followings unread
Hi you guys!
I got a Regelwerk these days. I want to use it as a controller for vsts in ableton live. Therefore i want to activate an vst effect by pressing one of the 24 buttons and deactivate it by pushing it once again. THE LED SHOULD BE LIT DURING ACTIVATION AND SHOULD BE TURNED OFF WHEN DEACTIVATED. So far, sounds simple.
BUT i only figured out the toggle mode n the momentary mode, which both are not what i am looking for:
in toggle mode, i would need a configuration that deactivates an vst effect when deactivating the midi-events. As it is by now i have to push the button TWICE for activation and TWICE for deactivation;
Button/led ON - effect on, midi on
OFF - effect on, midi off
ON - effect off, midi on
OF - effect on, midi off
Im momentay mode i have to press it only once, but the led is lit only when holding it down. In this mode the effect should be activated only for holding the button down, but it activates/deactivates the effect every time you push, not while holding it down.
PLEASE HELP
THANKX
Thomas Galad
Audio files: 224
PostPosted: Fri Apr 14, 2006 12:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
welcome
I wish I could help you, but I don't have one of these devices.
