W.T.
Joined: Jul 11, 2004 Posts: 272 Location: The Netherlands
G2 patch files: 11
Posted: Sun Jul 02, 2006 11:04 am Post subject:
audiopower depends on cpu load?? |
i use an unexpanded g2 and recently found out that when i use a lot of dsp power in a peformance, lets say i use 3 slots for this, and use a fourth just for audio, a simple stereo flanger perhaps, the audio sounds very thin!
when i only use slot 4 with the audio patch, the sound is a lot thicker!! how does this come? is there also a sort of audio poly / bandwith depending on how much cpu is used? thanks in advance. |
Afro88
Audio files: 12
G2 patch files: 79
Posted: Sun Jul 02, 2006 9:04 pm Post subject:
Could you post the perf and/or wav recordings of the flanger with only 1 slot and 4 slots enabled? |
3phase
G2 patch files: 141
Posted: Mon Jul 03, 2006 12:31 pm Post subject:
you have to look at the voice count of the slots..probably some of your patches get a reduced voice count when you enable a 4th slot and alter theire sound because of that |
W.T.
G2 patch files: 11
Posted: Tue Jul 04, 2006 2:18 am Post subject:
the problem is that it alters the audio path  |
Fozzie
Joined: Jun 04, 2004 Posts: 875 Location: Near Wageningen, the Netherlands
G2 patch files: 49
Posted: Tue Jul 04, 2006 2:32 am Post subject:
W.T. wrote: | the problem is that it alters the audio path  |
Is this internally generated audio routed through slot 4 or external-in audio? If it is the former, 3phase's suggestion might still apply. If it is the latter, well, that would be odd. Short sample for purpose of demonstration? |
sheridan
Joined: Jun 05, 2005 Posts: 473 Location: London, England
Audio files: 27
Posted: Tue Jul 04, 2006 8:03 am Post subject:
I'm guessing it has something to do with polyphony/number of voices too... try using an FX area for your audio ins - you shouldn't hear any difference then (when you add other slots). _________________
Sheridan
Hear music and Nord Modular G2 patches and find out music production tips at
http://www.nitetimeproductions.co.uk |
W.T.
G2 patch files: 11
W.T.
G2 patch files: 11
Posted: Sun Aug 13, 2006 9:23 am Post subject:
it makes me feel like a noob  |
Joined: Apr 03, 2004 Posts: 24432 Location: The Netherlands, Enschede
Audio files: 297
Posted: Sun Aug 13, 2006 11:21 am Post subject:
W.T. wrote: | it is the same single osc sawtooth . |
Assuming you use no envelope after the osc, and that's what the mp3 sounds like :
No ... its not the same single osc but you have 32 of them, all with a different phase and all parellel and summed on the output. And that does two things, it smears out the shape and it will get louder.
In a patch using an envelope before the osc goes to the output it's different, as as you have to press a key first to hear the output. and you can't press the same key 32 times simultaneously.
Hope that helps explain it, but if not please say so. _________________ Jan
W.T.
G2 patch files: 11
Posted: Sun Aug 13, 2006 2:00 pm Post subject:
Blue Hell wrote: | W.T. wrote: | it is the same single osc sawtooth . |
Hope that helps explain it, but if not please say so. |
this explains it really well.
But would this be some kind of bug or is there some logic behind it?
but now i know it doesn't bother me it actually sounds a bit cool
thanks Jan |
Audio files: 297
Posted: Sun Aug 13, 2006 2:10 pm Post subject:
It is not a bug, it is the working mechanism of the voices. Add a voice and the voice area gets duplicated (and so it needs DSP resources to be duplicated as well), but the FX area stays mono. All voice duplicates are automatically mixed in the output modules. _________________ Jan
W.T.
G2 patch files: 11
Posted: Sun Aug 13, 2006 2:32 pm Post subject:
thanks |
