Phase spread
Page 1 of 1 [5 Posts]
monobass
G2 patch files: 12
PostPosted: Tue Jul 18, 2006 6:10 am    Post subject:  Phase spread Reply with quote  Mark this post and the followings unread
I tend to patch things in an unefficient manner so I wonder if there is a more elegant solution for this. It's basically a way of creating a evenly distributed set of values across a specific range.
In the attached patch I have created a system for spreading the phase of 6 LFO's.
Hit a key to sync the LFO's then the mod wheel controls the phase spread: at 0 all the Lfo's are in sync, at maximum they are spread evenly across the full range of phase.
I could have also used this system to control the distribution of panning values.. but I set them manually.
Phase spread.pch2
Evenly distributed LFO phases. Mod wheel to control spread, hit key to sync.
 Filename:  Phase spread.pch2
 Filesize:  2.42 KB
 Downloaded:  1401 Time(s)
Steve
Audio files: 233
PostPosted: Tue Jul 18, 2006 8:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Elegance is in the eye of the beholder. Wink
Sounds interesting when you set the audio oscilators to different waveforms.
monobass
G2 patch files: 12
PostPosted: Tue Jul 18, 2006 10:43 am    Post subject: Reply with quote  Mark this post and the followings unread
very true, I just wish I was better at logic stuff on the nord, but I don't really think in analogue logic instinctively. But I ususally find a solution so I should be thankful.
Steve
Audio files: 233
PostPosted: Tue Jul 18, 2006 11:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Logic is a natural addition to modular synthesis. I think of it mainly in the realm of control signal generation and conditioning, but of course there are always creative ways to use it in unintended ways. I wish the G2 had a little bit better selection of logic modules.
monobass
G2 patch files: 12
PostPosted: Tue Jul 18, 2006 11:40 am    Post subject: Reply with quote  Mark this post and the followings unread
I think in digital, not analogue.. so the nord logic and control fries my brain a bit.
Steve
