 Forum index » Clavia Nord Modular » G2 Patches - Completed » Sequencer - interactive
Chord Memory
Page 1 of 1 [11 Posts]
Dewb
PostPosted: Thu Oct 21, 2004 1:47 am    Post subject: Chord Memory Reply with quote  Mark this post and the followings unread
In the middle of this discussion grimleyj asked about duplicating the chord memory feature of the Korg Karma. I've never used one, but it sounded like a nifty feature -- and an interesting problem -- so I gave it a shot.
Switch between chords with the variation buttons; play a chord on the keyboard to store a new chord in the active variation. For each chord you can also use the panel knobs to control the velocity and the delay between the previous chord ending and the next starting.
The chords are sent to the patch in Slot B. Before sending a chord, it sends an "all notes off" message (MIDI CC# 123) to Slot B, so you won't mix chords if Slot B is set to more than 3 voices.
Chords are assumed to be three notes. You could easily extend this to 4+ notes by bumping up the voice count and adding more note sequencer / midi note send pairs, but then all your chords would have to be 4+ notes. If you play fewer notes, then one of the notes from the previous chord will be kept. I am trying to figure out how to get around this, but no luck so far.
This patch only uses the first step in each note sequencer, which is sort of a waste. Clavia needs to add a sequencer that has a record feature like the SeqNote and is addressable like the SeqCtrl. Then you'd basically have a RAM module, which would allow you to cause all kinds of trouble.
KarmaChordMem.pch2
 Filename:  KarmaChordMem.pch2
 Filesize:  2.41 KB
 Downloaded:  1873 Time(s)
Wan
G2 patch files: 46
PostPosted: Thu Oct 21, 2004 2:04 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey Grimley and Dewb,
It grabbed my attention too, so i've made another solution in parallel.
It's not so feature rich as your solution, but i guess that can be added too.
However, press button a1.1 while holding a chord to capture it, press button a1.2 to play it back.
It uses a s/h module to capture the keyboard cv and a couple of crossfaders to distinguish between directly played and captured cv and gates. So it is a rather dsp cheap solution
Chord capture.pch2
Example of chord capture using a s/h module
 Filename:  Chord capture.pch2
 Filesize:  1.85 KB
 Downloaded:  2053 Time(s)
Grtz Wan
Wan
G2 patch files: 46
PostPosted: Thu Oct 21, 2004 2:28 am    Post subject: Reply with quote  Mark this post and the followings unread
A reply to my own post!
Took the patch a bit further, cause i wanted to try to implement the chord memory feature i remembered from my korg polysix (long time gone).
And i did kind of succeeded.
Press button a1.1 while holding a chord to capture it
Check with button a1.2 - it should play back
Press button a1.3 to activate keyboard controlled playback. Now that's the polysix isn't it Very Happy
Polysix Chordmem.pch2
Chordmemory function as on the korg polysix.
 Filename:  Polysix Chordmem.pch2
 Filesize:  2.13 KB
 Downloaded:  1898 Time(s)
Grtz Wan
General Elektrick
PostPosted: Thu Oct 21, 2004 10:20 am    Post subject: Reply with quote  Mark this post and the followings unread
It is !
I was a little jealous for this feature, my friend has a polysix, now I am
no more Very Happy Very Happy Very Happy
grimley
G2 patch files: 9
PostPosted: Thu Oct 21, 2004 2:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Dewb, Wan,
Thanks a million guys ... this is brilliant!!
Can't wait to get home to check out your patches.
On the Karma, you use the same buttons to capture the chords as you do to play them. There is a "shift" button that you hold to record. I wonder if it is possible to press 2 buttons at once on the G2, with one toggling record.
Anyway, thanks again.
-grimley
modular
G2 patch files: 72
PostPosted: Thu Oct 21, 2004 3:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh this is really clever Wan
Clavia,please, print this in next G2 Tutorial/Manual release!
Audio files: 224
PostPosted: Thu Oct 21, 2004 6:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
thumb up Cool Laughing
grimley
G2 patch files: 9
PostPosted: Sun Oct 24, 2004 11:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wan,
I made another attempt using your method of the S&H module. This uses the sustain pedal to capture the chord, and outputs the notes on midi channel 1.
My probelm now is that if the chord contains less notes than the polyphony count of the patch then wrong notes are included in the chord.
I can't think of a good way to prevent the midi note send module from sending more notes than the chord contains.
Anyone?
ChordMem.pch2
Variation on the chord memory S&H patch
 Filename:  ChordMem.pch2
 Filesize:  2.29 KB
Wan
G2 patch files: 46
PostPosted: Tue Oct 26, 2004 1:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
grimleyj wrote:
Wan,
Anyone?
Okay, I've expanded my original patch. There is now a second s/h module that captures the gate from the keyboard. So only the gates from the active voices are being captured and replayed, making the behaviour as you wish Smile
I've set the voicecount on 24 (expanded machine). Should reach 12 on an unexpanded machine
So now you can choose how many voices are captured by playing the requested number of keys.
ChordMem PrKeys.pch2
 Filename:  ChordMem PrKeys.pch2
 Filesize:  2.16 KB
 Downloaded:  1913 Time(s)
Grtz Wan
grimley
G2 patch files: 9
PostPosted: Tue Oct 26, 2004 2:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wan, you're a star!
.. and I'm learning a lot from your patches, thanks!
-grimley
Wan
G2 patch files: 46
PostPosted: Mon Dec 27, 2004 9:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello all,
revisited my own original patch and noodled along with it, then discovered a rather nasty bug. When you increase the release time of the envelopes the pitches jump back to their original pitch on key release, thereby destroying the effect of the chord memory.
So i dove in and debugged it, and put some other features in as well.
Like a note scaler, so that the chord memory can be scaled to a ... scale (look on the B pages), and portamento, and velocity response, and... well you get the picture.
3 variations are filled.
Chord memory syn.pch2
 Filename:  Chord memory syn.pch2
 Filesize:  3.84 KB
 Downloaded:  1901 Time(s)
Grtz Wan
