X-Electric
Joined: Jul 11, 2005 Posts: 182 Location: Warsaw, Poland
Posted: Fri Jul 13, 2007 6:14 pm Post subject:
Korg Mini Pops 7 emulation (Oxygene 6 rhythm combo) |
Oxygene 6 is one of my favourites from JMJ at all, and I always loved the MP7 rhythm combo (Slow Rock + Beguine) as heard on this track. I own a MP120, which also allows multiple button triggering, so mix of some preset rhythms is possible, but it lacks 3 most significant sounds: quijada, guiro and tambourine, which made the Oxygene beat so popular and recognizable. I decided to create an emulation on NM, because I couldn't find any decent one in the archives. I couldn't come up with cheap quijada and guiro enough to fit in one DSP with whole patch, so I checked the archives and found a decent solution in a patch which was signed on modules as "CdSP 2000". I tuned the solution to fit the DSP usage limit and to match the original sound, and it works great - just below the limit.
I'm attaching an audio sample from original Mini Pops 7, NM emulated one, and an emulated rhythm in a mix [edit: attachments are in reversed order], where most of the differencies between the original and emulated one aren't that hearable. There are plenty of mistakes in the emulation, I know, but it's the best I could come up with this setup, and one DSP only (not to mention free time ). The Oxygene 6 arrangement also sucks, but it was not the point. I just wanted to show that this rhythm fits nicely in the mix, and all these little differencies aren't that recognizable at all, especially to a regular listener.
Description: |
Filesize: |
258.12 KB |
Viewed: |
7785 Time(s) |
Description: |
Short and simple arrangement of Oxygene 6 with NM emulated rhyhtm part. |
Download |
Filename: |
XL_oxy6.mp3 |
Filesize: |
594.69 KB |
Downloaded: |
1070 Time(s) |
Description: |
Nord Modular version of the Oxygene 6 rhythm combo. |
Download |
Filename: |
NM_MP7_01.mp3 |
Filesize: |
133.47 KB |
Downloaded: |
1006 Time(s) |
Description: |
Original Mini Pops 7 'Slow Rock' + 'Beguine' rhythm combo. |
Download |
Filename: |
MP7_orig.mp3 |
Filesize: |
133.47 KB |
Downloaded: |
1041 Time(s) |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Sat Jul 14, 2007 12:30 am Post subject:
It all sounds good, but why don't you attach the patch itself too?
Wout |
X-Electric
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Sat Jul 14, 2007 5:53 am Post subject:
X-Electric wrote: | Ooops, my bad |
There's always somebody to remind you
Wout |
Joined: Apr 01, 2004 Posts: 2670 Location: Auckland, New Zealand
G2 patch files: 626
Posted: Sat Jul 14, 2007 11:27 am Post subject:
Very nice work. It even converts to G2 if you cancel the final bit quant module.
Cheers |
X-Electric
Posted: Sat Jul 14, 2007 12:22 pm Post subject:
g2ian wrote: | Very nice work. It even converts to G2 if you cancel the final bit quant module.
Cheers |
Thanks The bit quantizer is useless most of the time, I just put it there, as well as audio in and a morph group on plenty of parameters just to experiment when jamming - it's a bit boring to play to one and same sounding rhythm over and over...
I just wish the DSP wouldn't run out of juice that quickly - I was thinking about a fill-in trigerred by a quick mod wheel pulse or sth but maybe it's time to buy a G2... |
delay19ms
Posted: Sun Jul 15, 2007 7:43 pm Post subject:
X-Electric wrote: | I just wish the DSP wouldn't run out of juice that quickly - I was thinking about a fill-in trigerred by a quick mod wheel pulse or sth but maybe it's time to buy a G2... |
maybe you could replace some of your osc by lfo, lower res but could still sound ok, and it would give you dsp space... |
X-Electric
Posted: Mon Jul 16, 2007 4:55 am Post subject:
delay19ms wrote: | maybe you could replace some of your osc by lfo, lower res but could still sound ok, and it would give you dsp space... |
Already did it where it was possible - mostly the sound wasn't distorted on instruments like bongo or so, where the base frequency is <1000 Hz. (Though the LFO being a control signal is suppose to go up to 11 kHz.) |
