Joined: Apr 03, 2004 Posts: 24547 Location: The Netherlands, Enschede
Audio files: 301
Posted: Fri Feb 06, 2009 5:10 pm Post subject:
| doctorno wrote: | | Blue Hell wrote: | | an 1.60 patch |
This sounds great! I love it! |
I'm still wrestling with that one BTW ... currently at version 20 ... I can't get it "right" ... maybe I should have stopped at version 8  _________________ Jan
Jason
Joined: Aug 12, 2004 Posts: 466 Location: Los Angeles, CA. USA
Posted: Fri Feb 06, 2009 5:44 pm Post subject:
Thank you Clavia  |
sopheapsem
Joined: Apr 26, 2007 Posts: 7 Location: San Francisco
Posted: Sat Feb 07, 2009 2:49 pm Post subject:
Am I the only one in which this 1.6.2 didn't fix the Editor disconnect issue? Curious, because I also experience this same bug in 1.4 as well--consistently.
To clarify, in 1.6.2, same for me as 1.6.0, same for me as 1.4, I can connect my G2 via USB, open the editor and the hard/soft connection is made and I can build/tweak, etc. If I quit the editor & then restart the editor--I can't get the software to recognize the hardware until I either power-cycle the G2 or disconnect the USB cable and re-connect it. This has been the case ever since I first got the G2 (only about 14 months ago), and so seeing it in 1.6.0 didn't surprise me, and I was more surprised to hear people noticing it for the first time. But the problem is definitely NOT fixed on my system in 1.6.2, so I am now fully curious what is up? anyone else with the same system as me experiencing same/different?
Macbook Pro (2.33 Intel Core 2 Duo) OS 10.5.6 / G2 Keyboard (expanded) updated to 1.6.2
jake |
BigShort
Posted: Mon Feb 09, 2009 8:48 am Post subject:
| sopheapsem wrote: | Am I the only one in which this 1.6.2 didn't fix the Editor disconnect issue? Curious, because I also experience this same bug in 1.4 as well--consistently.
jake |
same here on my macbook and a G2X |
Joined: Jan 31, 2003 Posts: 18272 Location: Durham, NC
Audio files: 232
Posted: Wed Feb 11, 2009 3:46 pm Post subject:
sopheapsem and BigShort
Only a sample of two, but it sure looks like there is still a bit of a problem with the OSX midi driver.  _________________ --Howard
my music and other stuff |
BigShort
Posted: Sat Feb 14, 2009 3:15 am Post subject:
hi mosc,
thx for your warm welcome
and hello to all members from a longtime lurker with huge respect
to all and their fantastic work with a big thx too!
greetz BS |
manu81
Joined: Oct 26, 2008 Posts: 1 Location: Planet Gradius
Posted: Sun Feb 15, 2009 6:42 am Post subject:
Add another thank you to Clavia from me. I'm a bit late, but still, thank you very much Clavia!  |
dorremifasol
Joined: Sep 28, 2006 Posts: 823 Location: Barcelona, Spain
G2 patch files: 49
Posted: Sun Feb 15, 2009 8:13 am Post subject:
Hey manu81, , nice to see you here!
 _________________ Cheers,
Albert |
zynthetix
Audio files: 10
G2 patch files: 13
Posted: Mon Feb 16, 2009 2:59 pm Post subject:
jake |
I just tested this and I am NOT having the same problem. Let's re-trace my steps:
1) Turn on G2
2) Start editor software
3) Created a new performance, added some oscillators that are connected to main left output of the out module. Sound is coming out of left speaker.
4) Quit the editor. Sound is still coming out of left speaker.
5) Started the editor software again. Patch loaded up. Connected the oscillators to the main right output of the out module. Sound is now coming out of both speakers.
Is this test sufficient? What does it do on your set-up?
I am using a black macbook (e.g. the 'blackbook') with the latest motherboard for that model ( 2.2 ghz processor and 800 mhz frontside bus, 667 for RAM). This was the last version of the model that they made before the new, all aluminum line of macbooks. My G2 is probably from one of the first runs, it is several years old. I'm thinking the macbook model itself might be at the heart of the issue for some reason. Last edited by zynthetix on Tue Feb 17, 2009 9:15 pm; edited 1 time in total |
gomidas
Joined: Jul 09, 2004 Posts: 365 Location: La Ciotat, France
G2 patch files: 6
Posted: Tue Feb 17, 2009 5:11 am Post subject:
THE WAIT IS OVER!!!! AFTER MUCH FRUSTRATION!!!!  |
tristanshout
Joined: May 20, 2005 Posts: 4 Location: half moon bay, ca
Posted: Sun Feb 22, 2009 3:13 pm Post subject:
1.62 hangs more frequently for me than 1.4 did. dual G5 mac, running OS 10.4.11.
Today it hung while storing a performance in G2 memory, which I've never seen before. Had to power cycle. The performance that it was storing got lost. |
peterkadar
Joined: Jan 11, 2009 Posts: 152 Location: Toronto, Canada
Posted: Sun Feb 22, 2009 4:02 pm Post subject:
Man,
I'm just gonna roll with 1.40 for now. I picked up an old Mac Mini with a Power PC chip. At least I'll have reliabe back up plans if and when my PC and laptop bite the dust... |
tristanshout
Posted: Sun Feb 22, 2009 5:29 pm Post subject:
| i'm inclined to revert to 1.40 if I keep experiencing trouble. is it just as easy as running the 1.40 firmware update app? |
ark
G2 patch files: 31
Posted: Mon Feb 23, 2009 7:23 am Post subject:
No it isn't, because if you're running the 1.60 driver, the 1.40 update program will not recognize the G2.
At least on Windows, what you have to do is go into Device Manager, right-click the driver (which you must do with the G2 connected, because otherwise the driver won't be visible in Device Manager), say you want to update it, then supply the 1.40 driver as the "update".
Once you've done that, the 1.40 driver will recognize the G2 even though it won't be able to talk to it. At that point, you can run the 1.40 update program and it will replace the system software in the G2 even though it is replacing it by an earlier version.
So it's not a particularly difficult process; but you have to do things in an order that may seem counterintuitive. |
tristanshout
Posted: Mon Feb 23, 2009 8:51 am Post subject:
| I don't think the mac version has any custom drivers. There's just the firmware update app and the editor app. |
Audio files: 232
Posted: Mon Feb 23, 2009 12:30 pm Post subject:
| ark wrote: | | So it's not a particularly difficult process; but you have to do things in an order that may seem counterintuitive. |
It may be easy to do, but you deserve applause for figuring it out.
Oli
Joined: May 21, 2008 Posts: 250 Location: i think before i ambient
Posted: Fri Feb 27, 2009 5:53 am Post subject:
| mosc wrote: | | It may be easy to do, but you deserve applause for figuring it out. |
Yeah, nice work around, swapping the drivers. You are referring to the USB drivers, yeah? _________________ Good good study, day day up! |
ark
G2 patch files: 31
Posted: Fri Feb 27, 2009 8:37 am Post subject:
| Oli wrote: | | Yeah, nice work around, swapping the drivers. You are referring to the USB drivers, yeah? |
Yes -- those are the only drivers that Nord provides. |
gomidas
G2 patch files: 6
Posted: Wed Apr 01, 2009 2:45 am Post subject:
G2 OS 1.62 disconnection problem here also(MAC & PC),... went back to Synth OS 1.40 with G2 Editor 1.62(intel), seems ok for the moment  |
boxcolony
Posted: Wed Apr 01, 2009 4:52 am Post subject:
Aside from the disconnection problem, It seems that some patches get corrupted after the disconnetion.
Anybody got the same problem? |
gomidas
G2 patch files: 6
Posted: Wed Apr 01, 2009 5:34 am Post subject:
| boxcolony wrote: | Aside from the disconnection problem, It seems that some patches get corrupted after the disconnetion.
YES!  |
iPassenger
Joined: Jan 27, 2007 Posts: 1070 Location: Sheffield, UK
G2 patch files: 78
Posted: Wed Apr 01, 2009 7:23 am Post subject:
Much to my suprise I got some a couple of the dreaded lost connection errors at the weekend (having not had any since I first got my Nord) but I had recently attached my Nord to my very recently acquired USB hub rather than direct to my PC, so I switched it back to getting a direct line from the PC and have had no more errors since.
Not sure how relevant this is, just thought I would mention it. I have heard that some devices just don't get on with all external hubs and mine is a cheapy and others are quite happy. E.g. To date my iPhone has not had a problem with the external hub. _________________ iP (Ross)
ark
G2 patch files: 31
Posted: Wed Apr 01, 2009 8:30 pm Post subject:
| iPassenger wrote: | | Much to my suprise I got some a couple of the dreaded lost connection errors at the weekend (having not had any since I first got my Nord) but I had recently attached my Nord to my very recently acquired USB hub rather than direct to my PC, so I switched it back to getting a direct line from the PC and have had no more errors since. |
Interesting.
I've been running my G2 on a hub since I got it, and never had any problems until I installed 1.62, at which point I started getting occasional problems. Going back to 1.40 made the problems go away.
So I suppose it's possible that 1.62 is more sensitive to hub issues (timing?) than 1.40. |
purusha
Posted: Thu Apr 02, 2009 3:30 am Post subject:
Hmmm. So, out of interest, which OS are you guys with problems using?
1.62 has been fine for me so far on Vista, hub or no hub. _________________ OVNI Soundcloud Purusha Soundcloud |
iPassenger
G2 patch files: 78
Posted: Thu Apr 02, 2009 5:37 am Post subject:
| purusha wrote: | Hmmm. So, out of interest, which OS are you guys with problems using?
1.62 has been fine for me so far on Vista, hub or no hub. |
I'm on 1.62 and only experienced the issue after quite heavy patching (presumably it is pretty intermittent), a good few hours in. However once it crashed, it did so quite soon afterwards, so I removed it from the hub and have not experienced a crash since.
That's not's to say it wont mnd.
My USB Wifi dongle wasn't keen on the hub either but as I mentioned my card reader and iphone are quite happy with it to date.
If you ask me this USB lark is pretty wonky. My iphone and ipod hate the port on the front of my pc (crashes regularly during data transfer) but my wifi dongle couldn't be happier. It could just be a snugness (!!!new word alert!!!) of plug to socket issue. _________________ iP (Ross)
