PCBs for Dave Kendalls MIDI2Clock Motherboard
Page 1 of 5 [122 Posts]
Goto page: 1, 2, 3, 4, 5 Next
PostPosted: Tue Jun 07, 2011 3:03 am    Post subject: PCBs for Dave Kendalls MIDI2Clock Motherboard
Subject description: pre-order cutoff on 4th of July
Dave Kendall recently told us about a circuit he designed, converting MIDI 2 Clock:
http://electro-music.com/forum/topic-47703.html
check out this thread.
some of indicated interest in professional made PCBs for this project. dave and me would do a PCB run if there would be interest in at least 30pcs.
the highlights of this project:
- MIDI input, and outputs 24PPQN CLOCKS, START, CONTINUE and STOP pulses.
- onboard 2-stage divider network with GATE and TRIGGER outputs (for different time signatures, pulse divisions and pulse widths)
- using just a rotary switch and 8 SPST changeover toggle switches (no menus or LCDs, or any of that malarkey)
- operating from 1 BPM to 250 BPM, and will track tempo changes smoothly.
- LED indicators for the various outputs, and a MIDI receive LED
- pin-header on the PCB that carries decoded MIDI as CMOS-compatible 8-bit parallel +5V logic, along with other useful internal circuit signals
- other pin-headers on the board allow for expansion to further circuits, eg, more divider stages, or remotely controlling the action of the switches.
- pin headers too for the transmit section of the main processor (CV to MIDI)
- no programmable ICs used, and no calibration is needed
The PCB is quite large (5.4 3.3 in), the price would be 12.-EUR/17.-USD (depending on exchange rate and order quantities).
I could do bundles with the UART, if needed.
Building Documentation now uploaded:
M2C Documentation PDF(approx. 2MB)
that's how the board will look like:
M2C board
i hope to do a video demo together with the klee2, cubase and or ableton on weekend (given that the new camcorder comes in time).
wmonk
Audio files: 15
PostPosted: Tue Jun 07, 2011 3:28 am    Post subject: Reply with quote  Mark this post and the followings unread
I am in! Very Happy
Cool project Matthias and Dave!
Weblog!
bubzy
Audio files: 64
PostPosted: Tue Jun 07, 2011 3:45 am    Post subject:   Reply with quote  Mark this post and the followings unread
mememememememememe!
-thats a +1 btw Smile
-oh, and a UART Very Happy
keninverse
PostPosted: Tue Jun 07, 2011 4:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Most definitely will be in on a board!
arrmcbain
PostPosted: Tue Jun 07, 2011 5:14 am    Post subject: Reply with quote  Mark this post and the followings unread
One for me please! :tu:
magman
PostPosted: Tue Jun 07, 2011 5:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Ah good, another Fonitronik fix (with able support from Mr Kendall).
You can put me down for at least one (possibly more, if you need to reach a threshold).
Regards
Magman
Dego
PostPosted: Tue Jun 07, 2011 5:55 am    Post subject: Reply with quote  Mark this post and the followings unread
1 please + UART
rosch
yup, 2 for me please
PostPosted: Tue Jun 07, 2011 6:33 am    Post subject: Reply with quote  Mark this post and the followings unread
2 for me. Thanks!
What is the UART?
Dave Kendall
PostPosted: Tue Jun 07, 2011 7:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi guys.
Thanks for the interest Smile
The UART is a CMOS 3-state serial to parallel interface, that with extra logic ICs and other components, turns the MIDI serial data into parallel data. The old name for it is the IM6402IPL, and the newer version (made by Intersil) is the HD3-6402R-9Z. According to the intersil website, it's still being made. Both work, and the slower 2mHz version of either type works fine.
As far as the rest of the project data goes, I'll knock up a BOM and build notes when I get the time (very busy this week....). The schematic will be released after we've double-checked it with the boards, when we get them.
cheers!
"Everything in moderation, including moderation"
PostPosted: Tue Jun 07, 2011 8:39 am    Post subject: Reply with quote  Mark this post and the followings unread
If the UART is needed for this then I'd be interested in getting it bundled with the PCB. It saves me having to hunt it down and paying for shipping twice.
loydb
PostPosted: Tue Jun 07, 2011 8:40 am    Post subject: Reply with quote  Mark this post and the followings unread
I'd for sure take a PCB, and I'd echo the request for a bundled UART if possible.
PostPosted: Tue Jun 07, 2011 10:13 am    Post subject: Reply with quote  Mark this post and the followings unread
i think, if this all happens, i will just order as much UARTS as desired. no problem at all.
raoulblues
PostPosted: Tue Jun 07, 2011 10:43 am    Post subject: Reply with quote  Mark this post and the followings unread
One for me please! +uart merci
rosch
PostPosted: Tue Jun 07, 2011 12:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
cool, please count me in for 2 UARTs, too
brother303
PostPosted: Tue Jun 07, 2011 2:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Matt,hi Dave,
yeees,way cool!
I´m in for a board and one chip.
Wink
Best regards
Greg
Danno Gee Ray
PostPosted: Tue Jun 07, 2011 2:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'll take 1 PCB + UART please.
diablojoy
PostPosted: Tue Jun 07, 2011 4:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
I will take minimum 2 also with the uart option thanks matthias.
let me know if you fall short on numbers i can possibly increase my order also
LektroiD
PostPosted: Tue Jun 07, 2011 7:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
count me in for 1
Thanks Matthias for another awesome project
LektroiD
tommi
PostPosted: Thu Jun 09, 2011 1:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello, I'll be in for 1 PCB+UART. Thanks Matthias!
http://soundcloud.com/mister-vommi
http://tideofsound.net
tomcat
PostPosted: Fri Jun 10, 2011 3:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
3 + uarts Smile
UPDATE: 4 + uarts
marvkaye
PostPosted: Fri Jun 10, 2011 4:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
2 plus UARTs for me as well. Another way cool project to add to the pile. Thanks for pulling this together.
_________
<marv>
Level5
PostPosted: Sat Jun 11, 2011 10:14 am    Post subject: Reply with quote  Mark this post and the followings unread
2 + UARTs
tazer
PostPosted: Sun Jun 12, 2011 4:32 am    Post subject: Reply with quote  Mark this post and the followings unread
2 boards and 2 chips please
jojjelito
PostPosted: Sun Jun 12, 2011 6:28 am    Post subject: Reply with quote  Mark this post and the followings unread
l'm in for one PCB plus UART chip please.
