Joined: Mar 11, 2014 Posts: 746 Location: New Zealand
Posted: Sat May 16, 2015 4:31 am Post subject:
That looks really cool How stable is it when someone hits one of the panels? |
nicolas3141
Joined: May 25, 2007 Posts: 185 Location: Christchurch, New Zealand
Posted: Sat May 16, 2015 4:40 am Post subject:
I have an exhibition up at a local gallery at the moment, four interactive sculptural sound works http://auricle.org.nz/
To a certain extent they play themselves based on lots of LFOs and to a certain extent they are playable by touching the contact plates to make additional connections and modulate those connections with skin resistance. In the exhibit, that one is made more stable by being attached to a wooden plinth.
Nicolas |
Joined: Apr 03, 2004 Posts: 24433 Location: The Netherlands, Enschede
Audio files: 297
Posted: Sat May 16, 2015 5:11 am Post subject:
nicolas3141 wrote: | Ihttp://auricle.org.nz/ |
Looks like fun! _________________ Jan
Posted: Sat May 16, 2015 1:31 pm Post subject:
Christchurch... too far for me to get to, I'm afraid! |
JL
Posted: Tue Jun 02, 2015 11:32 am Post subject:
4 input mixer into a VCA. The VCA section is the Yusynth simple VCA with a few cut corners and kludges.
EFM 3529 Lowpass/Bandpass VCF. Sounds good, but overdrives a little too easily and has a lot of hiss. Had to tweak a few things to make the clipping more symmetrical (improved headroom too) and lower the cutoff freq a bit.
Dan Lavin
Audio files: 21
richardc64
Audio files: 26
Posted: Fri Jun 05, 2015 5:22 am Post subject:
Nice work, Dan. I like the surfboard power switch. Nice graphics overall. _________________ Revenge is a dish best served with a fork... to the eye |
donpachi
Posted: Fri Jun 05, 2015 7:24 am Post subject:
Dan, that surf amp is outstanding!
And I also fancy your panels, JL --- have done quite some Dymo and hammer-on builds too, first as a makeshift, then out of habit, then grew into liking them a lot
Oh, and the readability of hammer-on letters can be improved by applying "lacquer stik" wax or similar, a trick I learned from fonik. |
Broadwave
Joined: Feb 16, 2007 Posts: 347 Location: Manchester UK
Audio files: 6
Posted: Wed Jun 10, 2015 9:54 pm Post subject:
PHOBoS wrote: | AndyR1960 wrote: | ..Electric Stereo Hammered Dulcimer...
It's beautiful but what are those rings for, is that where the piezos are located ? |
Thanks PHOBoS, the rings are just decoration around the sound holes. There's 6 internal peizos, 3 to the left of the treble bridge and 3 to the right of the bass.
I'm not entirely happy with the output though, so I still tend to mic it up. _________________ Kronos 2-88, Kronos 61, Studiologic Sledge V2/SL, Broadwave ARP 2600EX, Broadwave 18U ARP based Eurorack Modular, Broadwave Minimoog Clone, GEM S2 Turbo.
Synth DIY Projects
Musical Doodlings |
Broadwave
Audio files: 6
Posted: Wed Jun 10, 2015 10:44 pm Post subject:
This could well be my last project...
Although I've amassed a decent collection of soft synths over the past 10 years or so, I've never been happy with the way you have to integrate with them (pushing sliders/knobs/switches etc with a mouse, or worse still trying to remember what knob on your controller changes whatever parameter!)
I always liked the idea of the Open Labs Neko, but it was just too expensive. So, for £330, I've built something that has changed the way my studio now works.
It's just a basic 1U Mini ITX PC (all parts off ebay £60), 120Gb SSD (£36 Amazon), HP 23TM Touch screen Monitor (£149 Debenhams UK), Alesis V61 (£85 ebay)
Everything else, 30Gb Boot SDD, M-Audio 1814FW, Fostex VC-8 ADAT expander, MIDI Interface and Patch bay, were rescued from the attic.
It's all built into a pretty hideous Tolex covered box, but it all does what I hoped it would.
I'm running Image Line's Minihost Modular as the main interface, all the physical ADAT I/Os appear on screen as Yellow tabs, which means I can route external hardware through VST FX simply via drag and drop, and of course I can run plenty of Soft synths and route them to any ADAT output for recording into Logic.
The large touch screen is the key to it all working smoothly. Editing softsynths is now far faster and more enjoyable than scrabbling around with a mouse
Synth DIY Projects
Musical Doodlings |
jksuperstar
G2 patch files: 18
Posted: Thu Jun 11, 2015 10:56 am Post subject:
Great work Andy! I am in the process of doing something very similar (using a miniITX PC, Sonic-Core XITE, Touch Screen, iPad, and some controllers (launchpad, QuNexus, and Arturia SparkLE).
Same inspiration to have it all prewired and ready to go. with no mouse fiddling. I'll post pics when I'm done... |
Dan Lavin
Audio files: 21
Posted: Fri Jun 12, 2015 3:16 pm Post subject:
Roland AX-7 restoration |
I just finished restoring a Roland AX-7 I got for cheap off ebay this winter. It was cheap because the body was duct-taped together, the previous owner actually abused it to the point of the internal standoffs breaking off. Hmmm imagine a rock performer abusing a piece of musical equipment!
Anyway, I took the opportunity to get rid of the boring all white finish that came with the factory model.
Description: |
Filesize: |
482.69 KB |
Viewed: |
275 Time(s) |
Description: |
Filesize: |
1.14 MB |
Viewed: |
273 Time(s) |
_________________ Synth DIY since 1977! |
kanji
isak
Posted: Sat Jun 13, 2015 9:18 am Post subject:
Re: Jupiter Clone Subject description: 4 Voice Jupiter clone |
kanji wrote: | Here's something I've been working on at these last couple months.
It's a four voice JP clone build using original Jupiter 8 schematics.
Each four voices have two VCO's per voice as in original.
Modules build so far are :
8 x VCO cards each with Saw, Square and PWM waveforms.
Each sound card has 4052 multiplexer as on output controller as in original so each voices waveform can be assigned digitally.
4 x 4-Pole "Roland" OTA Filters. Made pretty much same way as 80017A filter clones.
2 x VCADSR cards that control ENV1 and ENV2 envelope generators.
+ LFO card, PWM control section and various Modulation Control "cards" that control and mixes various modulations to each filter and voices.
Here is couple videos from the clone so far :
https://www.youtube.com/watch?v=1fX8TPMrIbY
https://www.youtube.com/watch?v=x9K_TSB4fHM |
AMAZING  _________________ http://www.myspace.com/mgmtrance |
DES
Posted: Sun Jun 14, 2015 7:25 am Post subject:
kanji - Wow that is nice! You made the case as well?
AndyR196 - What a great job! So are you finding the touch screen to work well with plugins? I've been thinking about using a touch screen in my rig but most people I've bounced the idea off of have sounded quite skeptical saying that the VSTs needed to be optimized for touch screen. Perhaps for multi- touch? _________________ Dave
www.davesneed.com |
kanji
Posted: Tue Jun 16, 2015 4:43 am Post subject:
Thank you for the comments.
I did the casing and panel as well. Casing is not 100% ready yet.
I still need small panel for pitch bend/modulation control section and this synth is going to get aluminum ends, like the ones in real jupiter 6/8  |
Broadwave
Audio files: 6
Posted: Tue Jun 16, 2015 10:53 am Post subject:
DES wrote: |
AndyR196 - What a great job! So are you finding the touch screen to work well with plugins? I've been thinking about using a touch screen in my rig but most people I've bounced the idea off of have sounded quite skeptical saying that the VSTs needed to be optimized for touch screen. Perhaps for multi- touch? |
It all works very well, as long as you keep the screen resolution down (so the VST GUI fills the screen). I've not missed the lack of multi-touch... after all, even playing a hardware synth, I can only rotate one knob at a time if my left hand is busy with the keys  _________________ Kronos 2-88, Kronos 61, Studiologic Sledge V2/SL, Broadwave ARP 2600EX, Broadwave 18U ARP based Eurorack Modular, Broadwave Minimoog Clone, GEM S2 Turbo.
Synth DIY Projects
Musical Doodlings |
vladosh
Audio files: 51
Posted: Tue Jun 16, 2015 11:32 pm Post subject:
Mini Modular in a salvaged box from an old factory equipment , it has: MFOS VCO ,Serge VCS , Serge Negative Slew ,Polivoks VCF , Parametric Moog Eq ,Buchla 208 Random , NLC Analog Neuron ,NLC Chaos Jerk ,NLC Difference Rectifier , VCA ,Yusynth Quadrature VC-LFO ,CGS Grinder ,E4M Xmix , Morphlag Envelope/Lag ,Clock Divider ,Yusynth Noise ,it takes a while to finish it if you start building two at the same time
Description: |
Filesize: |
51.61 KB |
Viewed: |
328 Time(s) |
_________________ http://synthacks.blogspot.com/ шематикс |
richardc64
Audio files: 26
Posted: Wed Jun 17, 2015 9:02 am Post subject:
This both saddened and angered me...
AndyR1960 wrote: | This could well be my last project... |
until I saw the pictures. Well done!
Yeah, you won't ever have to build anything again, but you might still want to.
Spiffy restoration, Dan. Love the color, and especially the labeling.
kanji wrote: | I did the casing and panel as well. Casing is not 100% ready yet. |
Looks incredible so far!
vladosh wrote: | Mini Modular in a salvaged box from an old factory equipment |
I love recycled/re-purposed cases. _________________ Revenge is a dish best served with a fork... to the eye |
helge-h
Posted: Tue Jul 14, 2015 12:18 pm Post subject:
Just finished my first rack, all my own design, although some are text-book circuits. One-and-a-half years in the making.
The measurements are non-standard: 16 cm hight and a multiple of 4 cm width for each module.
The modules:
Top row:
- 12 step sequencer with lots of functions
- dual LFO for clocks; counter (2-4-8-16); noise source, sample-and-hold and portamento in one module
- quad 4-input mixer
- dual envelope generator; ADSR
- dual envelope generator (attack-decay) and dual VCA
- VCO
- ring modulator; waveshaper
- digital signal processing module with many options; for example delay
Bottom row:
- power supply
- MIDI to CV (and USB input, but not finished)
- dual LFO
- buffers, multiples, triple mixer and audio output
- quad VCA
- VCO
- sub oscillator connected to the VCO
- dual state variable filter, with vactrols
It's an analog synth, but internally many of the modules have digital circuitry and microcontrollers.
I may present some of the modules in more detail later.
… and I also made a MIDI keyboard.
I have found lots of inspiration on this forum, so much good stuff being made.
Helge
Description: |
Filesize: |
498.4 KB |
Viewed: |
492 Time(s) |
Description: |
Filesize: |
284.38 KB |
Viewed: |
230 Time(s) |
Audio files: 297
Posted: Tue Jul 14, 2015 1:45 pm Post subject:
helge-h wrote: | Just finished my first rack |
Looks like a fun box! _________________ Jan
helge-h
Posted: Tue Jul 14, 2015 2:45 pm Post subject:
Blue Hell wrote: | helge-h wrote: | Just finished my first rack |
Looks like a fun box! |
Thanks.
It is. I had a lot of fun making it, anyway.
I can't play any instrument, but I like to experiment with all sorts of patches and make noises. I feel it sort of opens a new part of reality.
Helge |
Gman
Posted: Sat Jul 18, 2015 8:58 am Post subject:
Hey guys! I'm new to the forum, but have visited it many times in the past few months on my quest to build my first modular system. I wanted to show off my system now that I have finally finished it! All the circuits were hand soldered on perf board and I used a label maker for the panels and 3D printed the knobs (Knobs are surprisingly expensive!). The filter doesn't have labels unfortunately because I used the label maker at my High School but I just graduated and don't have access to it anymore. I'm now working on my 2nd modular system which is a bit more ambitious because the cabinet is 4ft wide and inspired by the Moog system 35!
I built 9 modules consisting of:
-VCO-1
-VCO-555
-1 low-pass filter
-2 YuSynth VCAs
-1 LFO
-2 Thomas Henry ARs
-1 Yusynth mixer
Shock_Hazard
Posted: Sat Jul 18, 2015 10:14 pm Post subject:
Forgive me if I'm missing something but, what's the point of this thread? Isn't the whole DIY section basically a "post photos of your builds" topic? It seems totally arbitrary.
Some great stuff (like the fantastic synth in the previous post) seems to be getting lost in these annual threads, it deprives the forum of new threads and subsequent discussion by confining things to one thread. |
-minus-
Posted: Sun Jul 19, 2015 3:32 am Post subject:
I don't mind these 'show us what you've built' threads. I'm hoping it shames me into getting my arse into gear and stop procrastinating. As a general look at what is being made by members, I think it works fine. A link to a more concise thread is always handy though. |
