Problem loading patches from here:It's not possible / fixed
Page 1 of 1 [13 Posts]
Funky40
G2 patch files: 5
PostPosted: Thu Mar 16, 2006 7:21 am    Post subject: Problem loading patches from here:It's not possible / fixed
Subject description: I get an error Message
I get following Error Message when i try to load a patch from here. It is the first time that i see this. I tried it with 4 patches.
Internet Connection is working
Can't load file. File format is not supported.
ion= Nord Modular G2 file Format 1
I have OS 1.4 in my Engine
Audio files: 309
PostPosted: Thu Mar 16, 2006 9:43 am    Post subject: Reply with quote  Mark this post and the followings unread
On all files ? patches and perfs ?
Fozzie
G2 patch files: 49
PostPosted: Thu Mar 16, 2006 10:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Is it when you try to open a patch or perf right away when downloading, without saving it first? I had problems with the file association, therefore they wouldn't load unless I saved 'em to disk first. After associating the file with editor program manually, it worked on my pc. Just try to to save it to disk and start it that way, it might work.
Funky40
G2 patch files: 5
PostPosted: Thu Mar 16, 2006 11:27 am    Post subject: Reply with quote  Mark this post and the followings unread
2 or three days ago it was all fine, i tested some patches from here.
I can't rightclick anymore to files und save them first on disk because i installed Macromedia dreamweaver 4Weeks ago. whenever i rightclick on a file it will save it as a php file Embarassed
Yes performances und patches, nothing works with loading directly
It must be as Fozzie wrote.....................hmmmm ? Macromedia is allready deinstalled.
shit, only idea is to set up the whole PC with XP new.
Fozzie
G2 patch files: 49
PostPosted: Thu Mar 16, 2006 11:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Wowowow, not so fast Wink. What if you just try what worked for me: go to a folder on your harddisk that contains g2 patches and performances. Right-click on of each file-types and choose 'open with [arrow]' and choose something like 'choose program...' (bottom option). You could choose any installed program now if all is well, but if the NMG2 editor program is not on this list, you can direct XP to the clavia folder that contains the editor. Check the option to always use 'this program to open this file type'.
After I went through this manual file-association routine for both the patches and the performances, the direct-download way of working was back fully functional again. It's easy; wouldn't hurt to try before messing with reinstalling things.
Audio files: 233
PostPosted: Thu Mar 16, 2006 11:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, please try Fozzie's suggestion before doing anything more drastic. If you can't double click on a .pch2 or .prf2 file on the local disk, you can't get the browser to work.
Funky40
G2 patch files: 5
PostPosted: Thu Mar 16, 2006 12:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
OhOh,
ok, the files are really no more shown with the G2 filelogo.
I did now as told, but than i get a windows error Message, something with system 32 and now are the files shown with a other signet. (blue strips and a red A,( I'm not so familiar with computers ))
My nglish is not good enough to explain it all
Fozzie
G2 patch files: 49
PostPosted: Thu Mar 16, 2006 12:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
I guess the icons you see now indicate that there is no more functional file association for this type of file. Maybe you can get someone with some computer knowledge to help you to do this correctly; it shouldn't be too hard.
Best of luck!
Audio files: 309
PostPosted: Thu Mar 16, 2006 12:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
A quick way to repair the file associations is to de-install the NM editor and then install it again.
edit : When you can't explain in English ... there are quite a few here being able to read German, so maybe try that.
Funky40
G2 patch files: 5
PostPosted: Thu Mar 16, 2006 1:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks,
i will try to reinstall the G2 editor.
I'm also in the synthesizerforum.de with somebody speaking about. But his tipp was'nt the solution.
Funky40
G2 patch files: 5
PostPosted: Thu Mar 16, 2006 4:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
reinstalling the G2 editor has fixed the Problem.
Thanks for the help
northstar
PostPosted: Thu Mar 16, 2006 4:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
I guess it won't solve Funky40's problem, but perhaps it's of use for others: Whenever I download patches and performances the download message window reads the correct file's name, e.g. "xyz.pch2", but on the HD it's saved as "xyz.pch2..pch2". Subsequent on deleting that doubled extension everythings works fine.
northstar
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Thu Mar 16, 2006 4:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
wierd, what OS are you on (Win/Mac)?
/Dasz
