Chris D.
Posted: Tue Aug 08, 2006 11:06 am Post subject:
Is the NORD G2 output level very low? Subject description: Not enough volume even with a 1000 watt amp! |
I'm playing with a very loud group, and I'm running the nord, 1-2 into a stero PA using bose 402's with a 60 W per side stereo rack mount amp. 3-4 are going out to a bass amp.
Not getting enough volume out of the PA, I tried out a more powerful AMP, The volume wasn't significantly greater, even though the amp was 10X the watt rating.
Baffled, we tried different speakers, and while louder, they still weren't any where near what we expected.
I used some factory presets for these tests, so I'm sure the signal coming out of the NORD outputs 1-2 was pretty hot.
Any ideas about what might be happening?
CD
CD |
cebec
G2 patch files: 31
Posted: Tue Aug 08, 2006 11:15 am Post subject:
| yes, some people have commented on this in the past. make sure the patch level is all the way up, the master level (hardware) knob is all the way up and try the +6 dB boost button the 2-out module. the factory presets aren't always adjusted in this manner |
Posted: Tue Aug 08, 2006 11:25 am Post subject:
No matter what a, 1K watt PA dedicated to the G2 should definitively have some cutting power.
Try a compressor and see what you get. The patches might be too lethargic. _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
sheridan
Joined: Jun 05, 2005 Posts: 473 Location: London, England
Audio files: 27
No, it's not low if all your levels are up. Check the main patch volume (CC #7) - this is often set lowish. If that is full up, look at the meters on the output module - if the levels are low you can click on the Pad button to increase the output by 6 dB. If it is still low, maybe there is an amp or mixer in the patch set low. Finally, you could always add and amp module or two to boost the levels.
If however, your output module meters are showing red but the level still sounds low then you need to raise the gain/trim on the mixer/amp that the G2 is connected to... basically the input gain on my G2 channels on my mixer are set to approximately the same as for my other keyboards/sound modules, so when the output module meters in the G2 are in the red, the mixer meters also show red, ie. full output.
Oooops, I was just beaten to it... ah well, I'll post it anyway. _________________
Sheridan
Hear music and Nord Modular G2 patches and find out music production tips at
http://www.nitetimeproductions.co.uk |
ian-s
Audio files: 42
G2 patch files: 626
Posted: Tue Aug 08, 2006 12:59 pm Post subject:
Re: Is the NORD G2 output level very low? Subject description: Not enough volume even with a 1000 watt amp! |
| Chris D. wrote: | 3-4 are going out to a bass amp.
3-4 outputs are not used unless specifically patched.
As well as lowish output levels, come have commented on the velocity curve not being suitable for a softer touch.
And don't forget, 10Xpower is only a 10dB increase in perceived volume. |
tombola
G2 patch files: 9
Posted: Tue Aug 08, 2006 1:41 pm Post subject:
I've always found the G2 level irriitatingly low. it's MUCH lower than a Waldorf Pulse, and definitely lower than a DSI Evolver or a PodXT - was going to ask if there's a pot or anything inside which can be tweaked to boost the output stage.
The unbalanced outputs obviously don't help.
I have everything plugged into a patchbay and into the inputs on my soundcard, even with it properly set up for a mix of balanced and unbalanced signals, I find the G2 unusually low, across all patches. _________________ http://www.musicthing.co.uk/ |
monobass
G2 patch files: 12
Posted: Tue Aug 08, 2006 1:55 pm Post subject:
| tombola wrote: | | I've always found the G2 level irriitatingly low. it's MUCH lower than a Waldorf Pulse |
The Pulse is well hot though... mine is anyway. I must admit I hadn't really noticed that about the G2 but then i don't use much else at the moment. _________________ Steve |
Joined: Jan 31, 2003 Posts: 18276 Location: Durham, NC
Audio files: 233
Posted: Tue Aug 08, 2006 5:32 pm Post subject:
I have found the G2 output levels to be low too, but not so low to be unusable or to require a dedicated preamp. _________________ --Howard
my music and other stuff |
Posted: Tue Aug 08, 2006 6:30 pm Post subject:
| elektro80 wrote: | No matter what a, 1K watt PA dedicated to the G2 should definitively have some cutting power.
Try a compressor and see what you get. The patches might be too lethargic. |
I suspect something along those lines too.
Clavia's presets most certainly aren't aimed at that sort of application, I suspect psychoacoustics. Any simple little mixer should be able to deal with any added pre-amplification that might be needed but beware of driving a amp's input into the red; It's usually preferable to take a better sound or a larger amp since overdriving amps leads to speaker damage due to excessive high frequencies and in extreme cases blown fuzes.
The output is too low compared to many things but not so low as to pose a real problem in a larger system. Amplification alone can't usually cure preceived loudness within very loud band situations, at least not without doing extra harm. _________________ Kassen |
paul e.
Joined: Sep 22, 2003 Posts: 1567 Location: toronto, canada
Posted: Tue Aug 08, 2006 9:01 pm Post subject:
is this an impedance thing ?
what are the PA amps inputs ?
what is the OHM rating of the speakers..of the amp...?
watt rating of the speakers?
a 8ohm speaker drawing on a 2ohm amp will not give you full power at all, for example
even a quiet synth will be loud enough in a decently rated PA...for sure
i am guessing you have mismatched impedance _________________ Spiral Recordings |
3phase
G2 patch files: 141
Posted: Wed Aug 09, 2006 12:48 pm Post subject:
| the g2 otputs dont deliver full line level..they are -10 db and therefore need a preamp (mixixing desk channel) to drive a poweramp |
Posted: Wed Aug 09, 2006 12:51 pm Post subject:
Uh...
Is it really that simple... our friend has plugged his G2 directly into the power amp line inputs??
Nahh.. he would never do that.. or?
Flickr |
Derek Cook
Posted: Thu Aug 10, 2006 11:30 am Post subject:
FWIW I have a Nord G2 Engine, a Yamaha EX5, Motif ES Rack, FS1R and A4000 all plugged into a Berhinger line mixer, and it's the FS1R that I have to boost above the others.
Apart from the FS1R, the mixer gains for all the other units are identical.
So I find the Nord G2 engine output comprable to the the other units, and sometimes. This is after tweaking the patch gains in the Nord box as already discussed above, and occasionally for some patches I need to set the +6dB pads.
But once that is done the Nord can certainly be heard, and all I use is a little old H&H amplifier driving a Scott speaker cab. That combination is more than powerful enough for the small pub and hotel type venues that I've played. |
varice
Joined: Dec 29, 2004 Posts: 961 Location: Northeastern shore of Toledo Bend
Audio files: 29
G2 patch files: 54
Posted: Thu Aug 10, 2006 10:37 pm Post subject:
Many of the G2 factory presets are not patched to take full advantage of the available headroom.
The G2 outputs can deliver a signal of almost 8 volts peak to peak before clipping! Is this below average for most synths? _________________ varice |
Axiom
G2 patch files: 28
nuts
Posted: Mon Sep 04, 2006 2:52 am Post subject:
Do you solve your problem ChrisD ?
I had the same trouble with the nord rack 3 mixed between old analog gear et other digital synth & sampler. The preamps on the mixing desk where always set close to the max but for some soundscapes or sounds made with filters resonance it was still way to low.
I sold it now (not for this reason) and i was thinking of a g2 engine + bitstream 3x but i don't really want to have the same level problem.
In comparison the microwave XTr sounds really louder. |
Derek Cook
Posted: Mon Sep 04, 2006 7:04 am Post subject:
| nuts wrote: | Do you solve your problem ChrisD ?
I have a G2 engine, and once I've tweaked the patches (including presets) to my taste, I've had no problem with lack of volume! |
capfindus
Posted: Mon Sep 04, 2006 12:45 pm Post subject:
| Well, my G2X has the lowest output off all my keyboards... |
nuts
Posted: Mon Sep 04, 2006 1:11 pm Post subject:
Thanks for your answers, the biggest problems for me is to have an acceptable recording level to avoid noise or "afterprocess" but i imagine there is lot of ways to increase volume via patching in the G2.
I tried on the software demo to chain 2 output modules and it works well but don't know what it really do on the G2 , does it distort the sound ? |
seraph
Editor
Audio files: 33
Posted: Mon Sep 04, 2006 2:36 pm Post subject:
| capfindus wrote: | | Well, my G2X has the lowest output off all my keyboards... |
benvenuto a electro-music.com  _________________ homepage - blog - forum - youtube
| Quote: | | Don't die with your music still in you - Wayne Dyer |
X-Electric
Joined: Jul 11, 2005 Posts: 182 Location: Warsaw, Poland
Posted: Mon Sep 04, 2006 7:05 pm Post subject:
| In Poland they were called "Kapitan Igloo"... |
Fozzie
Joined: Jun 04, 2004 Posts: 875 Location: Near Wageningen, the Netherlands
G2 patch files: 49
Posted: Mon Sep 04, 2006 11:15 pm Post subject:
| nuts wrote: | Thanks for your answers, the biggest problems for me is to have an acceptable recording level to avoid noise or "afterprocess" but i imagine there is lot of ways to increase volume via patching in the G2.
IMHO you really don't have to be afraid of noisyness with a G2, it is a synth that can sound very polished (depending on the patching of course). Maybe there are issues here with people trying to record the G2 on a +4dBu input? I always use a normal line level input on my soundcard (-10dBu), and it is fine. Can get full range audio dynamics; noise is no problem whatsoever. |
nuts
Posted: Tue Sep 05, 2006 4:24 am Post subject:
ok thanks, i will listen to that in 3 days the G2 engine is ordered.  |
Stanley Pain
Joined: Sep 02, 2004 Posts: 782 Location: Reading, UK
Audio files: 10
G2 patch files: 35
Posted: Tue Sep 05, 2006 7:44 am Post subject:
am i the only person to find the G2 output more than adequate? i know that i patch loud, for the sake of it (a terrible habit i'm slowly breaking), but even on the factory presets i find that i have to turn the main volume down a touch.
it's going into my PC via a Terratec EWS 88 MT, and i record into sx3. _________________ there's no I in TEAM, so let's all act as individuals instead |
