 Forum index » Clavia Nord Modular » G2 Patches - Completed » Drum
My first Drum patch
Page 1 of 1 [7 Posts]
modular
G2 patch files: 72
PostPosted: Fri Aug 27, 2004 7:36 am    Post subject: My first Drum patch Reply with quote  Mark this post and the followings unread
This is my first engagment with Drums patches. Only first five variations are active.
My Ddrum setup.pch2
Drums Setup with controlled delay effect
 Filename:  My Ddrum setup.pch2
 Filesize:  3.76 KB
 Downloaded:  2014 Time(s)
Audio files: 224
PostPosted: Fri Aug 27, 2004 7:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Sounds good so far, but you should make sure all of the variations are populated if you post it on the Patches Completed forum, I think. Otherwise it's still experimental wouldn't you think?
modular
G2 patch files: 72
PostPosted: Fri Aug 27, 2004 8:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Right, delete this Topic, please I'm gonna to post the same in Experimental Forum.
Sorry, for the inconvenience. Embarassed
Audio files: 297
PostPosted: Fri Aug 27, 2004 9:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Why not just initialize the now uninitialized variations and repost the patch ? The variations don't have to be diferent I'd say as long as the speakers won't blow up it seems to be OK to me.
Jan.
modular
G2 patch files: 72
PostPosted: Fri Aug 27, 2004 11:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Jan.
Ok, i've reposted the patch, now is updated with all 8 variations active.
Now a question?
How can add others sequencers module and link them so to do several drums patterns?
In other words I wanna the sequencer 1 play 32 bars of its pattern, for example, then it stops and start another sequencer module for 8 bars,then it will stop and start the third for 12 bars,and so on.
Maybe changing between different variations with midi control modules?
But in this case I'll have only eight possibilities.
Tips will be nicely accepted. Embarassed
Audio files: 297
PostPosted: Fri Aug 27, 2004 12:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think the question about the sequencers is an interesting one but it should be asked in http://electro-music.com/forum/viewforum.php?f=63
Maybe you can start a new topic over there ?
Jan.
modular
G2 patch files: 72
PostPosted: Fri Aug 27, 2004 1:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Jan.
I'm gonna do it.
