Nord Micro, is this 'aliasing' noise supposed to happen?
Page 1 of 1 [25 Posts]
masstronaut
PostPosted: Fri Nov 20, 2009 5:32 pm    Post subject: Nord Micro, is this 'aliasing' noise supposed to happen? Reply with quote  Mark this post and the followings unread
Hey Nord kids, I wonder if someone could check this for me...
Here's a brief sound example. It's just a low sine osc rising in volume. What you'll notice is a higher tone the accompanies it as it reaches a certain level. It sounds like aliasing or PWM or something.
Audio - http://www.mediafire.com/?z0nihtknkyo
The patch - http://www.mediafire.com/?nnwyo52mdw1
Thanks a lot if you can help with this.
ark
G2 patch files: 31
PostPosted: Fri Nov 20, 2009 7:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
I don't have an NM1, but if you post a screenshot of the patch, and it's not too complicated, I'll try to put together an equivalent G2 patch and post audio from it.
ark
G2 patch files: 31
PostPosted: Fri Nov 20, 2009 7:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
By the way, here's an image that results from applying Ableton Live's spectrum analyzer to your audio. You'll see that there appear to be various high partials, presumably distortion components, but they're all at least 60 dB down from the main signal.
Spectrum analysis of nordo.wav
 Filesize:  143.98 KB
 Viewed:  210 Time(s)
Audio files: 297
PostPosted: Fri Nov 20, 2009 7:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hmm .. only when I make it clip somewhere it does make the high tone, I hear nothing odd on the mp3 either ... again unless I make it clip.
oh .. and welcome of course!
masstronaut
PostPosted: Fri Nov 20, 2009 8:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hello and thanks.
I don't think there's any clipping. The levels in the patch should be OK and I've normalised the audio to -1db. It's actually more pronounced at low volumes, as if it's digitising noise from a low bit depth.
I can hear it on the headphone out and the main out from the MM.
Here's the revised patch, I've made it as simple as possible just to demonstrate the effect. You can see the level on the mixer is right down. The x-fade is just to automate the level of the oscillator.
Patch - http://www.mediafire.com/?zcwguttylio
The audio is a .wav so it's not an mp3 artefact.
New audio - http://www.mediafire.com/?goymkmqzy1d
Recorded at a lower level, hence the hiss, but you can plainly hear what sounds like a square wave with PWM.
Thanks again.
 Filesize:  30.64 KB
 Viewed:  9514 Time(s)
Audio files: 297
PostPosted: Sat Nov 21, 2009 8:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Not sure what happened here ... I was replying Ark's post in which he said there was clipping ... but the post is gone ... I hope I did not delete it by accident?
ark
G2 patch files: 31
PostPosted: Sat Nov 21, 2009 9:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Sorry, I deleted it on purpose.
I had said that it looked like there was clipping, because the level rose to a plateau, stayed there for a while, and then started down again. I was puzzled, though, because I thought that if I was really seeing evidence of clipping, I would have seen clipping artifacts in the spectrum analysis, and I didn't see any.
Then I looked at the patch again, and realized that if the LFO generates a signal that is more than what is needed to push the cross-fader to its limits, that would cause the envelope I saw without any clipping taking place. In other words, I realized that the LFO was effectively clipping, which didn't matter. So I deleted the post.
Audio files: 297
PostPosted: Sat Nov 21, 2009 10:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Ok, was about to point that out and then the post went away Wink
anyway, I see nothing odd on either the recording or the patch ... so either my ears fail me or there is clipping in an external device.
masstronaut
PostPosted: Sat Nov 21, 2009 11:26 am    Post subject: Reply with quote  Mark this post and the followings unread
There's definitely no clipping happening externally, this happens at quite a low level. The patch is very simple intentionally so there's no confusion as to where the distortion is coming from. The reason I have the level rising is that the effect 'kicks in' at a certain point. It's very apparent on more complex patches and is actually ruining the sound of it for me, it's not a minor thing - I'm quite sure there's something wrong with the outputs now.
Did you listen to the second clip Blue Hell? It's unmistakable there, bear in mind this is supposed to be a low sine tone, the 'Nintendo' effect is not intended. And although that sounds kind of interesting, in a more complex patch it just sounds like scratchy noise. Don't worry about the hiss - that's just because it was quiet.
Thanks chaps. I'd just like to know what the cause could be - a faulty component I guess, but which one?
PostPosted: Sat Nov 21, 2009 11:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Blue signals act at a 4th of the sample-rate of red ones. When you use them for am (which this essentially is) you'll get stepping at a 4th of the sample rate in your audio signal which is indeed unpleasant to sensitive ears.
In some cases a LPF over the modulation source is a good solution but structurally speaking I think you are better off using red osc's pitched way down for am. If sound quality is dear to you, and it sounds like it is, it pays off to make sure blue signals *never* touch the actual audio without smoothing in place. Often a first order lpf will service to push the errors below the audible, especially in the context of a mix.
This is a especially delicate issue with envelopes, I find, as it interferes with snappy attacks. A variable filter can be used there; I find the exact spectral content during extremely fast attacks doesn't matter so much. However, when you take the filter down again beware that the modulation source for that should likely be smoothed as well. Overall it's quite annoying, and compensating for this can easily take up a quarter or more of your patch. It's worth it though.
masstronaut
PostPosted: Sat Nov 21, 2009 11:43 am    Post subject: Reply with quote  Mark this post and the followings unread
It's not that, I wouldn't mind if it was. The duty cycle of that LFO is around 5 seconds or something - it's just there to provide a slow rising and falling level for demonstration purposes, not audio rate AM. I should clarify, this is not an issue with a particular patch, that patch is just a test.
The same thing happens with an osc going straight to an output, or into a mixer module first. It goes away if I turn the physical main volume knob down A LOT, but kicks in again when it's turned up - so it's related to the overall output level.
Thanks for looking at it.
Audio files: 297
PostPosted: Sat Nov 21, 2009 12:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
No I had not, I was referring to the 1st one ... but that 2nd one definitely clips somewhere indeed. and I do not hear it on the patch ... so probably a bad output indeed ... it seems too noisy as well .. the recording that is.
You also hear it on outs 3 + 4?
PostPosted: Sat Nov 21, 2009 12:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
masstronaut wrote:
It's not that. The duty cycle of that LFO is around 5 seconds or something - it's just there to provide a slow rising and falling level for demonstration purposes, not audio rate AM.
The sample-rate of the LFO is independent of the LFO rate. In fact, for lower LFO rates the jumps in volume may be less frequent due to bit-depth-induced stepping (the NM is only 24 bits, internally). Since you are basically am modulating the audio signal with both the LFO's sine and a sort of saw that has a frequency of a a 4th of the sample rate (and a variable amplitude dependant on the phase of the LFO) and am leads to side-bands on both sides of the signal some of the artefacts *will* end up in the audible range.
I'm not sure that's what your issue is here but that is certainly going on as well.
Right, that's different. I just listened to your file (previously media fire had some complaint about my cookies policy or something). This does sound like a broken dac or similar, it's much more pronounced that the phenomenon I mention above (which some people don't even seem to hear) and not as enharmonic.
What is slightly odd to me is that it would be affected by the main volume knob, which I'd expect to affect a analogue amp and not the dac, to preserve bits. Then again; issues with digital sound definitely aren't Clavia's forte.
PostPosted: Sat Nov 21, 2009 12:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
That would have been my question as well, but the issue is with a Micro.
Oh, well, this is outside of my area of expertise. Hopefully the notes on getting blue signals to behave will still be of use to someone.
masstronaut
PostPosted: Sat Nov 21, 2009 12:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
As Kassen says, it's a Micro. It's there on the headphone out though. I don't know if it is "clipping" exactly, or what it is that might be clipping, but it doesn't seem right to me.
I know that recording is v.noisy - that's OK, it was just done at a very low level to avoid any possibility of clipping elsewhere, and I might have left some other inputs open. Embarassed
masstronaut
PostPosted: Sat Nov 21, 2009 12:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh yeah, definitely. Will be of use when I get a working Modular. Smile
Audio files: 297
PostPosted: Sat Nov 21, 2009 12:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sorry ... I usually don't see message titles as I just read all messages Wink
PostPosted: Sat Nov 21, 2009 12:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
I suspect a broken DAC. The effect reminds me of sounds I got emulating bad DACs in a otherwise anti-aliased system. This gives harmonic (for practical purposes) overtones as the effect will repeat with the cycle of the signal.
Looking at the actual wave confirms this. For the positive half of the cycle there are discontinuities on both the way up and down at the same amplitude. cycles that stay below that level look like decent enough sines, give or take some recording hiss.
PostPosted: Sat Nov 21, 2009 12:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
's ok. It would have been good to try to listen to another DAC on the same system but in this case we can see a artefact that I couldn't explain in any other way than a broken bit in a dac. Amps don't do this.
Audio files: 297
PostPosted: Sat Nov 21, 2009 12:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Kassen wrote:
Amps don't do this.
My mixer sounded much like it yesterday .. i sent in the NM a bit loud.
PostPosted: Sat Nov 21, 2009 1:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh, yes, the harmonics were no doubt quite similar as it's basically a periodic higher-order discontinuity. When Masstronaut said it reminded him of PWM that was quite understandable as well, if you look at the place of the artefact and how it only affects one half of the cycle.
It's the DAC though, I bet.
That's bad news, I imagine paying somebody to solder in a new chip would cost more than a new MM.
Audio files: 297
PostPosted: Sat Nov 21, 2009 1:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Don't know ... doing it the official way maybe ... but I'd be surprised if it would be more than an hour of work ... for someone experienced at it ... the chips don't have too many pins ... you'd need some tools & good eyes & hands.
ark
G2 patch files: 31
PostPosted: Sat Nov 21, 2009 2:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Aha! Here's the problem.
If you look at the nordio2 clip, you'll see that the overall envelope has a weird plateau in it, and once the level passes that threshold, there's clear defect in the waveform. Look at the attachments for more detail.
I don't seem to be able to add more than five attachments; so I'll put the last one in a separate message.
The overall envelope (i.e. amplitude vs. time) for the second sample has a strange shelf in the positive half.
 Filesize:  101.74 KB
 Viewed:  173 Time(s)
The waveform for the first signal looks normal in the high-level portion too.
 Filesize:  123.28 KB
 Viewed:  178 Time(s)
The first signal's waveform looks normal in the low-level portion.
 Filesize:  114.15 KB
 Viewed:  165 Time(s)
Looking at a small portion of the waveform when it's loud, we see that there are artifacts of some kind in the positive part of each cycle.
 Filesize:  105.62 KB
 Viewed:  165 Time(s)
Looking at a low-level part of the second signal, the waveform appears normal.
 Filesize:  136.03 KB
 Viewed:  184 Time(s)
ark
G2 patch files: 31
PostPosted: Sat Nov 21, 2009 2:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
As promised, here's the missing attachment. It shows the overall envelope for the first sample.
The first signal has the kind of envelope you'd expect: It rises linearly until the fader has reached its limit, stays there for a while, then falls linearly back to zero.
 Filesize:  103.1 KB
 Viewed:  171 Time(s)
Oli
PostPosted: Mon Nov 30, 2009 7:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Sorry about the issue, but it is an interesting read.
I enjoyed it. Reminds me of studying comms systems in uni. Do you have this kind of background, Kassen?
Good good study, day day up!
