2010 Build Pictures
Page 22 of 24 [576 Posts]
Goto page: Previous 1, 2, 3, ..., 20, 21, 22, 23, 24 Next
cloudscapes
PostPosted: Sun Dec 12, 2010 6:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
cloudscapes wrote:
just finished my looper / sampler / granular glitcher / mangler / drone noise thing!
That looks great! Got any recordings?
doesn't the posted video count? Wink
Sonic Crayon DIY effects lab
Audio files: 326
PostPosted: Mon Dec 13, 2010 11:17 am    Post subject: Reply with quote  Mark this post and the followings unread
I guess .. but i got fed up with youtube and totally blocked it .. so i didnt even see it Laughing sorry ... will have another look.
ericcoleridge
PostPosted: Tue Dec 14, 2010 12:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Buchla 295 10 Channel Comb Filter Clone, and various housings
295 Clone
 Filesize:  1.02 MB
 Viewed:  588 Time(s)
 Filesize:  1.19 MB
 Viewed:  548 Time(s)
 Filesize:  1.24 MB
 Viewed:  618 Time(s)
 Filesize:  1.36 MB
 Viewed:  575 Time(s)
PostPosted: Wed Dec 15, 2010 12:42 am    Post subject: Reply with quote  Mark this post and the followings unread
looks awesome!
mono-poly
PostPosted: Wed Dec 15, 2010 12:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Sweet!
the architech
PostPosted: Thu Dec 16, 2010 1:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey Eric, I love that Buchla 200 housing you made. Do you have templates and dimensions for it? I was actually planning something similar, but was going to start from scratch. I was going to design it from scratch, but if I had templates or dimensions to start from, that'd be grand...
ericcoleridge
PostPosted: Thu Dec 16, 2010 3:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Believe it or not, I mostly did everything by eye-- there's a wealth of photos online for virtually every module. Still, I haven't really had a lot of time to work on this stuff, so it's taken me years to get this far. I'd like to come to some sort of finish before sharing any layouts, etc. I'm open to trades though.
I made the folding cabinet on Illustrator, using photos as my guide. But, I'm not super versed in Illustrator, so I've had trouble with other designs there. The next big thing I'd like to get worked out is the key design used on the 216 Touch Controlled Voltage Source. For my purposes, this is the most desirable, useful and doable of the various Buchla key designs. If someone could help me get a good scale illustrator drawing of this design, I'd be happy to trade for other layouts. I don't think it should be that difficult, but I don't have much access to a computer that will run illustrator very effectively.
 Filesize:  149.39 KB
 Viewed:  24141 Time(s)
the architech
PostPosted: Thu Dec 16, 2010 3:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
well, I'm not really interested in emulating the Buchla modules themselves, just the case. Like those shelves look pretty shallow, how deep are they? Looks tight getting PCBs and all in there.
bubzy
Audio files: 64
PostPosted: Thu Dec 16, 2010 4:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
wsg pcb and back. note the ridiculous polystyrene caps Very Happy
 Filesize:  138.67 KB
 Viewed:  451 Time(s)
 Filesize:  139.02 KB
 Viewed:  439 Time(s)
frijitz
Audio files: 54
PostPosted: Sat Dec 18, 2010 12:30 pm    Post subject: wavolverII Reply with quote  Mark this post and the followings unread
OK, it has a panel, so it's a build, right?
This is a prototype of an updated version of the Wavolver waveshaper. New features include input offset under VC and variable amplitude (+/- 5V) of the second pulse.
Ian
 Filesize:  99.41 KB
 Viewed:  358 Time(s)
PostPosted: Sat Dec 18, 2010 4:55 pm    Post subject: Re: wavolverII Reply with quote  Mark this post and the followings unread
you got it! Laughing
droffset
PostPosted: Sun Dec 19, 2010 4:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cynare vid up.
Warning, it's a beginner level vid, advanced dudes might get bored.
cynare panel by drOffset, on Flickr
Edit: Spelling mistakes.
PostPosted: Sun Dec 19, 2010 9:21 pm    Post subject: Just built Ray Wilson's NPN Transistor VBE tester Reply with quote  Mark this post and the followings unread
I really have needed a way to match transistors and I built Ray's (Music From Outer Space) Simple NPN Transistor Matching setup.
I decided to utilize a PCB and I used Eagle to design the PCB. This was my first attempt at a double-sided PCB and it worked out fine!
The only tweek I had to make was to change R12 from 1500 to 822 ohms (for the null circuit).
The module can be powered from my synthesizer supply (+15/-15v) -- I used an 8 pin socket for the test transistor (just using the first three pins for testing).
Now that I have this tester, I have plenty of work to do -- I need to get a matched pair into my Bi-N-Tic filter. I am also building some Yusynth modules that require matched pairs: the Quad VC Panners, Diode Ladder filter, and the Moog filter clone.
Picture shows the VBE tester board and the corresponding readout from the multimeter. The tester is mounted on an aluminum base for stability.
 Filesize:  1.47 MB
 Viewed:  342 Time(s)
bubzy
Audio files: 64
PostPosted: Mon Dec 20, 2010 1:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Love that cynare Droffset. nice knobs in the middle too Smile good work.
The Peasant
PostPosted: Tue Dec 21, 2010 10:12 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm well into my third SynthCase project, the case and front panel work have been completed. I typically do large projects over the winter, so by the end of the year I haven't really completed anything, I'm usually just getting started by then. When I have completed this project sometime in the new year I imagine that I will post the results in the 2011 Build Pictures thread.
This project has the highest density of front panel components that I have ever done, including two heavily modified Jim Patchell 8X2 sequencers and two Fonik VCPS sequencers. There are also a bunch of CGS modules and a few other things included as well. More pictures and information are posted on my website: www.electronicpeasant.com/projects/syncase3/syncase3.html
Take care,
Doug
 Filesize:  208.69 KB
 Viewed:  350 Time(s)
The Electronic Peasant
dougseidel
PostPosted: Tue Dec 21, 2010 11:09 am    Post subject:
Subject description: update
here's my new box - 3 oscillators and LP filter, with simple sequencer with LED blob, and switchable LDR controls for pitch and filter freq.
And I'm amazed at the beautiful stuff people have shown up above.
 Filesize:  64.83 KB
 Viewed:  23477 Time(s)
 Filesize:  66.81 KB
 Viewed:  23478 Time(s)
PostPosted: Tue Dec 21, 2010 11:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, indeed. Beautiful work!
emdot_ambient
PostPosted: Tue Dec 21, 2010 3:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
dougseidel wrote:
here's my new box.
Uh...OK...but, um, what is it?
Mr. Green
emdot_ambient
PostPosted: Tue Dec 21, 2010 3:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
Checked out your site...now THAT is truly hardcore.
RF
Audio files: 28
PostPosted: Tue Dec 21, 2010 8:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Soundlab Ultimate, Expander and Keyboard. The Synth unit can be removed from the keyboard section to operate on it's own by removing two bolts.
I've been working on this way too long - one trim item remains to be done, the space between the two panels - still working on that. Other than that, it's set to go.
bruce
 Filesize:  111.88 KB
 Viewed:  345 Time(s)
 Filesize:  111.37 KB
 Viewed:  337 Time(s)
www.sdiy.org/rfeng
The Peasant
PostPosted: Tue Dec 21, 2010 10:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thank you! Building these is so much fun!
I already have plans, cases, and pcbs for two more SynthCase projects after this one, and by the time I get them built I'll probably have a few more ready to go. Once you get started building this stuff it's impossible to stop! dancing
Take care,
Doug
loydb
PostPosted: Wed Dec 22, 2010 8:11 am    Post subject: Reply with quote  Mark this post and the followings unread
That came out great! Are you going to cover the gap with a wooden trim strip?
RF
Audio files: 28
PostPosted: Wed Dec 22, 2010 8:14 am    Post subject: Reply with quote  Mark this post and the followings unread
That's the plan - the two finishes on the panels kind of demand a bit of wood.
www.sdiy.org/rfeng
tommi
PostPosted: Wed Dec 22, 2010 10:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Fonitronik VCMod on stripboard. I still have to try it and calibrate it..
this is the price to pay when you're late for pcb offers!
 Filesize:  921.94 KB
 Viewed:  355 Time(s)
 Filesize:  856.26 KB
 Viewed:  319 Time(s)
 Filesize:  871.05 KB
 Viewed:  336 Time(s)
http://tideofsound.net
PostPosted: Wed Dec 22, 2010 5:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Clever my friend !! Very nice. Cool
Bill
