 Forum index » electro-music.com » NEEMFEST 2019
Video files from Jack Tamul's composition, GAIA
Page 1 of 1 [12 Posts]
Audio files: 235
PostPosted: Wed Sep 11, 2019 2:11 pm    Post subject: Video files from Jack Tamul's composition, GAIA Reply with quote  Mark this post and the followings unread
At Neemfest 2019 Jack Tamul organized a group performance of has composition called GAIA. This was recorded directly from the board and the performers were asked to record cell phone video during the performance.
If you made a video, please upload it here as a reply to this topic. After a reasonable time, we will edit all these vids into a movie to document this event. It should be pretty interesting.
So post your vids here and please contact anyone you know that has made a video but might not see this post.
Just click on the "Post Reply" button and then you can click "Add Attachment". Problems: try the chat room or send me a Private Message, PM,. by clicking here: http://electro-music.com/forum/privmsg.php?mode=post&u=2
Thanks to Steve Mokris for volunteering to edit this together.
cwikman
PostPosted: Tue Oct 08, 2019 12:03 pm    Post subject: Video upload - 1 of 2 (failed) Reply with quote  Mark this post and the followings unread
Will try again
Audio files: 235
PostPosted: Fri Oct 11, 2019 12:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
cwikman:
Apparently you tried and failed to get the upload completed. Did you get an error message?
Maybe we have a file limit on our server that is being exceeded. Can you let me know what is the size of the file? I can increase the limit if necessary.
Thanks...
BentNoise
PostPosted: Sat Oct 12, 2019 2:40 pm    Post subject: GAIA video
Subject description: attached file
Video file attached.
GAIA-EarthSounds.mp4
GAIA video - Earth Sounds
 Filename:  GAIA-EarthSounds.mp4
 Filesize:  22.5 MB
 Downloaded:  678 Time(s)
BentNoise
PostPosted: Sat Oct 12, 2019 2:44 pm    Post subject: GAIA video
Subject description: GAIA video Tubes
Tube sounds from GAIA.
GAIA-Tubes.mp4
GAIA video Tubes attachment
 Filename:  GAIA-Tubes.mp4
 Filesize:  85.23 MB
 Downloaded:  687 Time(s)
Audio files: 235
PostPosted: Sun Oct 13, 2019 5:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
welcome Bentnoise, whoever you are. Thanks for posting.
Audio files: 235
PostPosted: Sun Oct 13, 2019 5:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
I have increased some of the server's quotas so uploads of large files should now work. Let me know if you have any problems.
BentNoise
PostPosted: Mon Oct 14, 2019 3:42 pm    Post subject: GAIA video posts Reply with quote  Mark this post and the followings unread
I sent Steve the larger video file prior to the new larger file size limit.
-Scott
Creating circuit bent and glitchy noises.
https://bentnoise.bandcamp.com
ark
G2 patch files: 31
PostPosted: Thu Oct 17, 2019 8:02 am    Post subject: Video Reply with quote  Mark this post and the followings unread
Two videos for you
IMG_6629.MOV
 Filename:  IMG_6629.MOV
 Filesize:  492.33 MB
 Downloaded:  799 Time(s)
IMG_6630.MOV
 Filename:  IMG_6630.MOV
 Filesize:  23.04 MB
smokris
PostPosted: Mon Nov 04, 2019 12:35 pm    Post subject:   Reply with quote  Mark this post and the followings unread
Here's the composite video, including videos shot by Chris Wikman, Scott Armstrong, and Andrew Koenig — https://vimeo.com/370961440
Gaia @ NEEMFest 2019 from Steve Mokris on Vimeo.
Editors note: Nov 9, 2019, added embedded window from Steve's Vimeo page. --mosc
audio: https://ruori.bandcamp.com/
visual: https://vuo.org/
day-job: https://kosada.com/
Audio files: 235
PostPosted: Mon Nov 04, 2019 7:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Great job, Steve. Thanks, Jack for composing this and leading us. Thanks to everyone who participated and to those that took videos.
Now that we are all enlightened and connected with the spirit of Nature, we can do this again by astral projecting to the other side of the Universe and showing up in someone else's vision.
Keep making music...
smokris
PostPosted: Mon Nov 04, 2019 7:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
alien
