Joined: Jan 31, 2003 Posts: 18330 Location: Durham, NC
Audio files: 235
Posted: Fri Jun 30, 2006 10:33 am Post subject:
Variations in performances with Global Panel |
There are some things I find confusing with the G2. Maybe I don't understand what's going on enough.
In a performance with, say, all 4 slots populated, you can put the synth in Global Panel mode with shift/global-panel. For engine users (engineers?) you can display the Global Pages in the Parameter Overview window.
Now, what about the variations? If you have a keyboard synth, the variation buttons change all of the variations in every slot to the same variation when you select it. That is to say, when you push variation 3, all four slots jump to variation 3. (This is not exactly the best thing to do IMHO, but that is what it does).
Question, how do you do this with the editor if you have the engine?
I bring this up because people who develop performances on the engine may be missing something pretty powerful. Consequently, performances are not being made as well as they might. I can't recall a single performance posted here with the global pages variations are used. Someone please correct me - my memory is rather leaky lately. _________________ --Howard
my music and other stuff |
Joined: Apr 03, 2004 Posts: 24676 Location: The Netherlands, Enschede
Posted: Fri Jun 30, 2006 11:37 am Post subject:
Re: Variations in performances with Global Panel |
| mosc wrote: |
Not.
iIt would have to be patched such that a master slot sends variation changes to the orther slots used. Or alternatively it would have to be controlled over MIDI through the global channel, at least I think that should work. _________________ Jan
Posted: Fri Jun 30, 2006 11:42 am Post subject:
Occasionally I see a performance that seems to need the simultaneous variation changes, luckily the variations in deifferent slots can pretty fast be changed from the computer keyboard as well. Pressing A for slot A then 1 .. 8 for the variation and repeat with B, C and D keys - not instantaneous, but pretty fast. _________________ Jan
Audio files: 235
Posted: Fri Jun 30, 2006 2:04 pm Post subject:
Thanks, seems like a bit of an ommission to me.
I would like to see the global panel variations allow any combination of settings in the individual patches. It's not very useful to have all of them change to the same variation. It implies that each patch must be carefully set up for the performance. It makes layering patches very difficult. I wonder why nobody has complained about this before.  _________________ --Howard
3phase
G2 patch files: 141
Posted: Sat Jul 01, 2006 11:00 pm Post subject:
parameter in the global area should be excluded from variation changes... that would help to make the synchronus jump beneficial...
so its really useless to do remote patches that make use of the global page...actually a good place to control external gear.
I also found acces of the global area a bit unconvienient..this trippel press to get to the slot volumes troubles me... i would have prefered a double stroke with one hand |
sheridan
Joined: Jun 05, 2005 Posts: 473 Location: London, England
Audio files: 27
Posted: Tue Jul 04, 2006 9:54 am Post subject:
| mosc wrote: | | Question, how do you do this with the editor if you have the engine? |
As Jan said, I would also use CtrlSend modules from one 'master' slot. Either using an 8 switch module to come up with the variation values (like in the first attached patch), or you can just set the values on the CtrlSend modules to the relevant values on each variation of the master slot, so when you change the variation in the master slot, it will change all of the others... this method needs a Keyboard Gate signal to initiate the sending of the control signals (2nd attachment) so is a bit more expensive, but if you are already using one, then it becomes the (slightly) cheaper patch.
The first example also enables you to change all variations by changing the master slot's variation, as long as the relevant switch for each variation is selected (as in example).
Phew! Sound complicated, but it's actually very simple. It's probably just my bad explanations!
| Description: |
| 2nd way to change all slots' variations from one slot. |
 Download (listen) |
| Filename: |
VariationChange2.pch2 |
| Filesize: |
3.99 KB |
| Downloaded: |
1435 Time(s) |
| Description: |
| A patch to change all slots' variations together |
 Download (listen) |
| Filename: |
Variation change.pch2 |
| Filesize: |
4.12 KB |
| Downloaded: |
1412 Time(s) |
Sheridan
http://www.nitetimeproductions.co.uk |
Audio files: 235
Posted: Tue Jul 04, 2006 1:32 pm Post subject:
Thanks for the responses. But when using the G2X as a master keyboard, one would like to not have to patch up a slot just to do control.
It seems like whenever you touch the variation buttons in the global panel, you get into serious trouble because your individual slots jump.
The way I would like to see this work is:
You select a global page variation.
Jump out of global page mode.
Set all of the individual variations in the four slots.
Go back to global mode.
Change to another variation and do the same.
Now when you hit a variation buttion in Global Page mode, the slots change to what you want. _________________ --Howard
3phase
G2 patch files: 141
Posted: Tue Jul 04, 2006 2:26 pm Post subject:
| thats too much slot changing.. actually its good that there is the possebility to change all slots variation simultaniosly. Its just a bit too minimal implemented... it could be for example possible to exclude a certain slot from variation changes at all... this also would help to establish a remote slot within the global area.. they way its implemented now i ve never used it sofar... gave up on that feature... even volume changing is too unconfortable |
Posted: Tue Jul 04, 2006 2:53 pm Post subject:
I think Howard means that the local variation setup is stored in the global variation setup. Such that global variation 1 can have local variations 1 6 3 8, wher global var 2 has 3 8 8 3 etc. (for slotsa A B C D)
Anyway, such a setup makes sense I think. _________________ Jan
Audio files: 235
Posted: Tue Jul 04, 2006 3:24 pm Post subject:
| Blue Hell wrote: | | I think Howard means that the local variation setup is stored in the global variation setup. Such that global variation 1 can have local variations 1 6 3 8, wher global var 2 has 3 8 8 3 etc. (for slotsa A B C D) |
Yes, that's what I meant. _________________ --Howard
Afro88
Joined: Jun 20, 2004 Posts: 701 Location: Brisbane, Australia
Audio files: 12
G2 patch files: 79
Posted: Tue Jul 04, 2006 7:00 pm Post subject:
I think Clavia did it the static way to make it easy to understand and harder to mess up. It just makes it a little more work to get your global variations correct, because you need to actually move slot variations around to get your desired global variation. But this is relatively simple and straight forward if you use the patch mutator's temporary storage space to do your reorganisation. Just write down what slot variations work well together and then go through and resort them.
Your way makes sense mosc, but I think it would get really confusing really quickly, and make it easy to mess up your global variations unknowingly. |
