Variations in performances with Global Panel
Page 1 of 1 [11 Posts]
Audio files: 235
PostPosted: Fri Jun 30, 2006 10:33 am    Post subject:  Variations in performances with Global Panel Reply with quote  Mark this post and the followings unread
There are some things I find confusing with the G2. Maybe I don't understand what's going on enough.
In a performance with, say, all 4 slots populated, you can put the synth in Global Panel mode with shift/global-panel. For engine users (engineers?) you can display the Global Pages in the Parameter Overview window.
Now, what about the variations? If you have a keyboard synth, the variation buttons change all of the variations in every slot to the same variation when you select it. That is to say, when you push variation 3, all four slots jump to variation 3. (This is not exactly the best thing to do IMHO, but that is what it does).
Question, how do you do this with the editor if you have the engine?
I bring this up because people who develop performances on the engine may be missing something pretty powerful. Consequently, performances are not being made as well as they might. I can't recall a single performance posted here with the global pages variations are used. Someone please correct me - my memory is rather leaky lately.
Audio files: 326
PostPosted: Fri Jun 30, 2006 11:37 am    Post subject: Re: Variations in performances with Global Panel Reply with quote  Mark this post and the followings unread
Not.
iIt would have to be patched such that a master slot sends variation changes to the orther slots used. Or alternatively it would have to be controlled over MIDI through the global channel, at least I think that should work.
Audio files: 326
PostPosted: Fri Jun 30, 2006 11:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Occasionally I see a performance that seems to need the simultaneous variation changes, luckily the variations in deifferent slots can pretty fast be changed from the computer keyboard as well. Pressing A for slot A then 1 .. 8 for the variation and repeat with B, C and D keys - not instantaneous, but pretty fast.
Audio files: 235
PostPosted: Fri Jun 30, 2006 2:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, seems like a bit of an ommission to me. Crying or Very sad
I would like to see the global panel variations allow any combination of settings in the individual patches. It's not very useful to have all of them change to the same variation. It implies that each patch must be carefully set up for the performance. It makes layering patches very difficult. I wonder why nobody has complained about this before.
3phase
G2 patch files: 141
PostPosted: Sat Jul 01, 2006 11:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
parameter in the global area should be excluded from variation changes... that would help to make the synchronus jump beneficial...
so its really useless to do remote patches that make use of the global page...actually a good place to control external gear.
I also found acces of the global area a bit unconvienient..this trippel press to get to the slot volumes troubles me... i would have prefered a double stroke with one hand
sheridan
Audio files: 27
PostPosted: Tue Jul 04, 2006 9:54 am    Post subject: Re: Variations in performances with Global Panel Reply with quote  Mark this post and the followings unread
As Jan said, I would also use CtrlSend modules from one 'master' slot. Either using an 8 switch module to come up with the variation values (like in the first attached patch), or you can just set the values on the CtrlSend modules to the relevant values on each variation of the master slot, so when you change the variation in the master slot, it will change all of the others... this method needs a Keyboard Gate signal to initiate the sending of the control signals (2nd attachment) so is a bit more expensive, but if you are already using one, then it becomes the (slightly) cheaper patch.
The first example also enables you to change all variations by changing the master slot's variation, as long as the relevant switch for each variation is selected (as in example).
Phew! Sound complicated, but it's actually very simple. Very Happy It's probably just my bad explanations! Laughing
VariationChange2.pch2
2nd way to change all slots' variations from one slot.
 Filename:  VariationChange2.pch2
 Filesize:  3.99 KB
 Downloaded:  1425 Time(s)
Variation change.pch2
A patch to change all slots' variations together
 Filename:  Variation change.pch2
 Filesize:  4.12 KB
 Downloaded:  1399 Time(s)
transformer Sheridan
Hear music and Nord Modular G2 patches and find out music production tips at
http://www.nitetimeproductions.co.uk
Audio files: 235
PostPosted: Tue Jul 04, 2006 1:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the responses. But when using the G2X as a master keyboard, one would like to not have to patch up a slot just to do control.
It seems like whenever you touch the variation buttons in the global panel, you get into serious trouble because your individual slots jump.
The way I would like to see this work is:
You select a global page variation.
Jump out of global page mode.
Set all of the individual variations in the four slots.
Go back to global mode.
Change to another variation and do the same.
Now when you hit a variation buttion in Global Page mode, the slots change to what you want.
3phase
G2 patch files: 141
PostPosted: Tue Jul 04, 2006 2:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
thats too much slot changing.. actually its good that there is the possebility to change all slots variation simultaniosly. Its just a bit too minimal implemented... it could be for example possible to exclude a certain slot from variation changes at all... this also would help to establish a remote slot within the global area.. they way its implemented now i ve never used it sofar... gave up on that feature... even volume changing is too unconfortable
Audio files: 326
PostPosted: Tue Jul 04, 2006 2:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think Howard means that the local variation setup is stored in the global variation setup. Such that global variation 1 can have local variations 1 6 3 8, wher global var 2 has 3 8 8 3 etc. (for slotsa A B C D)
Anyway, such a setup makes sense I think.
Audio files: 235
PostPosted: Tue Jul 04, 2006 3:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, that's what I meant.
Afro88
Audio files: 12
G2 patch files: 79
PostPosted: Tue Jul 04, 2006 7:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think Clavia did it the static way to make it easy to understand and harder to mess up. It just makes it a little more work to get your global variations correct, because you need to actually move slot variations around to get your desired global variation. But this is relatively simple and straight forward if you use the patch mutator's temporary storage space to do your reorganisation. Just write down what slot variations work well together and then go through and resort them.
Your way makes sense mosc, but I think it would get really confusing really quickly, and make it easy to mess up your global variations unknowingly.
