G2 LCD Replacement
Page 1 of 2 [47 Posts]
T7
PostPosted: Thu Jul 13, 2006 7:16 pm    Post subject: G2 LCD Replacement Reply with quote  Mark this post and the followings unread
Anyone know if the G2 LCD's require soldering?
slave to this
G2 patch files: 7
PostPosted: Fri Jul 14, 2006 6:41 am    Post subject: Reply with quote  Mark this post and the followings unread
funny this gets mentioned....
i just noticed the other day that the lcd for my "master clock" and "voice mode" section was flickering. i have never seen it do it this before and thought that maybe it just had something to do with the amount of voices i had assigned to a particular patch....am i wrong? is it crapping out on me?
T7
PostPosted: Fri Jul 14, 2006 3:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
If the screen flickers on just the one patch, I would say it's not defective.
T7
PostPosted: Fri Jul 14, 2006 3:38 pm    Post subject: Re: G2 LCD Replacement Reply with quote  Mark this post and the followings unread
T7 wrote:
Surely someone knows the answer to this.
monobass
G2 patch files: 12
PostPosted: Fri Jul 14, 2006 5:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
T7 have you opened it up and looked?
I opened mine up to install the expansion and it's all very neat in there and generally easy to see what is going on.
If you want help you need to give info.
Steve
T7
PostPosted: Fri Jul 14, 2006 5:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
It's brand new. I don't want to remove the controller board unless I know I can replace an lcd without soldering. If soldering is required I'm returning it for a new G2. I've tried asking Nord USA but they don't know, and Clavia seems to be on vacation. Any help appreciated.
I'm not sure what info you need. Either you know the answer or you don't. Rolling Eyes
monobass
G2 patch files: 12
PostPosted: Fri Jul 14, 2006 6:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Why would you not return it immediately if it is brand new anyway?
A fauly LCD might be a symptom of something far worse under the hood.
These are very reliable bits of hardware so this is out of the ordinary.
Steve
T7
PostPosted: Fri Jul 14, 2006 7:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
Anyone? Sad
Audio files: 236
PostPosted: Fri Jul 14, 2006 9:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
I agree with Steve. If it is brand new, you should contact someone about warranty repair or exchange. I haven't heard of anything that makes the LCD flicker.
Can you indicate which patch flickers? If it is one of your own, maybe you could post it.
T7
PostPosted: Fri Jul 14, 2006 9:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks. I don't have a flickering problem, that was Slave To This.
On one LCD one of my side lights is very dim. On another LCD the viewing angle is way off so it's blurred, and strangley, it's discolored when the unit is turned off. So it appears to be poor quality control to me. If the LCD's just plug in I'm willing to replace them. But If soldering is required forget it, I'll return it to the dealer for a replacement.
T7
PostPosted: Fri Jul 14, 2006 10:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Anyone know if soldering is required to replace an LCD on the G2??? Smile
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Sat Jul 15, 2006 12:24 am    Post subject: Reply with quote  Mark this post and the followings unread
I've never had mine open. If I had, I probably wouldn't have looked at this specific detail. I would try for a swap back at the shop.
monobass
G2 patch files: 12
PostPosted: Sat Jul 15, 2006 9:06 am    Post subject: Reply with quote  Mark this post and the followings unread
So you're willing to void your warranty to solve a simple issue that could be a symptom of a much larger problem? What if you void your warranty, plug a new LCD in and the problem is still there?...
Do you live in a room with soft walls by any chance? Wink
Steve
T7
PostPosted: Sat Jul 15, 2006 12:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
I would of course make sure it would not void the warranty before doing it. Wink
Do me a favor Steve, save your snide comments for someone else. I don't need your advice unless you can actually answer my original question.
Do you have too much time on your hands by chance?
monobass
G2 patch files: 12
PostPosted: Sat Jul 15, 2006 4:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Even installing the expansion yourself voids the warranty in theory.
Steve
T7
PostPosted: Sat Jul 15, 2006 4:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Piss off.
monobass
G2 patch files: 12
PostPosted: Sat Jul 15, 2006 4:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
good luck
Steve
Afro88
Audio files: 12
G2 patch files: 79
PostPosted: Sat Jul 15, 2006 5:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
I remember seeing a picture of the inside of the G2 on a website somewhere... but I can't remember where sorry. It was a site that had lots of info on the NM1, and a first look page of the G2, complete with under the hood pics. Black background if I recall correctly... Anyone know the site I'm talking about?
edit: here is is http://www.sequencer.de/clavia_synthesizer/clavia_g2_modular.html
You should really take the advice of the people who have already posted though and just return it and play for a swap. How long will that take, 30 mins? A much better option than turning into a psychopath over several days because no one knows the answer to your question.
T7
PostPosted: Sat Jul 15, 2006 5:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
If you don't know the answer please don't post. Rolling Eyes
Afro88
Audio files: 12
G2 patch files: 79
PostPosted: Sat Jul 15, 2006 5:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just trying to help mate Rolling Eyes
PostPosted: Sat Jul 15, 2006 6:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Brand new synths should work flawlessly, if they don't I agree you should demand a new one; after all, you paid for a working synth and so should receive one.
I seem to remember the LCD's are soldered in, those are just standard parts and attached to the controler cerquit board. Soldering in a replacement yourself would not be fun and it's not especially interesting either, I would just avoid that if there is any other way but hey; it's your synth, you paid for it so you can do whatever you want to it as far as I'm concerned.
The one exception would be if the local repair facility have a bad rep or are slow and you can diagnose the problem yourself (it could for example be a bad soldering link?).
Opening modulars up is easy, so is putting them back together, noharm in looking. If you leave traces on the screws and people talk about the waranty later you can tell them a internal screw got loose while traveling; this happens.
DrJustice
PostPosted: Sat Jul 15, 2006 6:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey T7, chill Smile
Looking at the picture in the linked to article from www.sequencer.de above, the following can be observed:
The pin rows above the cutouts for the LCD modules can be seen. It looks like the PCBs of the LCD modules are resting on top of the front panel PCB with no space for a connector body. So it seems like they're soldered in place.
DJ
DrJustice
PostPosted: Sat Jul 15, 2006 6:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ah... Kassen hello welcome beat me to it there.
So now it's established with at least some degree of probability that they're soldered. I guess it's back to the shop then?
DJ
PostPosted: Sat Jul 15, 2006 6:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
DrJustice wrote:
Hey T7, chill Smile
I'd like to second this. Neither soldering nor talking to service counters combines well with getting agrivated.
That being said, remarks about soft walls aren't especially productive in problem solving either. I think Steve meant that as a lighthearted joke but I can see how it made T7 upset.
Big pasionate disagreements are almost unavoidable in artisitc matters like music but the proper way to deal with flickering LCD displays doesn't realy sound like one of those to me.
PostPosted: Sat Jul 15, 2006 6:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, I'm quite sure of it (opened my own NM a few times). There's not that much space there, sockets would add cost and they wouldn't serve any purpose; I think nearly all companies simply solder them in.
Anyway, I personally would go back. With a steady hand and patience you could replace a part like that yourself but unless but there is no guarantee it's in the part itself and not somewhere in the controling structure.
If T7isn't the sort of person who goes "hmmm, what might that be?" and screws it open before asking for advice (which he clearly isn't and that's fine) then I think it's best to go back. There are better places then diagnosing LCD displays in new expensive synths to start out in DIY repairs....
