fluxmonkey
Posted: Tue Feb 12, 2008 6:28 pm Post subject:
Noise Subject description: pseudo-random shift register |
i have a simpler (3chip) design on my other machine, which I'll try to dig out... but Jim Patchell has a cadillac here:
http://www.oldcrows.net/~patchell/synthmodulesII/200-1021.pdf
Ken Stones Digital Noise is also based on CMOS, and you could sub a cmos gate oscillator for the PLL he uses... |
fluxmonkey
fluxmonkey
Joined: Jan 31, 2003 Posts: 18294 Location: Durham, NC
Audio files: 235
Posted: Thu Feb 14, 2008 3:36 pm Post subject:
These look like ways to make analog noise. In a Lunetta, you really don't need noise sources. Just run a few OSCs into a gate modulator and you'll have plenty of nice noise.  _________________ --Howard
my music and other stuff |
loss1234
Audio files: 235
Posted: Thu Feb 14, 2008 5:47 pm Post subject:
Whatever gate you use with two audio rate signals gives you a lot of noise - that is a very broad bandwidth signal. Run two sigs like that through another gates and it will be very noisy.
But this isn't synthesis like additive or subtractive. This is something rather unique. You would never us a Lunetta to try to make some "sound". You use it to discover sounds that it can do. _________________ --Howard
loss1234
danielwarner
Posted: Thu Feb 14, 2008 11:03 pm Post subject:
| A nice way for getting noisy results out of CMOS like the 40106 is a simple power supply starve pot |
Audio files: 235
Posted: Fri Feb 15, 2008 9:02 am Post subject:
| danielwarner wrote: | | A nice way for getting noisy results out of CMOS like the 40106 is a simple power supply starve pot |
Ahhh.... That's a very interesting tip. I never tried that on my Lunetta, but I've had some experience with that on the Cracklebox.
Thanks...
You're from Sacramento. Do you know Stan? (probably) _________________ --Howard
danielwarner
Posted: Sat Feb 16, 2008 2:39 am Post subject:
| Nope, I'd not heard the name until I happened upon this sub-forum, I'd love to meet him or see him perform one of his instruments! |
jnuaury
Audio files: 9
Posted: Sat Mar 01, 2008 6:19 pm Post subject:
"analog" white noise actually works quite beautifully when plugged into a counter it works best when you find an interesting method of resetting the counter though some nice clicks and pulses can be found and used as audio or sent to logic as random gates
on the modular at my school some of my favorite sounds come from patching the noise into the logic modules |
jnuaury
Audio files: 9
Posted: Sat Mar 01, 2008 6:26 pm Post subject:
i second this technique! if you have multiple functions running off one chip and you "starve" it you can often get a simple circuit to that plays itself for awhile |
fluxmonkey
Rykhaard
Posted: Wed Jun 23, 2010 3:37 am Post subject:
| bbob wrote: | | also check out his other projects, like the experibass |
Whu'! Absolutely, speechless! (Great vid. editing as well. ) That, was amazing AND catchy! |
