Noise
Page 1 of 1 [14 Posts]
fluxmonkey
PostPosted: Tue Feb 12, 2008 6:28 pm    Post subject: Noise
Subject description: pseudo-random shift register
i have a simpler (3chip) design on my other machine, which I'll try to dig out... but Jim Patchell has a cadillac here:
http://www.oldcrows.net/~patchell/synthmodulesII/200-1021.pdf
Ken Stones Digital Noise is also based on CMOS, and you could sub a cmos gate oscillator for the PLL he uses...
fluxmonkey
PostPosted: Wed Feb 13, 2008 11:03 am    Post subject: Reply with quote  Mark this post and the followings unread
found it.... not sure, but I think Harry Bissell sent a version of this to me originally...
3chip CMOS noise source
 Filesize:  15.64 KB
 Viewed:  12393 Time(s)
fluxmonkey
PostPosted: Wed Feb 13, 2008 11:37 am    Post subject: Reply with quote  Mark this post and the followings unread
and after a bit of Googling, here's an earlier variant that includes a filter to derive pink noise as well...
 Filesize:  32.96 KB
 Viewed:  371 Time(s)
Audio files: 229
PostPosted: Thu Feb 14, 2008 3:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
These look like ways to make analog noise. In a Lunetta, you really don't need noise sources. Just run a few OSCs into a gate modulator and you'll have plenty of nice noise. Laughing
loss1234
PostPosted: Thu Feb 14, 2008 4:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
by gate oscillators do you mean an xor? could you explain? the only digital way i know of is with a shift register
thanks
Audio files: 229
PostPosted: Thu Feb 14, 2008 5:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Whatever gate you use with two audio rate signals gives you a lot of noise - that is a very broad bandwidth signal. Run two sigs like that through another gates and it will be very noisy.
But this isn't synthesis like additive or subtractive. This is something rather unique. You would never us a Lunetta to try to make some "sound". You use it to discover sounds that it can do.
loss1234
PostPosted: Thu Feb 14, 2008 10:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
ok i am excited to try this
dont worry, i am not after "realistic" sounds. i want the weird stuff Wink
so its as as simple as taking a 4001 and putting a different audio signal into each side of the gATE? wow
this is why a tutorial on all the little tricks would be great
thanks
danielwarner
PostPosted: Thu Feb 14, 2008 11:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
A nice way for getting noisy results out of CMOS like the 40106 is a simple power supply starve pot
Audio files: 229
PostPosted: Fri Feb 15, 2008 9:02 am    Post subject: Reply with quote  Mark this post and the followings unread
Ahhh.... That's a very interesting tip. I never tried that on my Lunetta, but I've had some experience with that on the Cracklebox.
Thanks...
You're from Sacramento. Do you know Stan? (probably)
danielwarner
PostPosted: Sat Feb 16, 2008 2:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Nope, I'd not heard the name until I happened upon this sub-forum, I'd love to meet him or see him perform one of his instruments!
jnuaury
Audio files: 9
PostPosted: Sat Mar 01, 2008 6:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
"analog" white noise actually works quite beautifully when plugged into a counter it works best when you find an interesting method of resetting the counter though some nice clicks and pulses can be found and used as audio or sent to logic as random gates
on the modular at my school some of my favorite sounds come from patching the noise into the logic modules
jnuaury
Audio files: 9
PostPosted: Sat Mar 01, 2008 6:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
i second this technique! if you have multiple functions running off one chip and you "starve" it you can often get a simple circuit to that plays itself for awhile
fluxmonkey
PostPosted: Tue Jun 22, 2010 7:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Diego Stocco - Bassoforte from Diego Stocco on Vimeo.
also check out his other projects, like the experibass
oops, wrong thread... meant to post this here
www.fluxmonkey.com
Rykhaard
PostPosted: Wed Jun 23, 2010 3:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Whu'! Surprised Absolutely, speechless! (Great vid. editing as well. Wink ) That, was amazing AND catchy!
