A VCA of sorts
Page 3 of 3 [59 Posts]
Goto page: Previous 1, 2, 3
gasboss775
PostPosted: Tue Apr 11, 2017 5:32 am    Post subject: Reply with quote  Mark this post and the followings unread
I wanted to try out the minimal configuration that would yield usable results. The attached images show the simulation results and schematic for a very basic VCA implementation which seems to work well ( at least on the simulator! )
Only works with Digital Signal Sources
The Pot adjusts the decay time.
The output is highlighted in green, the 2.8 Mohm represents the input impedance of a jfet buffer / mixer.
 Filesize:  68.86 KB
 Viewed:  741 Time(s)
 Filesize:  368.43 KB
 Viewed:  782 Time(s)
gasboss775
PostPosted: Tue Apr 11, 2017 11:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Bread-boarded this and it worked well the trigger source was from a 4017 counter. If the trigger source had a bit more muscle ( say from a 555 ) then the first circuit above would probably have sufficed.
 Filesize:  32.65 KB
 Viewed:  762 Time(s)
richardc64
Audio files: 26
PostPosted: Tue Apr 11, 2017 8:28 pm    Post subject: Re: Diode VCA & simple EG Reply with quote  Mark this post and the followings unread
gasboss775 wrote:
I tried this version of the diode VCA today. ( see attached )
R3 was found to be necessary to avoid signal breakthrough.
Without a resistor path to ground at the VCA output -- that is, if it's capacitor coupled -- the right-hand diode can be omitted, as below.
At +V = 9V, output level was more that adequate to drive my pc Line In without amplification.
 Filesize:  13.02 KB
 Viewed:  12361 Time(s)
gasboss775
PostPosted: Tue Apr 11, 2017 10:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks RichardC64, I was thinking about a drum circuit like that but not sure on component values, I'll definitely give this one a try!
gagarin
PostPosted: Thu Oct 05, 2017 3:46 am    Post subject: Re: Diode VCA & simple EG Reply with quote  Mark this post and the followings unread
How can I change attack time? What will be if I will use sine or saw as input signal?
gasboss775
PostPosted: Wed Nov 15, 2017 12:55 pm    Post subject: Re: Diode VCA & simple EG Reply with quote  Mark this post and the followings unread
How ca7n I change attack time? What will be if I will use sine or saw as input signal?
It's easy to add an attack control ( see attached ) this type of VCA can only work with logic / rectangular signals.
 Filesize:  86.4 KB
 Viewed:  714 Time(s)
airfrankenstein
PostPosted: Tue Apr 16, 2019 1:46 am    Post subject: Re: A VCA of sorts
Subject description: and simple EGs
Hi there,
So these simple circuits are entirely passive ?
richardc64 wrote:
At some point you'll want to hear the results of interconnecting all these digital circuits, and you'll probably want some dynamic control of the amplitude. The first circuit provides amplitutude control of digital waveforms without resorting to OpAmps, OTAs, or (ugh) cmos in linear mode.
Basically, as CV rises, the rectangular wave from the digital output to be heard "stands up" at the junction of the two diodes and passes through the 100K resistor and the coupling capacitor. This method was used in paia's Stringz-n-Thingz and a similiar technique was used in their Cosmic EGG.
Two simple EGs are shown, which don't really need much explanation. Select pot and cap values for the desired durations. The Gate Inputs should probably be buffered by an AND gate with both inputs tied together. If the output is to be routed many places, it can be buffered by a single-supply OpAmp such as the LM324.
gabbagabi
PostPosted: Thu Apr 18, 2019 5:12 am    Post subject: Reply with quote  Mark this post and the followings unread
i was forced to remember something as i saw the simulation screenshot
 Filesize:  57.98 KB
 Viewed:  508 Time(s)
 Filesize:  63.03 KB
 Viewed:  487 Time(s)
Steveg
PostPosted: Mon Apr 22, 2019 3:58 pm    Post subject: Re: A VCA of sorts
airfrankenstein wrote:
Hi there,
Welcome airfrankenstein,
No, they all have active components such as the transistors.
Passive is usually reserved for circuits that have no powered components.
Steveg
