analogmonster
Joined: Mar 28, 2006 Posts: 1438 Location: Kansas City, Mo USA
Posted: Wed Jul 02, 2025 5:00 am Post subject:
Re: 8 CV to MIDI converters Subject description: Control MIDI equipment with analog sequencers |
analogmonster wrote: | Hello everyone,
So I decided to build this as a set of eight independent microcontroller controlled CV/GATE/CLOCK to MIDI converters.
Each converter consists of a pair of inputs (CV and CLOCK) and a corresponding CLOCK display LED. |
Wow, that is a beautiful build and very useful module, indeed! Thanks for the video. _________________ -- Kevin
http://kevinkissinger.com |
The Peasant
Joined: Nov 13, 2009 Posts: 114 Location: Sunny Alberta
Posted: Wed Jul 02, 2025 9:05 am Post subject:
analogmonster wrote: | So I decided to build this as a set of eight independent microcontroller controlled CV/GATE/CLOCK to MIDI converters.
Very nice, please keep us updated of your progress. Do you plan on making this available to others?
Take care,
Doug _________________ The Electronic Peasant
www.electronicpeasant.com |
analogmonster
Posted: Wed Jul 02, 2025 10:58 am Post subject:
The Peasant wrote: |
Yes, I do. I've already started with the implementation of the next function, which will make the module being able to act as stand-alone MIDI sequencer additionally. When finished it can be selected by the top row switches.
Yes, I provide circuit diagrams, gerber files and the software for free and programmed microcontrollers and / or pcbs for cost rate to everyone who is interested. Just send me an email ( carsten[at]analog-monster[dot]de, mail address can be found on my web site as well ) _________________ Analogmonster: https://www.analog-monster.de/index_en.html
SoundCloud: https://soundcloud.com/analogmonster-1 |
analogmonster
analogmonster
The Peasant
analogmonster
Posted: Fri Jul 11, 2025 5:47 am Post subject:
Formant++; Subject description: UCVM - repair of a veteran |
My first microcontroller based module, an 8 channel MIDI2CV/GATE - interface (UCVM) from 2004 did not boot any more. Reason was a dead ISP connector.
So I did what I was afraid of, I opened it after several years and entered the guts.
Enjoy the pictures.
Description: |
Filesize: |
93.62 KB |
Viewed: |
50 Time(s) |
Description: |
Filesize: |
129.88 KB |
Viewed: |
46 Time(s) |
Description: |
Filesize: |
198.27 KB |
Viewed: |
48 Time(s) |
Description: |
Filesize: |
99.34 KB |
Viewed: |
34 Time(s) |
Description: |
Filesize: |
131.34 KB |
Viewed: |
39 Time(s) |
Posted: Fri Jul 18, 2025 9:37 am Post subject:
Power Supply Bus and CAN Channel Project |
Years ago, when I began expanding my synthesizer system, I needed to add an additional power supply and the associated wiring in the new cabinet. Wanting to ensure reliability, I chose to use larger 18 AWG wiring and robust TE connectors. This became the new standard for all added modules, and I built distribution cables to supply power accordingly.
Over time, however, I became less satisfied with the loose cable runs — they weren’t as secure as I’d like, were vulnerable to vibration, and didn’t look particularly neat. Still, redesigning the bus system was one of those "I’ll get around to it later" projects.
As I started adding microprocessor-based modules, I wanted to integrate a CAN bus to support global inter-module functions. That provided the push I needed. I realized I could use my 3D printer to create custom channel segments that support both the existing TE power connectors and new Molex CAN connectors.
The snap-in feature of the TE connectors made it relatively easy to design 3D-printed mounting holes to accommodate them securely. Since my printer's bed is only around 12" wide, I chose to print 3" channel segments (matching the Aries 3" module width), then arrange them end-to-end to form a continuous channel along the cabinet.
This is still a work in progress, but I recently completed the first cabinet channel and took a photo to show a before-and-after comparison — the top cabinet still has the original loose power cables, while the bottom cabinet uses the new channel. I’ve also included a picture of a few channel segments as they come off the 3D printer. For efficiency, I print them three at a time per batch.
Description: |
Power supply buss installation in progress to compare old and new |
Filesize: |
2.03 MB |
Viewed: |
52 Time(s) |
Description: |
Channel pieces from the 3d printer |
Filesize: |
1.54 MB |
Viewed: |
40 Time(s) |
Joined: Nov 23, 2015 Posts: 1318 Location: Netherlands
analogmonster
Posted: Sat Jul 19, 2025 2:19 pm Post subject:
Re: Formant++; Subject description: UCVM - repair of a veteran |
analogmonster wrote: | My first microcontroller based module, an 8 channel MIDI2CV/GATE - interface (UCVM) from 2004 did not boot any more. Reason was a dead ISP connector.
So I did what I was afraid of, I opened it after several years and entered the guts. |
Good troubleshooting! Seems that problems are caused by loose connections more often than not. Rare when it is some exotic problem! _________________ -- Kevin
Posted: Sat Jul 19, 2025 2:21 pm Post subject:
Grumble wrote: | I've made what I call a DRONER... |
That's a fine application for an Arduino-based device and a cool-looking case for it. Thanks for the video! _________________ -- Kevin
Posted: Sun Jul 20, 2025 1:28 pm Post subject:
I wasn't happy with the software and have been tweaking today.
Much better functionality now. _________________ my synth |
The Peasant
Posted: Sun Aug 10, 2025 8:57 pm Post subject:
I have completed the VCF module, 14 tubes in this one. Working on a video now.
Take care,
Doug
Description: |
Filesize: |
491.1 KB |
Viewed: |
19 Time(s) |
Description: |
Filesize: |
802.2 KB |
Viewed: |
25 Time(s) |
Posted: Tue Aug 12, 2025 5:02 am Post subject:
The Peasant wrote: | I have completed the VCF module, 14 tubes in this one. Working on a video now.
Take care,
Doug |
Indeed -- definitely want to hear your filter. 14 tubes? Wow. I don't think old TVs had that many tubes! _________________ -- Kevin
Posted: Tue Aug 12, 2025 7:21 am Post subject:
Great, I love tube stuff.
Although I learned electronics during the tube periode/start of transistor era (think oc71 etc.) I never build anything using tubes…. _________________ my synth |
Posted: Thu Aug 14, 2025 7:40 pm Post subject:
Fix for Aries AR-334 Sequencer Reset Behavior Subject description: A single component change solved a long-standing problem |
Well, I don't have a photo for this fix. However, I enjoy finding ways to make vintage modules work "better than new".
I recently solved a long-standing quirk in my vintage Aries AR-334 sequencer. When it received simultaneous clock and reset signals, it would jump to step #2 instead of starting cleanly at step #1.
Digging into the circuit, I found that the clock-in path included a 0.1 µF capacitor to ground in parallel with a 39 kΩ resistor. This RC combination slightly delayed the clock pulse compared to the reset pulse. When clock and reset arrived at the same time, the reset would trigger first, then the delayed clock edge would immediately advance the sequencer to the second step.
The fix was straightforward: I removed the 0.1 µF capacitor, leaving the 39 kΩ resistor in place. With the capacitor gone, the clock signal is no longer delayed, and the sequencer now resets and starts properly on step #1, matching the behavior of my other sequencers and clock dividers.
This will allow me to fully integrate the vintage Aries sequencer with my Klee and other sequencers (particularly Wren sequencers and the Elektron Octatrack sequencer). _________________ -- Kevin
Joined: Jan 31, 2003 Posts: 18249 Location: Durham, NC
Audio files: 226
Posted: Fri Aug 15, 2025 11:31 am Post subject:
I second the request hear a 14 tube filter  _________________ --Howard
my music and other stuff |
Joined: Dec 11, 2010 Posts: 1007 Location: Toronto, Ontario - Canada
Posted: Thu Aug 21, 2025 5:59 am Post subject:
Grumble wrote: | Your buttond reminds me of a device I made for a brother of mine: It works like a bass guitar and the buttons are arranged accordingly.
With the black and red buttons one can set the octave for the lowest snare ( the yellow buttons). |
That's awesome! A very unique layout. Nice work  _________________ JacobWatters.com |
Posted: Fri Aug 22, 2025 5:25 am Post subject:
Cynosure wrote: | My daughter drew the shape and painted it. I cut it out and added the electronics. |
That is delightful! I can see that she really enjoys it. _________________ -- Kevin
