Topics
Author
Replies
Views
Last Post
using TV to display audio signals
[ Goto page:
1 , 2 , 3 , 4 ]
dnny
84
266614
Sun Jan 19, 2014 9:33 am
BrotherJacob
....before you look elsewhere- have a look at this;
[ Goto page:
1 , 2 ]
75646
Sun Jun 05, 2011 10:18 pm
richardc64
Matell Synsonics Pro - different PCB
blakeAlbion
0
1155
Mon Aug 12, 2024 6:00 am
blakeAlbion
What tools to tighten nuts?
Circuit bending
gelg
4
2827
Wed Jan 24, 2024 9:55 am
Return 2 sendeR
Bit-crushing reverb: The ART DR2A
Adding switches to the DAC of the DR2A to force individual bits to 0
Christoffer
3
6654
Tue Nov 21, 2023 2:06 pm
djwizzz
Matrix Keyboard/Trigger/Circuit Bending Question
smmpcomposer
3
3328
Sat Mar 12, 2022 4:38 pm
Circuit Bent, or synth?.. Yamaha PSS-130
Built this demon
darklife
7
12700
Thu Nov 11, 2021 7:30 pm
PiercedFaceMan
Yamaha PSS 460, no sound! Amp La4500 replaced but nothing!
Stereokromatik
0
2059
Sat Oct 02, 2021 8:11 am
Stereokromatik
Casio SA-7 Diode specs
need info on D1 in the Casio SA-7 circuit
kapachuchu
2
3579
Wed Mar 31, 2021 2:03 pm
kapachuchu
(mis)Using the PT2399 delay chip as a high-speed oscillator?
Hashtag Octothorpe
21
23052
Tue Mar 09, 2021 12:47 pm
Hashtag Octothorpe
Before I fry it - Casio MT-205 bends?
atomforce80s
5
6185
Mon Mar 08, 2021 1:57 pm
atomforce80s
Bring the BAss
Cracked electronics producing sub/low freq audio and general low frequency sound appreciation
liamkw
0
2578
Fri Nov 13, 2020 12:30 am
liamkw
AM radio drum machine?
unsogno
2
4664
Sun Nov 08, 2020 1:57 pm
[zfgenerator]
Using capacitors with "manual PWM" switching and walkmans
cburn
2
3672
Thu Sep 17, 2020 3:56 pm
cburn
Casio SK1 power supply issues / understanding transistors
wax+wire
1
3703
Tue Jun 23, 2020 3:59 pm
Passive Mixer for keyboard and drum channels - Casio SK5
wax+wire
15
12141
Sun May 24, 2020 3:54 am
wax+wire
Voltage divider VS Voltage Regulator
MatthewMachinist
3
4260
Tue May 19, 2020 2:27 am
MatthewMachinist
Integrating a Yamaha keyboard into a homemade synth
kris
3
5456
Fri Mar 06, 2020 11:14 am
Toy solar system adding line out - Harder then expected
de:Beer
4
4964
Thu Jan 30, 2020 3:19 pm
JovianPyx
Running circuits on voltage control
Running a 4093 on CV?
Dr. K
4
4616
Thu Jan 16, 2020 9:51 am
JovianPyx
Bend Points Active Even When Not Physically Touching
southboundpachyderm
2
6074
Wed Jan 15, 2020 9:37 am
Power LED Blocks Audio in Bent Book Strip
southboundpachyderm
2
3767
Sat Jan 11, 2020 11:31 pm
southboundpachyderm
Great distortion bends but problem w/Line out & volume level
Nightrainbows
5
4842
Fri Dec 13, 2019 4:02 pm
getting started with delptronics bender
newbie questions
insearchof
0
3410
Wed Sep 11, 2019 8:53 am
insearchof
Hing Hon EK-001
[ Goto page:
1 , 2 , 3 ]
DETOX
52
115341
Fri Aug 23, 2019 10:49 pm
billrobin
Wiring a this Comparator for single supply ?
tl072 comparator
thepaddiscuile
8
8384
Fri Aug 23, 2019 6:59 am
Cyber Folk Book
new book on DIY electronic instrument building
DIGBEE
1
3915
Wed Aug 21, 2019 8:37 am
richardc64
Triggering toy from modular synth.
CrowleyE
3
4375
Fri Aug 16, 2019 7:36 am
TYCO HOT KEYZ schematic
noto
0
3295
Thu Aug 01, 2019 10:37 pm
noto
Three output Power Supply
Ground reference
FMB
2
4207
Mon May 20, 2019 3:17 am
FMB
PSS-170 Mod
stolenfat
1
5775
Fri May 10, 2019 4:14 pm
CHRISKELLY
Ordered a digital reverb.
transform into eurorack
7213
Thu May 09, 2019 5:24 am
ixtern
Yamaha PSS140 Volume Control
CHRISKELLY
3
4382
Mon May 06, 2019 1:28 pm
Voltage Regulator Overheating - Heat Sink Needs?
Troubleshooting big circuit bent project running off LM7806.
Cyeos
10
15870
Tue Dec 11, 2018 10:17 am
GlowSignal
SK1 + Bastl Kastle
cant find any info on what i stumbled upon last night
Lvithnn
2
5078
Tue Dec 04, 2018 4:32 am
ixtern
Augmentations for Casio MT65 Keyboard
gasboss775
8
13491
Mon Sep 17, 2018 9:34 am
gasboss775
replacing crystal with oscillator
stolenfat
7
9568
Fri May 11, 2018 12:58 pm
Sync pulse from LED?
Can I hack a tap tempo button to provide sync in/out?
kudamm99
8
10514
Sun Feb 11, 2018 5:42 pm
kudamm99
V-trigger to S-trigger stops when devices share ground?
Wirl
10
10432
Fri Jan 26, 2018 8:01 am
Disable split function on VSS200
I want to learn if it's possible to disable split keyboard function
Oortone
0
4218
Thu Jan 25, 2018 6:34 am
Oortone
Using Heat Sink On My Circuit
Marcus83
1
5093
Wed Oct 25, 2017 10:56 am
Hey are these any use ( ICs)
Shumba
3
7325
Fri Jul 07, 2017 2:43 am
LFLab
Advice Wanted re Hacking a USB controller
Avolites D4 Pilot has so much potential
Caravandal
1
5876
Sat Jul 01, 2017 1:46 pm
gdavis
Monotron 2 Octave keyboard project
01012k7
4
11091
Sun May 28, 2017 9:32 pm
J-chot
Taplfo project
help getting this things to work
samsam
10
13735
Wed May 03, 2017 11:17 am
samsam
Triangle wave amplitude
samsam
4
7907
Sun Apr 09, 2017 12:38 pm
samsam
Triggering Delay/Loop Pedal With Logic Chip?
samp
6
10920
Mon Mar 27, 2017 7:14 am
samp
bending Yamaha PSR-6
other Yamaha's too
[ Goto page:
1 , 2 , 3 , 4 ]
dnny
89
233541
Tue Mar 14, 2017 7:43 pm
SamVsSound
Is Alaron MySongMaker a Square Wave Synth like Hing Hon?
brainstormer
0
5048
Thu Mar 09, 2017 4:41 pm
brainstormer
Little Tikes Pop Tunes Keyboard
alienmeatsack
9
17277
Tue Mar 07, 2017 12:44 pm
SamVsSound
Display topics from previous: All Topics 1 Day 7 Days 2 Weeks 1 Month 3 Months 6 Months 1 Year
Sort by: Last Post First Post Topic Title Replies Views Author
Ascending Descending
