MadScientist
Posted: Thu Dec 08, 2011 9:15 pm Post subject:
Remember that wood is an very good thermal insulator. With your amazing cabinet, the heat generated inside can only be conducted away through the front panels, and that is assuming you won't be covering those with wood as well.
Adding to this is that your panels are tilted back, making it even more difficult to cool the inside through them.
For that reason putting the PSU inside the case may be asking for trouble, depending on how it is designed (linear, switched mode) and how much power you expect the completed synth to draw. |
diablojoy
Joined: Sep 07, 2008 Posts: 809 Location: melbourne australia
Posted: Fri Dec 09, 2011 2:12 am Post subject:
| Quote: | Adding to this is that your panels are tilted back, making it even more difficult to cool the inside through them.
heat is a good point. I will have to take some measurements once the cab is full though and then see if i need to add vents or not
My thanks to scrog productions for the idea for the power scheme
which i am still working on . It is a 18v-0-18v 300VA centre tapped torroidal feeding 8 x lm317/337 regulator boards [ only one is shown in pics ] via 2 x 35 amp bridge rectifiers and 4 x 18000uf caps
I expect to draw no more than 200-300mA max through each regulator so they should run pretty cool
I have also added a delay board to bring each reg board on line
one after another to limit the initial start up current. _________________ In an infinite universe one might very well
ask where the hell am I
as good an answer as any |
bubzy
Joined: Oct 27, 2010 Posts: 594 Location: United Kingdom
Audio files: 64
MadScientist
Posted: Sat Dec 10, 2011 6:24 am Post subject:
| diablojoy wrote: | [...] It is a 18v-0-18v 300VA centre tapped torroidal feeding 8 x lm317/337 regulator boards [ only one is shown in pics ] via 2 x 35 amp bridge rectifiers and 4 x 18000uf caps
I expect to draw no more than 200-300mA max through each regulator so they should run pretty cool.[...] |
If you wish, then I wouldn't mind giving your PSU configuration the full, custom mad scientist analysis, assuming you haven't done so already. I believe this would be worthwhile in this case, given how much effort you have spent on the project.
If so, then please measure the copper resistances of the toroidal transformer, primary and total (across 36V) secondary. The secondary resistance in particular is likely to be quite low, so a rough value will be quite adequate.
Also, I assume you are using 2x 18'000 uF for smoothing each unregulated supply rail, 4 in total? |
Posted: Sat Dec 10, 2011 10:50 am Post subject:
audio? i wanted to hear something... _________________
Tech Buddy at Random*Source |
Posted: Sat Dec 10, 2011 10:59 am Post subject:
That's a nice little box!
Yes... Sound?!  _________________ ACHTUNG!
diablojoy
Posted: Sat Dec 10, 2011 7:54 pm Post subject:
| Quote: | | Also, I assume you are using 2x 18'000 uF for smoothing each unregulated supply rail, 4 in total? |
yes,
just after the rectifiers.
will try to take some measurements when i get home
| Quote: | | audio? i wanted to hear something... |
yes please so do I
nice mix of modules bubzy _________________ In an infinite universe one might very well
Joined: Dec 11, 2010 Posts: 1028 Location: Toronto, Ontario - Canada
Posted: Sun Dec 11, 2011 1:51 pm Post subject:
so you finally accomplished it? great! will have to wait until tomorrow to watch the vid, though. i am realy looking forward to it! _________________
umschmitt
Posted: Sun Dec 11, 2011 2:59 pm Post subject:
Wow ! Beautiful & brutal synth ! With lots of radical options it seems ! Nice use of a LED display, too. _________________ ::U::N::S::C::H::N::E::L::L:: |
EdisonRex
Audio files: 172
Posted: Sun Dec 11, 2011 3:39 pm Post subject:
Good demo, Jacob. You've done awesomely.  _________________ Garret: It's so retro.
inlifeindeath
Joined: Apr 02, 2010 Posts: 316 Location: Albuquerque, NM
Posted: Sun Dec 11, 2011 3:52 pm Post subject:
sounds great! glad you got it done as well!
i like the 'things i learned' section on your site as well haha _________________ http://www.youtube.com/user/borisandfef |
wmonk
Joined: Sep 15, 2008 Posts: 529 Location: Enschede, the Netherlands
Audio files: 15
Posted: Sun Dec 11, 2011 4:40 pm Post subject:
Wow Jacob, that is really awesome! and sounding real funky
Heh, and the video looks a lot more CMOS compared to your professional vids  _________________ Weblog! |
Joined: Mar 28, 2006 Posts: 1472 Location: Kansas City, Mo USA
Posted: Mon Dec 12, 2011 1:06 pm Post subject:
Cool equipment from Bubzy and Cynosure.
The CMOnSter's sound is bigger than life! _________________ -- Kevin
http://kevinkissinger.com |
Posted: Mon Dec 12, 2011 1:20 pm Post subject:
a new track with my modular synth |
btw -- in case you didn't notice, I just posted a track from my DIY modular:
http://electro-music.com/forum/topic-51049.html
In particular, it showcases the some of the Yusynth filters: (the VCS filter clone, the Steiner filter clone, and the Fixed Filter bank). I also used the fonitronic Voltage-controlled Ring Modulator, and some CGS modules (Super Psycho Modulation Source, Wave shaper, Modulo magic), too. _________________ -- Kevin
Posted: Mon Dec 12, 2011 6:14 pm Post subject:
Thanks for all the kind words. I'm glad you guys like the sounds it makes. I'm very proud of my little monster synth.  _________________ JacobWatters.com |
umschmitt
Posted: Tue Dec 27, 2011 12:36 am Post subject:
haha! what a nice build. look like the ultimate christmas pinball machine to mee... _________________
Captain Biscuits
Joined: Jun 11, 2010 Posts: 116 Location: Northampton, UK
Posted: Wed Jan 11, 2012 3:57 pm Post subject:
A Modular is never Finished but . . . Subject description: mine has reached a sort of "that'll do for now" moment. |
Been building bits of this for about 2 years on and off I guess starting with an MFOS mini synth, then an MFOS 10 step, 3 VCOs, etc etc
Finally completed a case with 2 LFOs, a dual AR EG and a low pass filter around Christmas.
Planning to play with some CMOS/Lunetta bits to get some interesting beats (largely based on Bruce's You Tube Vid of his Quad bass and lunetta combo) next.
Then there's a Klee part made which needs finished and 2 or 3 Thomas Henry VCOs to make up.
Oh - and a Chaquo pcb on the way from the Bridechamber and an MFOS MFM to play with - and an Appendage board in a cupboard somewhere
So not finished - but it's reached a point where I'm kind of chuffed with it at last and enjoying playing with it!
556.79 KB |
| Viewed: |
452 Time(s) |
297.11 KB |
| Viewed: |
410 Time(s) |
Joined: Jan 31, 2003 Posts: 18290 Location: Durham, NC
Audio files: 235
Posted: Wed Jan 11, 2012 5:31 pm Post subject:
Re: A Modular is never Finished but . . . Subject description: mine has reached a sort of "that'll do for now" moment. |
| Captain Biscuits wrote: | | Been building bits of this for about 2 years on and off I guess |
looks amazing... _________________ --Howard
my music and other stuff |
Posted: Wed Jan 11, 2012 6:45 pm Post subject:
Captain Biscuits - I love the panel designs! _________________ JacobWatters.com |
fluxmonkey
Posted: Thu Jan 12, 2012 6:37 pm Post subject:
if you didn't click on Cap'n B's pics to get the fullsize closeups, go back and do it now! wonnerful on all counts, CB.
on a side note, innit time for a new 2012 build thread? _________________ www.fluxmonkey.com |
