2011 Build Pictures
Page 9 of 19 [453 Posts]
Goto page: Previous 1, 2, 3, ..., 7, 8, 9, 10, 11, ..., 17, 18, 19 Next
RF
Audio files: 28
New postPosted: Tue May 24, 2011 6:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just finished the upper Drum box and this case to add to my original drum voices and pattern generators (in the lower section)
The new box includes the Thomas Henry MPS, Rich's Liquid Hi Hat, 2 Fritz AD/AR coupled with simple VCA's, two 4069 LFO's, Foniks VC Clock and VC Pattern Sequencer, and a simple mixer.
The Lower box is four Bass++ voices, two XOR gates, two 4 input R/2R ladders, 3 clocks, CGS pulse divider and some shift registers, counters and such.
The VCPS and VC Clock for drums is Exclamation
 Filesize:  79.83 KB
 Viewed:  32095 Time(s)
www.sdiy.org/rfeng
midgetfidget
New postPosted: Tue May 24, 2011 9:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Paradigm X wrote:
jodroid, that looks amazing Shocked Smile
Feel a bit daft posting this now (Razz) but Ive finished my first evar x0xb0x !! Well chuffed. Ive since discovered the MIDI in needs looking at but otherwise it sounds and looks (IMO) amazing Very Happy
Ben
Where did you get that case? I'm looking at rehousing mine. Left mine in the sun for a few minutes and it warped and melted Shocked
New postPosted: Tue May 24, 2011 11:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
what a nice built Cool
did you add a gate out for each step of the sequencer?
Paradigm X
New postPosted: Tue May 24, 2011 11:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Christian/Substyler at www.x0xsh0p.de
Drop him an email i dont think theyre in his webshop
Smile
midgetfidget
New postPosted: Thu May 26, 2011 6:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
furio
New postPosted: Fri May 27, 2011 4:26 am    Post subject: Reply with quote  Mark this post and the followings unread
CGS65 - Tube VCA (Today's New Front Panel)
 Filesize:  100.41 KB
 Viewed:  31738 Time(s)
TubeVCA-CGS65-14TE_v2.pdf
 Filename:  TubeVCA-CGS65-14TE_v2.pdf
 Filesize:  20.65 KB
 Downloaded:  322 Time(s)
New postPosted: Fri May 27, 2011 4:59 am    Post subject: Reply with quote  Mark this post and the followings unread
so you are using the Mankato as a slew limiter, too? THAT is consistent! Very Happy
furio
New postPosted: Fri May 27, 2011 5:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you Matthias, the Monkato is under construction, but this are my best 2011's working filters...
 Filesize:  101.3 KB
 Viewed:  31674 Time(s)
AnalogCustom
New postPosted: Sat May 28, 2011 1:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Mini Synth in compact size (10x20cms).
Oscillator, Sub oscillator -1, Sub oscillaror -2
Moog Filter, ADSR
LFO
AMP, ADSR
Pulse Width Modulation.
CV and Gate inputs.
Audio out.
Saludos!
Marco.
New postPosted: Sat May 28, 2011 10:17 pm    Post subject: Two Yusynth VCAs
Subject description: Just filled up another cabinet -- going to take a break (temporarily!)
Well, this module brings me to a milestone -- namely that I've now completed another complete row (the top cabinet).
I made a decision to use this as a "stopping point" (at least for now) and to once again focus on music-making rather than instrument building.
I love both of these activities and there is always an inner-battle between the desire to build and the desire to make music.
Of course -- there are plenty of things I want to tweak and a couple of functions I will be adding -- but probably not until next winter.
On this site I find support and guidance and I appreciate you all.
I enjoy this thread -- fun to see all the different designs and approaches to DIY -- as fun as it can be to walk through a musical instrument store -- to see original instruments with original designs is all the more fun and enlightening.
The front panel for two Yusynth VCAs.
 Filesize:  176.29 KB
 Viewed:  31433 Time(s)
View of the PCBs and front panel components.
 Filesize:  175.35 KB
View of the entire synthesizer -- this module completes the top row of modules.
 Filesize:  190.29 KB
Inventor
Audio files: 267
New postPosted: Sat May 28, 2011 11:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Kevin, it looks like the monolith...
"My God, it's full of stars!"
Les
New postPosted: Sun May 29, 2011 7:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Les
LOL -- thanks, Les.
Well my break from building is temporary of course. I still have some more k/s units to build Wink
New postPosted: Mon May 30, 2011 9:53 am    Post subject: My first module
Subject description: V8 Simulator
my first module: Ken Stone's V8 Simulator.
I added an extra switch for a much slower speed which gives a nice rhythm,
and a LED which acts as a speed monitor. The panel was already this color
(cut form a piece of 'scrap' metal) but I might do some labeling in the future.
(more photos)
 Filesize:  18.95 KB
 Viewed:  194 Time(s)
 Filesize:  51 KB
 Viewed:  205 Time(s)
New postPosted: Mon May 30, 2011 10:00 am    Post subject: Skip Step baby 10 Reply with quote  Mark this post and the followings unread
And the 2nd one:
Baby10 based sequencer with skip function and +/- output voltage.
(more photos)
 Filesize:  30.6 KB
 Viewed:  185 Time(s)
 Filesize:  53.8 KB
 Viewed:  187 Time(s)
New postPosted: Mon May 30, 2011 12:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice builds PHoBoS, i like the sequencer Smile
furio
New postPosted: Mon May 30, 2011 1:51 pm    Post subject:   Reply with quote  Mark this post and the followings unread
bravo PHOBoS !! I like your sequencer too Very Happy
furio
New postPosted: Mon May 30, 2011 2:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
I have a another one ARP 4072 VCF Very Happy
 Filesize:  153.9 KB
 Viewed:  189 Time(s)
ARP4072-14TE.pdf
 Filename:  ARP4072-14TE.pdf
 Filesize:  36.29 KB
 Downloaded:  190 Time(s)
New postPosted: Mon May 30, 2011 2:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Dave and thanks furio, I really like your bright colored panels and those knobs Smile
kupfer_m
New postPosted: Sat Jun 04, 2011 6:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Recently finished :
Yusynth VCLFO and CGS Double Wasp VCF
-minus-
New postPosted: Sat Jun 04, 2011 6:52 am    Post subject: Reply with quote  Mark this post and the followings unread
I haven't checked the build thread for some time. Sometimes I think my addiction is pretty bad and I need professional help... then I see what you guys are doing! Shocked Some of you must have teams of engineers working for you! Either that or I seriously have to pull my finger out and work a lot harder. Well done everyone! This is really inspirational... or a big worry. Laughing
New postPosted: Sat Jun 04, 2011 8:09 am    Post subject: Reply with quote  Mark this post and the followings unread
kupfer_m wrote:
CGS Double Wasp VCF
nice clean labortorial look.
what rotary switch you are using? seems to be quite small...
furio
New postPosted: Sat Jun 04, 2011 8:51 am    Post subject: Reply with quote  Mark this post and the followings unread
fonik wrote:
kupfer_m wrote:
CGS Double Wasp VCF
Yeah kupfer_m ...made a very nice "clinic" design =)
I have used the Mini Rotary Switch form Musikding for my CGS Twin Wasp.
 Filesize:  64.34 KB
 Viewed:  30640 Time(s)
AnalogCustom
New postPosted: Sat Jun 04, 2011 3:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Chainable, 9 Step Analog Sequencer - MIDI to Sync:
Analog Sequencer (LOOP and END mode)
Inputs: Clock; HOLD; Reset Pulse; Reset Trigger
Ouputs: END state; END Trigger; RUN state; GATE, CV.
Marco.
kupfer_m
New postPosted: Sat Jun 04, 2011 11:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
fonik wrote:
kupfer_m wrote:
CGS Double Wasp VCF
I used an older switch salvaged from some old equipment.
It has a long shaft so it extends a few cm behind the pots.
New postPosted: Sun Jun 05, 2011 1:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
that's what i did last week (just for completeness):
