2011 Build Pictures
Page 7 of 19 [453 Posts]
Goto page: Previous 1, 2, 3, 4, 5, 6, 7, 8, 9, ..., 17, 18, 19 Next
PostPosted: Tue Apr 26, 2011 6:58 am    Post subject: Reply with quote  Mark this post and the followings unread
i built a new module combining a simple divider and attenuverters. this is what i use my existing attenuverter and a divider for frequently: nice sequencing.
this module is bipolar and it is working quite nice. i still have to straighten out some minor issues...
nevertheless, sometimes it is good to build something just to recognize that you don't need/want it!? i mean, why bipolar? since i use it for sequencing, and since i use quantizers i would do fine with a unipoar module. so i will redesign/simplify the whole thing, i believe...
vladosh
Audio files: 51
PostPosted: Tue Apr 26, 2011 10:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi all ..
I know it's not really good looking (comparing) ,but i was in a rush to play it .. it's not much it's just the doepfer diy synth with 2 more lfo's added .. and a dual which needs to be wired .. two sample and holds splitters ,clock ,noise gen .. and the bugbrand dual pattern gen which i'm wiring right now ... thanks to everybody in the forum they've been understanding for my dumb questions
greetings
vlad
 Filesize:  57.45 KB
 Viewed:  20887 Time(s)
diablojoy
PostPosted: Tue Apr 26, 2011 3:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
hi mathias great looking module as always
not certain i am understanding what it does though
Bipolar adjustment of CV at specific clock divisions ?
I presume the jacks next to each attenuverter pot are CV inputs and
as each division is reached that modified CV is sent to the bottom CV out jack
is this close ? I could see how negatively modified CV's could be desirable
but as you say not so when quantizers are used after
cheers
PostPosted: Tue Apr 26, 2011 11:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
each of the 4 dividers outputs are sent to an attenuverter. this voltage is then sent to a single out, and to the sum. so at the SUM out you get stepped voltages (see screenshot below). it works at audio rates too.
for the next module i will just have attenuators, and the divisions will go to the single outs w/o attenuation.
 Filesize:  19.32 KB
 Viewed:  20728 Time(s)
diablojoy
PostPosted: Wed Apr 27, 2011 3:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
ah very interesting and a somewhat different approach. i like it
will look forward to hearing more.
BananaPlug
PostPosted: Wed Apr 27, 2011 6:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
I use a Binary Zone (bipolar) and find that even when feeding a 0-5V quantizer it's nice to have the bipolar adjustments. Yes, the negatve voltages get clipped but that can be a nice effect. In any case when "composing" I find it easiest to start in the middle (pitch) and work positively and negatively from that point.
I like that you have the separate outputs on your.
adambee7
PostPosted: Wed Apr 27, 2011 9:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
be nice to hear some mp3s Very Happy Very Happy
AnalogCustom
PostPosted: Thu Apr 28, 2011 4:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Analog Drum Synth, based on Syntom and Synbal projects:
http://electro-music.com/forum/post-143647.html
Syntom - Syntom - Cynbal - Cynbal - MIX - LP Filter - Ring Mod and Oscillator
Demos (only drum modules):
https://sites.google.com/site/cardenassynthruments/config/pagetemplates/bateria-electronica/DemoAnalogDrum.wav
https://sites.google.com/site/cardenassynthruments/config/pagetemplates/bateria-electronica/DemoAnalogDrum2.wav
bass drum:
https://sites.google.com/site/cardenassynthruments/config/pagetemplates/bateria-electronica/bombo.wav
snare:
https://sites.google.com/site/cardenassynthruments/config/pagetemplates/bateria-electronica/caja.wav
hi-hat 1:
https://sites.google.com/site/cardenassynthruments/config/pagetemplates/bateria-electronica/charles1.wav
hi-hat 2:
https://sites.google.com/site/cardenassynthruments/config/pagetemplates/bateria-electronica/charles2.wav
cymbal:
https://sites.google.com/site/cardenassynthruments/config/pagetemplates/bateria-electronica/plato1.wav
synth tom:
https://sites.google.com/site/cardenassynthruments/config/pagetemplates/bateria-electronica/tomelectronico.wav
*edit*
Drum synth (syntom and ring) + Sample and hold:
https://sites.google.com/site/cardenassynthruments/config/pagetemplates/bateria-electronica/drumsynth_s%26h.mp3
Drum synth (syntom and ring) + Sample and hold (trigger) + ENV (frec mod. oscillator)
https://sites.google.com/site/cardenassynthruments/config/pagetemplates/bateria-electronica/drum2.mp3
sl2!
Marco Antonio.
Danno Gee Ray
PostPosted: Thu Apr 28, 2011 5:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Very nice build indeed!!
PostPosted: Thu Apr 28, 2011 11:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
great build.
i have something similiar on my agenda for 3 years now, and i postpone it from year to year Crying or Very sad
tjookum
Audio files: 26
PostPosted: Fri Apr 29, 2011 4:06 am    Post subject: Reply with quote  Mark this post and the followings unread
It has been a while since I posted here but I finally have something to show.
youtube description:
This project has been a long time coming, but the first prototype is finally done. Still some minor changes to be made, mainly around the filter and a CV input for the filter. Im currently developing a kit, contact me if you're interested.
-2 triangle oscillators with fine tune knob for those tearing slow drones.
-2 triangle LFO's with interchangable capacitors to set the range.
-LFO amount for both sides
-LED reflector rate indicators
-custom filter with resonance control
-on/off and volume
sorry for the bad video quality, my camera is old and doesn't like low lighting conditions. The audio was recorded raw into ableton live directly from the output without any filtering or effects.
And here are the first 2 tracks made with the machine:
26-04-2011 sticky tape by Tropical Benny
Oregano 29-04-2011 by Tropical Benny
 Filesize:  1.31 MB
 Viewed:  283 Time(s)
 Filesize:  1.24 MB
 Viewed:  233 Time(s)
Hunter S. Thompson
movies
noise
PostPosted: Sat Apr 30, 2011 3:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Excellent Tjookum! Very Happy
sounds great and makes me wonder how you did those LED indicators.
adambee7
PostPosted: Sat Apr 30, 2011 5:16 am    Post subject: Reply with quote  Mark this post and the followings unread
That sounds like it could level a building. nice and deep. you've come a long way mate since i first noticed you in the lunetta forum. great stuff. Very Happy Very Happy
furio
PostPosted: Sat Apr 30, 2011 6:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Dual High Performance OPA2134 CGS MIXER/INVERTER
 Filesize:  542.85 KB
 Viewed:  211 Time(s)
tjookum
Audio files: 26
PostPosted: Sat Apr 30, 2011 6:49 am    Post subject: Reply with quote  Mark this post and the followings unread
I always take apart all kinds of stuff and I found these little reflector bars under an LCD screen as backlight. They have little grooves on one side and they are sloped on the other so the light is spread sort of evenly.
Laughing my neighbour agrees.
thanks
Hunter S. Thompson
movies
noise
PostPosted: Sat Apr 30, 2011 1:05 pm    Post subject: Modular PSU
Subject description: +/- 15V 2x1A
Just finished the +/-15V 2x1A PSU for the modular. Smile
I've chosen for connectors instead of a direct connection between the panel
and the actual PSU, so it's easy to take it out. Because I don't have another
PSU for testing modules and it also makes it easier to replace it in case I
need to upgrade to a more powerfull one. I still have to make something to
distribute the power to the modules but haven't found the right connectors
yet.
 Filesize:  32.76 KB
 Viewed:  213 Time(s)
 Filesize:  52.6 KB
 Viewed:  216 Time(s)
PostPosted: Sat Apr 30, 2011 3:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
i like the fresh colors Very Happy
PostPosted: Sat Apr 30, 2011 4:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice color scheme. I also like the idea to include the make of the circuit (Yusynth, CGS, Fonitronic, etc) on the front panel. It documents the lineage of the circuits and likely brings a smile to the faces of the people who so generously share these circuits.
Ironically, though my synthesizer is an Aries synthesizer, now it is only about 1/3 Aries due to the additions over the last year.
furio
PostPosted: Sun May 01, 2011 1:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanx fonik & Kevin ...It is really nice to get compliments from Synth Guru's Smile
I have used a CGS70 PCB (Dev-mod Mixer/Inverter block) http://www.cgs.synth.net/modules/cgs70_mix.html ...I do not have electronic knowledge, but with the OPA2134 instead off the TL072, sounds better and deeper. I have used low noise resistors and cheapers 47pF ceramic caps http://www.reichelt.de/?ACTION=3;ARTICLE=9297;GROUPID=;SID=13Tb0O5X8AAAIAAD@NgSk80f28f7e58da9ed3910a9e0820ac8f3e
Maybe it would be possible to improve it more with some lower pots/resistors values, better caps and LM4562.
 Filesize:  448.53 KB
 Viewed:  248 Time(s)
tjookum
Audio files: 26
PostPosted: Sun May 01, 2011 3:09 am    Post subject: Reply with quote  Mark this post and the followings unread
What a beauty, I really like the attention to detail and the black perfboard. What schematic did you follow?
Hunter S. Thompson
movies
noise
furio
PostPosted: Sun May 01, 2011 4:54 am    Post subject: Reply with quote  Mark this post and the followings unread
CGS66 MOD Regulated Power Supply - Airflow improved, Dual Doepfer BUS (6x2) & Euro mounting optimized. Please don't ask for the PCB file from me, I have lost this file (the HD is dead) http://www.cgs.synth.net/modules/cgs66_psu.html
 Filesize:  632.75 KB
 Viewed:  208 Time(s)
PostPosted: Sun May 01, 2011 7:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Smile
It's pretty much the basic LM317/LM337 schematic from the datasheet, which
is similar to the Ken Stone CGS66 +/- 15 Volt Power Supply but with some different
component values. (4700uF/35V Caps, 240/2K4+500R trimpot)
furio
PostPosted: Sun May 01, 2011 1:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
CGS Tube VCA, after the picture I added the feedback feature with a wire from the Output to the 3rd Input switch.
 Filesize:  352.69 KB
 Viewed:  225 Time(s)
PostPosted: Sun May 15, 2011 8:16 pm    Post subject: A new Yusynth Dual Autobend Reply with quote  Mark this post and the followings unread
Just finished up this module. Its function is quite simple: when it receives a gate signal, the module generates a "bend" (transient voltage).
Front Panel of the Yusynth Autobend.
 Filesize:  1.08 MB
 Viewed:  227 Time(s)
The PCB: Yves' design is a PCB with two, independent, identical autobends. Thus, single and dual versions are possible. You will likely notice the two identical layouts on the board.
 Filesize:  1.92 MB
 Viewed:  242 Time(s)
Danno Gee Ray
PostPosted: Mon May 16, 2011 3:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
In 2357 Archeologists will unearth definitive evidence that Kevin Kissinger was, in fact, a machine...
