monobass
G2 patch files: 12
Posted: Sat May 12, 2007 6:56 am Post subject:
I understand the reasoning about not including 'sampling' type things in the list but I completely disagree with leaving it out... it defeats the object of a poll. It's hardly democratic when your choices are artificially limited.
We all know the delay lines could be changed in simple ways which would make live sampling easier to do. There is a massive demand for it so leaving it off the list would be disingenuous.
If you want to end up with a shortlist of a certain size then the only fair way to do it is a series of polls with less choices everytime, or a large poll.. there's no way getting around it. Those with the best arguments laid out will get the most votes i'm sure... _________________ Steve |
SecretAsianMan
Posted: Sat May 12, 2007 8:14 am Post subject:
| Yup. You put all of the suggestions up for vote, have some debate on them, then call the vote. |
The Why Project
Posted: Sat May 12, 2007 9:54 am Post subject:
Please don't forget this one:
Store more variations per patch. (Alternative solution has already been
proposed by Dasz: Muteless Patch/Performance loading).
Regards,
The Why Project |
varice
Joined: Dec 29, 2004 Posts: 961 Location: Northeastern shore of Toledo Bend
Audio files: 29
G2 patch files: 54
Posted: Sat May 12, 2007 10:33 am Post subject:
| 3phase wrote: | Another thing that cant be patched... The voice allocation mode...
Every time when i try to emulate an old synth with its playing fun i fail because of the bloody round robbin allocation of the G2..i really hate it..
It always is robbin voices...
For example when patching a 101..a pro one..a jx-3p
all this synths allow to play while the internal sequencer is running.. its great... you play chords over a repetitive sequence...
easy to patch..but it don't works with round robbin...the notes of the chords you held will get stolen...
So a very important wish that would allow the G2 to do proper emulations of classic synths and better interactive sequencer patches and would solve some other related problems in special patches...
And cant be patched in any way...
We need an alternative allocation mode... i even wouldn't care if round robbin goes totally..but there might be patches where this is better...
so 2 allocation modes... |
Yes - we need at least a "repeat" mode. See this in the Wish List:
http://electro-music.com/forum/topic-15459.html
The poly voice allocation mode needs to set at the patch level. _________________ varice |
dasz
Joined: Oct 16, 2004 Posts: 1644 Location: victoria, canada
Audio files: 29
G2 patch files: 56
Posted: Sat May 12, 2007 11:28 am Post subject:
Feature #12 - don't forget mute less switching when loading an identically wired patch (to the currently loaded one) all modules and connections are identical, just different variations.
Bug #1 - loop changes reset sequencer to step 1 (incorrect behavior - terrible in a live situation). In NM1 the loop change went into effect only once the current steps exceeds the loop point (correct behavior)
/Dasz Last edited by dasz on Sat May 12, 2007 11:30 am; edited 1 time in total |
3phase
G2 patch files: 141
Posted: Sat May 12, 2007 4:50 pm Post subject:
| _ Steve _ wrote: | I understand the reasoning about not including 'sampling' type things in the list but I completely disagree with leaving it out... it defeats the object of a poll. It's hardly democratic when your choices are artificially limited.
Artificial limited? its the limit of the hardware architecture and of cause a fantastic wish like sampling capabilitys would gain high votes in a poll..
but..its like if we would like to improve a car and say we want it able to swim...good idea..but unrealistic...
So a general sampling wish wouldn't do any good because that basically asks for a new machine...
I however would think that it would be cool to have a module that allows to access the ram in more creative ways...
so a wish for a delay with modulate able read out rate and freeze function would be cool and has some useful applications like long lofi delays with low memory consumption and even some kind of real time sampling mungeling fx...
but thats the maximum a g2 could do..
so its good to prohibit the sampling wish ... its better to wish for a module that is realistic possible that might allow us some sampling fx...
That would probably have a higher chance to get Clavias attention than unrealistic wishes... to much unrealistic wishes would discredit the whole wish list as the work of unrealistic dreamers... Last edited by 3phase on Sat May 12, 2007 7:35 pm; edited 1 time in total |
monobass
G2 patch files: 12
Posted: Sat May 12, 2007 5:02 pm Post subject:
Yes what you are describing is what some people might call 'sampling'. Others have a different idea.
Just let people decide what they want to vote for.
For once this forum could just hang back on the taxonomy  _________________ Steve |
3phase
G2 patch files: 141
Posted: Sat May 12, 2007 5:23 pm Post subject:
So my wishes are...
1) improved sound... the g2 lacks something in relation to the Nm1..its subtile and it might be related to a bug or a change in gain structure...
basically nm1 and g2 sound identical..but when we reach overloaded states in feedback loops the NM1 sounds much smoother... i would like to see the G2 improved there more than anything else. It might be subtile but would give the intstrument a bigger boost on the long run than new features...
because this is very in the main dsp infrastructure i put this wish to 1) because i personally think that this might be a point where clavia at least should investigate and make sure that this really have to be this way..
maybe its just a little adjustment..these subtile things not necessarily have to have big causes..but aslong nobody sees a problem nobody takes the effort to check the item...
2) new sequencer modules...
a) multi pattern/ poly sequencer... it either acts as a monophon sequencer with multiple edit pages that can be selected by a control...
or it works in poly mode than the different edit pages show the individual voices...
it should be able to record like the actual sequencer..that could be replaced by the new one...
It also could allow to record more than 16 steps...
And give us a control to navigate thru the edit window..
This way we could only assign 4 steps to the controls of the G2..and have to knobs for voice navigation and edit position navigation and achieve full polyphone edit possibility for up to 128 steps with just 6 knobs...
with an additional setting where only the edit position is read out...and mod inputs for the navigation this module could act as a 3 dimensional ram table... a rough one..but nevertheless an interesting module ...
So such a big poly sequencer would allow to store polyphone data...act as multi pattern sequencer... act as 3 dimensional or polyphone ramtable...
allows detailed editing without assigning all steps to knobs...
In addition to this we would need a record able gatetime sequencer..one that just records gatetimes an has a trigger puls on each gate step and a independent gate time output that stays high during the gate is up..
The trigger out steps our poly note sequencer...
the gate time sequencer should be variable quantized... so from 16th to 96th notes ... this is good enough for a synthesiser because otherwise we get problem to keep it edit able... within the quantization setting we can scroll thru a grid similar to the note sequencer..but just with to lines..the triger point ..and the gate time...
i think it would be enough if the gate time sequencer is monophon..but better of cause polyphone.. editing similar to the poly note sequencer...
but no mod inputs..
Ok..just dreaming...but i was so much into sequencer patching with the G2 that it boiled down to just 2 modules that are missed.. polyphone note info..and gate times...
I managed to patch such thing but it eats slots... but...
I successfully used such patches on stage..a real bringer to be able to record some chords and be able to store that and get back to it later... in an live edited version...
So my first 2 wishes..the other 3 in the next post... Last edited by 3phase on Sat May 12, 2007 6:39 pm; edited 1 time in total |
3phase
G2 patch files: 141
Posted: Sat May 12, 2007 5:30 pm Post subject:
| _ Steve _ wrote: | Yes what you are describing is what some people might call 'sampling'. Others have a different idea.
For once this forum could just hang back on the taxonomy  |
Lets do it another way...
Just as i did with the 2 wishes above...
we vote in the end for wishes where we present an idea how that could look! so just asking for sampling would be to easy..you need to describe a module and what this module should do... within the limits of the given architecture..
so you might ask for a delay module that can freeze a sound and replay it on a trigger pulse... with a variable rate...
actually that would be a pretty cool module...
And you are wright..that is sampling....
But !
you cant ask for transferring that sound via usb or store it in the machine... what would be actually real sampling...because thats beyond the limits of the actual architecture and therefore unrealistic.
What i want to say..if we have feature wishes we should describe how this could be realized.. than its easy to see what looks possible and what not...
so..you are wright..lets allow to to ask for sampling modules... but in a realistic way in form of a module that is actually a variation of a delay module... Last edited by 3phase on Sat May 12, 2007 7:36 pm; edited 1 time in total |
3phase
G2 patch files: 141
Posted: Sat May 12, 2007 6:04 pm Post subject:
So.. i want to limit me for 5 wishes...
Wish 3... is actually a trick that would give clavia some work...
3) support of the Nm1 to G2 conversion utility to add all old structures that cant be easily patched and therefore allowing full sound compatibility... with the aid of g2ools
So i call this wish :
Inclusion of missing NM1 functions
-Morphs on switches
-Fixed filter bank
-mini delay module that accesses the dsp memory as on Nm1
(24bit with sweet sound for tuned delay lines)
-original overdrive
( the new overdrive is nowhere as good on polyphonic sounds.. the old overdrive is more musical useful and has nice modulation propertys )
These are the main issues...
and to be complete but roughly possible to be patched
-spectral oscillator... lets get rid of the shape osc b...
-formant osc
-5stage envelope
With this additions the NM1 lib would be properly convertible..
And the G2 would win with the first main issues soundwise a lot...
especially the nm1 overdrive is very powerfull for creating subtile fatness and rude am like modulations...things we don't get with our given g2 modules...
And the dsp intern delay line makes much sweeter physical modeling sounds..
especially this wish could be maybe obsolete when wish one is featured..maybe the sweetness is not related to the 24 bit..maybe its the more noise feedback behavior of the g2 that makes the difference when using the given delay modules...
Wish 4)
The mentioned exclusion of parameter from variation changes...
maybe as
A special value module that can be used to create values that just are the same in all variation locations... probably the easiest way to realize that..
Maybe all parameters that are assigned to the global page could be variation independent?
Or just allowing any parameter to be excluded..but that might be a heavy task
Wish 5)
The already mentioned Midimodule master setting...in addition with midi functions on patch level
So all midi send modules get additional to the given settings a M setting where the send channel is controlled by the patch settings parameters...
there we can select channel 1-16.. the 4 slots..but also Off and! Same...
So the send modules send to their own slot...
This way we can disactivate midi send of a patch globally when needed..redirect the midi stream to another instrument quickly for multiple midi send modules and create slot independent patches that control themself with midi send modules...
Shit... The alternative allocation mode..that gives held notes priority..so no voice stealing
and.
i just got 3 other things in mind... but that are the less important wishes
-A allpass filter module
-Allowing clock output on external sync...having the G2 clock transparent
-getting rid of the SOURCE tag on switches and show directly the setting of the switch in the displays.
So all together 9 wishes...
with my trick wish No 3  |
3phase
G2 patch files: 141
Posted: Sat May 12, 2007 6:58 pm Post subject:
| dasz wrote: | Feature #12 - don't forget mute less switching when loading an identically wired patch (to the currently loaded one) all modules and connections are identical, just different variations.
/Dasz |
Sounds good... but is that possible? how can the g2 know that the patch is identical wired? It would be necessary to analyse the patch before loading it..within the G2 itself..without aid of the editor..there fore increasing loading times a lot and taking many resources for the analysation process...
Maybe you see a way..than let us know it..
but... i would say that this is an unrealistic wish and shouldnt be in the poll...
I think its a good solution that each wish that mades it in the poll has to be discussed for realisation possibility..
so one of you now have to bring up an idea how the machine can handle this task...
or the more than 8 variations..the memory of the machine is limited as we can see while ptaching... so more than 8 variations would make patches bigger..and would you handle the extra variations?
I personally think 8 is enough... but..that on the poll..
but i suggest that an idea how the extra variations can be handled should be brought up...
the g2 only has 8 variation buttons...
How would you access more than 8 variations than? |
The Why Project
Posted: Sat May 12, 2007 7:11 pm Post subject:
| 3phase wrote: |
Some good discussion on the topic in this thread:
http://electro-music.com/forum/topic-5111.html
Regards,
The Why Project |
3phase
G2 patch files: 141
Posted: Sat May 12, 2007 7:13 pm Post subject:
| chinard wrote: | a few things on my wishlist:
-make the arppegiator into a module instead of being a global parameter.
-gate time for sequencer module (allowing for ties)
-user editable dead zone for pitch stick
-mono/poly key sorter (highest to lowest and last note played would be great)
-meter module! (I cant tell you how many times i wish i could put a meter on a control wire to test what values were being passed)
-flux capacitor |
You can have a pretty good meter with a midi send module that is assigned to a value module as receiver...with some extra scaling also bipolar values can be shown..only in a 128 steps resolution..but that is usually enough to show what is goin on in a patch...
http://electro-music.com/forum/topic-7278.html
also your first wish can be patched.. in much better ways than the internal one works..with swing and order function of keys played... more pricy than a single module... when you wish i can post a patch...
what the hell is a flux capaciator? |
3phase
G2 patch files: 141
Posted: Sat May 12, 2007 7:23 pm Post subject:
| The Why Project wrote: | | 3phase wrote: |
Regards,
The Why Project |
I had a look..but that you see this only from the engines perspective is not valid..the instruments have to stay compatible and more variations have to be stored somewhere...
so when ther are solutions for more than 8 variations it should be an extra patch format ..the fat patch...otherwise the memory would hold much less patches than now... i am constantly low in memory..the amount of theoretical patch locations on the g2 is rather academic...
Dont be offended..but i dont think clavia would change that...they wont make the patches twice or 4 times as big as standard... and they wont include a 3rd patch format... they maybe could improove how memory is located... so a patch with only one variation takes less than one with 8 or more... but realistically..why should they spend so much work in such a hidden feature? I think that is an unrealistic wish..this time not because its not technical possible..its just very very unlikely to convince clavia to do that...
When i understand you wright you want more variations for sequencing pattern changes... you should opt for my poly/multipattern sequencer wish instead... theoretical this would be able to store as much patterns as the theoretical voice maximum of the G2.....modulateable...
so you would have 32 patterns in each variation..so a total of 256 sequence variation per patch...
would that be enough?
But also if such a poly/multi pattern sequencer would be limited to 8 voices/patterns you would have 8 times as much variations in sequnecing as now...
i personally would be even happy with a 4 voice poly module...equals 4 pattern sequencer when switched to mono mode...
would allow me to sequence 4 voice chords and give you 32 drum patterns per patch...
the filling of an 808... |
3phase
G2 patch files: 141
Posted: Sat May 12, 2007 8:04 pm Post subject:
| dasz wrote: | 1. muteless patch loading - lock specific slots down (or groups of slots) - user definable (so tnot all dsps get rebooted whenever another patch is loaded / dsp reboots) and save-able per performance.
2. pattern memories for all sequencers
3. variation exclusion
4. clock based envelopes.
5. poly sequencer with pattern memories
6. pitch bend out and NRPN
7. Sysex Out |
no1 goes too deep in the given architecture how sounds are split between the dsps..especially polyphonic sounds..
Its not really like that one slot uses one dsp... Even when it would be great to live without loading times we have to accept that that is the nature of our instrument...
Maybe when the dsps would recompile in a certain order?
So that at least one slot is playing? all the time?
or the g2 automatical feeds the going sound in its own delay memory while recompilation and plays that during the recompilation? we would have a glitch than instead a drop out... a matter of taste..i would prefer the glitch..i can turn the mastervolume down when i want it to be muted...
In the end a rather unrealistic wish because this goes very deep...
In the poll i would feel defenetly compelled to vote for that...
but is it realistic? However..if this can be optimized i would love it...
i just gave up thinking about that years ago an i am happy that with the performance mode i only have one gap instead the 4 gaps i had with the nm1...
somehow i started even like it.. it shows on stage that i play really life opposite to the laptopacts that have theese perfect transitions..even better than dj´s...what is a bit lame...
loadn roll !!!  |
3phase
G2 patch files: 141
Posted: Tue May 15, 2007 11:00 am Post subject:
So.. I made a list of the mentioned wishes sofar...
I combined a few that would be handled by clavia as one wish anyway... and lefet a very few out when it seems to much a thing that can be solved by patching... but... mainly to safe some typing..when i missed something important.. correct it..
Sofar is to say that even with the little amount of users involved ther is a clear winning wish allready...
new sequencer modules !!! multi pattern and polyphony most wanted..and as i pointed out maybe can be realized as one module... but even without such details..there is a clear demand for that...
Beside that it allready happened taht in the top 10 are 3 wishes i would call unrealistic and one i would call redundant...
what wouldnt be so ideal to poll a list with just 60% realistic wishes...
For the very important midi master control for send modules i was the only one i opted for...what is a pitty because that issue makes working with the G2´s midifunctionality really uncomfortable and should be a number one priority...
So if here are others that see the need to shot off midi out from sendmodules without the editor or reasign them as patch setting please opt for it...
We have now in my reduced list 47 wishes allready... we cant poll them all... ther must be some further discussion...
I personally would prefer a list for a poll that totally leaves out unrealistic wishes..or we have an extra poll for what we see as difficult..
the gapless loading for example..of cause everybody votes for that....
But to be true... do you think clavia can reinvent the whole instrument concept in an update? this wish clearly asks for a new instrument...
Dasz anyway was my personal unrealistic wishes king ;-.)
However... here a screenshot of the previous list and the xls file...
Would be nice if allready mentioned wishes that are ssen as important get some backup from other users so we can see the tendency...
The poll schould not have more than 30 wishes to get a top ten that matters...
I UPDATED The LIST..therfore attachments got removed Last edited by 3phase on Wed May 16, 2007 6:21 am; edited 1 time in total |
dorremifasol
Joined: Sep 28, 2006 Posts: 823 Location: Barcelona, Spain
G2 patch files: 49
Posted: Tue May 15, 2007 12:12 pm Post subject:
Where's the velocity curve?? As my main desktop keyboard controller, this is the most important thing to me.  _________________ Cheers,
Albert |
Fozzie
Joined: Jun 04, 2004 Posts: 875 Location: Near Wageningen, the Netherlands
G2 patch files: 49
Posted: Tue May 15, 2007 12:14 pm Post subject:
Nice work, 3phase. However, imho we should first compile a list of all wishes (possibly combining overlapping ones), then discuss what is realistic and what is not, and finally have a vote to see what is important. As far as I'm concerned, there hasn't been any structured way of voting yet, so there is no basis to already conclude that certain wishes are important and others aren't. Maybe grouping similar wishes will help to reduce the list in size / make it more manageable. _________________ Spinning at ~0.0000115740740741 Hz |
3phase
G2 patch files: 141
Posted: Tue May 15, 2007 12:29 pm Post subject:
| dorremifasol wrote: | Where's the velocity curve?? As my main desktop keyboard controller, this is the most important thing to me.  |
this is in the list..very down..and actually a redundant wish because you can patch that if you really need that with just 3 modules...
Key in..scaler... midi send... dont costs even much...
but i kept it in to stop you from moaning ;-P
However... We really should concentrate on things we cant get easily done with some patching or a setting in the daw.. Velocity curves can be altered from allmost any daw or sequencer exept ableton live...
I see that it would be some extra comfort but... nothing i wold get feverish for the arrival of the update for... |
3phase
G2 patch files: 141
Posted: Tue May 15, 2007 12:37 pm Post subject:
| Fozzie wrote: | | Nice work, 3phase. However, imho we should first compile a list of all wishes (possibly combining overlapping ones), then discuss what is realistic and what is not, and finally have a vote to see what is important. As far as I'm concerned, there hasn't been any structured way of voting yet, so there is no basis to already conclude that certain wishes are important and others aren't. Maybe grouping similar wishes will help to reduce the list in size / make it more manageable. |
True..but it would be actually good if everybody would state theire main issues or gives a handup for wishes the would enjoy to see...that makes everything a lot easier..because the sequencer wish for example needs to be polled than anymore... and we can concentrate in the voting on the secondary things to give them an order of importance... the most wishes have a count from one..
would be good if wishes that are more important get more supporters..than we can build a main and second priority list. and maybe one with special ideas...
What is good sofar that the point that bothers me the most is on high priority allready... The sequencers are really a bit underdeveloped..its not much more than on the Nm1...what is too little for a performance syntheziser...
On tghe other hand my second biggest drawback got no attention even when i promotet it a lot... seems that nobody works with the midi send modules and therefor dont sees the inconvinience that they cant be controled globally... |
Joined: Apr 03, 2004 Posts: 24582 Location: The Netherlands, Enschede
Audio files: 308
Posted: Tue May 15, 2007 12:42 pm Post subject:
XLS ... ... Sven could you convert this to a file type that is accessible for non microsoft tooled ups like me? Like rtf or txt or pdf or csv or html or ps ... or a doc file, I can read doc files and convert 'm to pdf. _________________ Jan
3phase
G2 patch files: 141
Posted: Tue May 15, 2007 12:58 pm Post subject:
i can try..but would prefer to do the work on the update because in the moment not many people have opnend the mouth..maybe because they didnt like to double post wishes..but..that actually helps a lot to see tendencys and to identify populistic unreal wishes...
I really think that unrealistic wishes shouldnt be in the top ten list...
maybe as extra out of competition so calvia can see that there is a demand for certain things that might be involved in new hardware..but for now..?
A personal question..do you think there is anyway clavia could minimize the loading gap they would go for? i would love to have continous sound output on performance change... but is that an realistic wish? or one we should formulate out of competition?
Same with the more than 8 variation... i just dont see that possibliy happening because it would change the whole instrument and editor around without bringing anything new..just more...
When i would be clavia i wouldnt put resources in things that create a lot of work, problems and possible bugs with so little advertizing factor..
But maybe i am the only one with this view... opinions please... |
GovernorSilver
Joined: Apr 26, 2004 Posts: 1349 Location: Washington DC Metro
Posted: Tue May 15, 2007 1:23 pm Post subject:
I guess g2ian and Blue Hell have addressed the keyboard temperament issue to a considerable extend with their work - its just a matter of continuing to evolve the g2ools suite.
From the Wish List forum, I'd like to continue my support for enabling the G2 Editor to send/receive MIDI over USB.
Even better would be integration of the G2 Editor as an plugin, both AU and VST formats. |
Audio files: 308
Posted: Tue May 15, 2007 1:31 pm Post subject:
| 3phase wrote: | | A personal question..do you think there is anyway clavia could minimize the loading gap they would go for? |
Suppose you're asking me ... see noone else near ... must be me then
I don't think it is possible to eliminate the gap as it is, but some people have proposed to make it possible to freeze certain parts of a performance or some patches. I think that would make an implementation possible.
Personally I have no really strong wishes for improvements on the G2, well I have some, but they are not really strong. It would make sense to make the MIDI module list more complete than it is now, with at least pitchbend processing. I think the proposal for the MIDI master modules seems sensible as well.
But the thing is that everyone seems to look at it from a different angle, my angle is noodling on an engine and that looks different from performing on a keyboard. Then there are people who use sequencers a lot and others use 'm less. And probably I could go on a bit here. It will not be easy to do justice to all the different view points, both not for compiling a list here and not for Clavia to make something out of it.
There is one thing I would really like to see though and that is delays with the quality the old NM had and read / write pointers on them. But also I'd like to have longer delays, those would need a reduced quality of course .. unless real time compression / decompression would be an option.
Right I do seem to have opions after all
Ok, that's the answer, but what was the question again ...
It will be hard to judge I think for us what wishes would be realistic or not. I agree with you that it would be a waste to make a list for which Clavia could say one item after other "impossible, next please". Best we can do is to follow Fozzie's proposal I guess .. I mean discuss stuff, also with keeping in mind if it would be possible to make it - even though that is not so easy.
Oh something else that I would like ... up/down counters ...
Still it's too bad I can't read your XLS. _________________ Jan
Joined: Jan 31, 2003 Posts: 18276 Location: Durham, NC
Audio files: 233
Posted: Tue May 15, 2007 2:27 pm Post subject:
I second that... (I've mentioned it a million times it seems). Even just a velocity gain would be helpful.
Sure, you can modify every patch to adjust for velocity , but it is really a system function, like sustain pedal polarity, control pedal gain or master tune. To me, this would be the most important upgrade, even more important than the filter bank, but I long for a filter bank too. _________________ --Howard
my music and other stuff Last edited by mosc on Tue May 15, 2007 2:33 pm; edited 2 times in total |
